help building a tree trimmer.
/ help building a tree trimmer. #1
92b16si
im looking to build something similar to this, to help trim avocado trees. the fab works, looks really simple. need help on figuring out what type of blades ,how to run them and what type of hydraulic motor to use.
[ame=http://www.youtube.com/watch?v=qVygcZYpJfs]Bubco Tree Hedger.wmv - YouTube[/ame]
/ help building a tree trimmer. #2
I was thinking about buying another old sickle mower and making it hydralic drive and using that for cutting my caraganas in my yard as there a pita to trim by hand.
/ help building a tree trimmer. #3
All those spinning blades looks like sumthin outa a B grade movie. OTOH, it would do a good job trimming my MIL's hedge.
/ help building a tree trimmer. #4
It is amazing what people design isn't it? I did notice when he was topping, it seemed to leave a few sprouts. Perhaps going to fast?
http://www.bubco.com/vineyard.htm#T2200E
Looks like they have quite a bit of info on their website. Including some good static photos.
I was looking for info mainly , on what kind of hydraulic motor I need to use. and how to i link all the blades together.
/ help building a tree trimmer. #6
I would be interested in your findings as I plan to make something for a similar purpose (grapes and blackberries pruning).
I have been mulling over using a discarded gas hedge trimmer and replacing the gas motor with a hyd motor. Then afixing some additional hyd cylinders that would allow me to raise it,anble it and change positions. I am still in the contemplating stage...
/ help building a tree trimmer. #7
That is a very interesting vid.
On your request for assistance from the TBN members I think you need to define the parameters of the project.
What is the mounted vehicle
What is the acreage to trim
How much $$$$$
I know nothing about trimming trees on that kind of scale. But if I did do that sort of operation then it is very specialized.
The cutter looks very good. The estimated run hours is going to lead different people on various thought paths.
A 1 acre grove or a 200 acre grove.
ie on a 1 acre grove the cutter will probably be removed when the trimming is finished on 200 acres I think the tractor might be used full time.
Craig Clayton
How much $$$$$
Craig Clayton
good questions. this will be mounted eaither on a ford 5500 or a john deere 5725 .
it will need to trim about 38 acres of avocado trees.
price wise , as long as it is cheaper to build then to buy and import this to mexico.
/ help building a tree trimmer. #10
Hi,
the blades are heavy duty saw blades. they turn at the same speed as a normal blade. Make sure of this as too slow will cause grabing.
the blades are over lapped to stop jamming.
Easy to mount as replace the bucket on any loader. set it out side the wheel as then can also do hedges. Have a tilt so that it can be changed on the move when the tractor moves due to uneven ground.
The hydralic motor can be spect fron a good supplier.
belt drive between blades.
Hi,
thanks .good info. thats guys trying to gather up all the parts in the next couple of months . ill keep you posted.
/ help building a tree trimmer. #12
If it was a belt drive unit, I would think you would need a tensioner between each shaft. But, probably not with a chain driven unit. But again you might, or you will get a bunch of chain slap.
Your sprocket / pulley sizing, along with the mating to a properly sized pump will take some calculating.
Since the blades are offset, would you run the sprockets / pulleys offset also, using a dual drive?
Belt driven would be smoother.
Unless you have already done so, I would be calling and asking some questions. I would ask what the blade RPM is, rotation, belt or chain driven, etc. Blade type and size also.
Interesting build, but you could be buying a ton of parts trying to re-engineer this thing.
This thing will have to be built with some tight tolerances. Having 6 or 8 large spinning blades rotating at 7000 rpm? smacking into tree limbs for hours on end...., having a shaft vibrate loose - someone could loose a head. Ouch.
Keep us posted.
/ help building a tree trimmer. #13
I needed to let the thought process rattle around in my head for awhile.
So based on my 10 acres that I planted 1000's of trees on I did some rough calculations.
My acreage is 330' by 1500? more or less.
Using a single cutting bar and the tree rows 30' on center
It requires 1/4 mile up and back to trim
So 1/2 mile per row per pass
10 rows x 1/2 mile = 5 miles per 10 acre block
5 miles x 4 blocks = 21 miles with ends
21 miles div 3 mph = 7 hours per pass
Some years back I built my city based wood chipper which was a lawn mower with a plywood bottom no wheels and the branchs were feed into the top and it worked.
I heard the TING of the saw blades ( vid ) which I also hear when I use the blade on my gas weed eater.
This is the budget model unless you want to go big.
Buy lawn tractor deck mower spindles and mount 24" blades on them and a steel pulley on the other end.
use the common 24" x 3" x 1/8" blades
mount them similiar to the saw blades.
drive them with belts like a mower deck
all powered by a hydraulic motor
That ends model 1
Model 2
is smaller
use chain saw bars 24" in pairs
powered by a worm drive skil saw
powered by a 5000 watt electric generator
J J's posts are of a very strong design
Made in Canada
My chain saw design will work but the run hours per trim are too high
for bar lube use corn oil ( enviro )
Craig Clayton
/ help building a tree trimmer. #14
im looking to build something similar to this, to help trim avocado trees. the fab works, looks really simple. need help on figuring out what type of blades, how to run them and what type of hydraulic motor to use.
______________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
You should seriously look at what the Minute Maid Orange Juice folks
did with thier orange groves when Coca Cola owned them.
Seriously-they made each and every orange tree in production into a box size topiary planting. This in turn allows them to use a propane or diesel scizzor lift to prune the groves when needed and make the harvest easier with orchard ladders making all the limbs uniform within the box size desired and use a small 4 wheel drive scizzor lift as well at the same time.
Using a scizzor lift would allow you to use an electric hedge pruner to trim the limbs or a chainsaw pole pruner as well with a large work platform directly where you see the work that needs to be done.
the thing with this is involves to much man hours, and too much time, i rather am shooting for the box type design as well , but i see this machine cutting my pruning time in half and the man hours as well.
does anyone know what rpm the saws should be running? were could I get the hydraulic motor's . I live in Mexico, but travel to chicago often. hopeing to start building with in the next couple of months.
/ help building a tree trimmer. #17
Go to the home page and in the top left corner click on the add for Surplus Center. They have all sorts of Hyd items
/ help building a tree trimmer. #18
/ help building a tree trimmer. #19
I also have been thinking about a bucket mounted sickle bar similar to the Samurai. Matter of fact, I have a Gravely walk behind mower sickle bar less than 4', which would be perfect for my usage. The hydraulic requirements would be similar to the Samurai.
I believe the Samurai is a nice attachment, just a bit too pricey.
The thing is i dont think a sickle bar would be hable to cut 3" branches, but this things is in the low $30's . There is no way i can spend that much
2018 Ford Escape SUV (A66738)
2018 Ford Escape...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2006 KENWORTH W900 (A67714)
2006 KENWORTH W900...
2016 Chevrolet Express Shuttle Bus (A66736)
2016 Chevrolet...
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
2018 Autocar ACX Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2018 Autocar ACX...
