Notch Master
/ Notch Master #21
I looked at them and they look really good. I was given a cheaper copy of their bottom end model. But it has bushings vs the sealed bearings. The problem with the bushings is that metal from cutting gets on the shaft from the cutting lube and works it's way into the bushing wearing them out quicker. If I had to buy one I think I would opt for the sealed needle bearings.
/ Notch Master #22
I was just kidding about selling it, first couple tries were not very successful. :eek:
It's probably gonna be more time consuming with the practice than I can devote to it, to learn it right anyway, I'll just plod along with it when I can.
A little trick that may help you, if you are right handed? Hold the torch in your left hand, and feed the wire with your right hand. Always try to rest the torch hand on the base material, or something.
/ Notch Master #23
I'm gonna sell that thing, got no business owning one. :laughing:
Guess I'll make a base for my vise tomorrow. That'll be handy too, drop it in the same tripod. I'll try to be pro, tho, and weld the bolts on the other side.
I would drill, tap, use threaded stock and use red Lock-Tite. They won't come out, unless you need them to at some point.
Steve
/ Notch Master #24
I do not use any lube when notching tubing. I gets impregnated in to the metal and makes it dsificult to weld. even if you use a cleaner to remove the lube after cutting you have to worry about the cleaner fumes when welding. Some can be deadly.:eek:
Bill
/ Notch Master #25
nice notcher!!
I think that the Notch Master was the original that the chinese copied. Looks sturdy.
/ Notch Master #26
Bill
One of the welding supply shops I deal with sells a synthetic lube for cutting that doesn't need to be cleaned off before welding. I think it's more of a coolant than a lube. If I remember correctly it doesn't contain petroleum or Chlorine products. It's a house brand, like the spray fluid I use to keep splatter from sticking to the mig torch. It's been years since I've made a roll cage so I'm not even sure where the bottle is. But I found if I don't use a lube or coolant then the hole saws start to break teeth off but with it the saws last a very long time.
Lowbuck makes a nice notcher that doesn't require hole saws or any lube.
/ Notch Master #27
nice notcher!!
If they did they did a poor job. I think they copied the jigger, which IMO is a downgrade to the nicer woodward or JD2 notchers.
/ Notch Master
made this up today, now I'll be able to find my vise.
/ Notch Master
Thanks S/A, will try that. Going to get some thinner wall pipe now and try some tigging. Somehow I fear, I am not destined to be a tigmeister.. :laughing:
/ Notch Master #30
Oh it takes time! It is the hardest process to learn. What you need is a good pair of thin gloves that can take a lot of heat for your torch hand. Next time you're at the super market pick up one of those Ove Gloves. They are really nice for Tig welding. Majority of the time I don't wear a glove on my filler wire hand.
/ Notch Master #31
Hopefully you will have the time to learn. There are probably some vids on youtube that could help you out. When you are welding notched pipe it is hard to make it look good with a mig. you have to start and stop to many times to get in position. With a tig you can start and stop as many times as you want and won't be able to tell. One thing that I have learned that helps me while tiging is a magnifying lens in my hood. This could also be because my eye sight isn't as good as it use to be.:laughing:.
Bill
/ Notch Master #32
Your right! The clones look more like the Joint Jigger.
Its hard to beat JD2. Their benders are among the best as well
/ Notch Master #34
Shield Arc, can you expand on that a little? I have been told you can't weld aluminum with DC, but obviously that's wrong. Thanks.
When Linde invented Tig welding aluminum it was called Heliarc, and this is how it was originally done.
Hopefully you can read all this, it will explain better than I ever could!:eek:
/ Notch Master #36
Nice notcher. I made one a few years back and it gets used allot. It's heavy and has no chatter while being used. The down side is it took me two days to build it but it will last a lifetime and it was a fun project.
/ Notch Master
Well, anybody else we'd let slide Paul, but you have to post a picture. :laughing:
I spent all afternoon checking out benders. It's scary on the internet, almost spent way too much (for my skill level..) ordered a HF.
/ Notch Master #38
Well ok but don't laugh :eek: You'll have fun with your new bender :thumbsup:
Made it all from scrap that was around the shop.
/ Notch Master
That looks good! :thumbsup:
Windmill Target (A64912)
Windmill Target...
2017 Kubota ZD1211 (A64912)
2017 Kubota ZD1211...
2003 Honda Pilot AWD SUV (A66738)
2003 Honda Pilot...
PALLET OF MISC FLANGES/BOLTS (A67714)
PALLET OF MISC...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
2018 CHEVROLET SILVERADO CREW CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
