Which Winch
/ Which Winch #11
I have a Viper (not Venom) winch on my RTV 900 and love it. When I bought it I did extensive research, and found the Viper to be rated better than the Venom. I know Warn is great, but for the difference in price, the Viper was a real deal, and it has done everything I need. Visit some of the ATV forums and see what actual users are saying.
/ Which Winch #12
There is WARN winches and then there is everything else in my book. You get what you pay for.
/ Which Winch #13
I've got a Ramsey on a Honda Rancher and it does a good job, must not be to many others though that think much of them.
/ Which Winch #14
Well not to start a fight but warn aint all it is cracked up to be. around 4 years ago I bought a brand new M8000 1st time I pulled my jeep up a muddy grade it burnt up the motor. I have used winches for years and this was not a hard pull, the jeep just wouldnt make it up the last 20 feet of slope. I contacted warn cause it has a great warranty and after all it is a warn, they will stand behind their product right? Wrong. I was advised by the warn rep that the winch was not rated for a 20 foot continuous pull. That the motor burnt up because I had ran it too long. he then wanted to sell me an outrageously priced replacement motor. They oiffered to look at it if I sent it in but informed me that if there was a non warranty issue (which he already determined I had abused it) I would be responsable for the repair cost. So I turned around and bought a ramsey patriot 9000 lb winch. It has been on a trailer since it arrived and has pulled combines, trucks cars and anything else I hooked it to for the last 4 years without so much as a hickup. I pit a cheap chineese winch on my jeep and blew a gear box, in a situation where it was reasonable to blow it. Got the same service I recieved from warn but at 1/3 the orignal cost. I bought another one identical and it has been on there since. it is chinees crap but it works when I need it.
Under no circumstances will I ever buy another Warn winch. I will save my money and go ramsey.
My quad has a cheapo chinese special from tractor supply and it works just fine for the 50.00 it cost.
Did I mention warn is no better than the chinese crap?
/ Which Winch #15
MileMarker has been a great lower priced winch for me,own a 3500lbs and 8000lbs.
/ Which Winch #16
I have Ramsey and love the wireless remote. Had one on my 2004 RTV 900 and never a problem. Kind of expensive but worth the money.
/ Which Winch #17
I'm hardly a winch expert, but from some Warn failures experienced by my brother with his Gator, I now understand that winches are designed with something called a duty cycle in mind. In the above post with the Jeep, Warn said it was abuse because the pull exceeded the duty cycle (the time allowed for continuous use at a certain load, before a designated period of rest and cool down before another pull.) All those people talking about buying a winch to pull logs out of the woods with their ATV winch should take heed. That is how my brother burned up two Warn winches.
You need to really search to find out this information. Warn, for one, provides this information but you have to try hard to find it. Simply buying a 3000# winch for a 1500# UTV sounds like a great idea until you study the details.
I believe this applies to all electric motor winches. That is why some winches are hydraulically driven. That is why some cost several multiples of the cheaper ones.
You should not buy based on name alone.
Do your research.
A winch being used at only 10% of it's rated capacity can be used much longer than one being loaded to it's maximum rated capacity. The manufacturer should provide a chart you review before you make your purchase.
Just my suggestions. Take it or leave it.
/ Which Winch #18
I mentioned here that I like the wireless remote control for the Ramsey. Today I got my 3130 tractor stuck on the side of the hill in some wet snow and everytime I tried to move I started down the hill sideways.
I brought the RTV over and put the plow down and attached the winch to the front bucket of the 3130. Got on the tractor and slowing started to move it, then used the winch on the RTV and the tractor power to get out.
Couldn't have done that with a wire control.
/ Which Winch #19
I want a winch for my Arctic Cat 300 ATV. I'm looking on Ebay at 2000lb to 5000lb Venom brand winch.
My question is: what are the disadvantages to the larger winch. I'm I correct in thinking that bigger may not be better because more amps needed. Or is this something I shouldn't be concerned with.
My uses will be getting the ATV out of places I shouldn't be and occasional light log skidding.
I have two Warn 2500 winches with synthetic rope (a must have by the way). One for plowing and the other for ATVing. For an AC 300 I would say at least a 2500 would be okay.
Warn is an okay winch but certainly not the best. Bigger winches do not always equal bigger performance. Your battery and stator needs to keep up with the power requirements of the winch. If in doubt, bring a snatch block\block and tackle with you as well.
/ Which Winch #20
11174d1257819380-installed-road-armor-bumper-06-ford-f250-emergency-rescue-vehicle-l_5cbae0a126de407a86328c5de74ad789.jpg
Used Landpride GR1525 Stump Grinder
Used Landpride...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
iDrive TDS-2010H...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
