Blowing Fuses on 2165
/ Blowing Fuses on 2165 #1
Ottodrome
I have a 2165 that has been working great. All of a sudden I started to blow the 20a fuse between the battery and ignition switch. It happens sometimes in the middle of snow blowing. It also happens when I shut the unit off and then try to re-start it.
Any ideas? I do know my ignition switch is a bit loose. Not sure what it could be.
Any help would be appreciated.
/ Blowing Fuses on 2165 #2
would look at connections to or the ignition switch itself as the culprit. A test light or VOM should help you isolate the short.
/ Blowing Fuses on 2165 #3
Put a head lamp across the fuse holder. You may need a switch with fuse in series to get it started. Wiggle wires and connections and look for the light to get bright.
As it turns out it was the fuse holder wire itself. I changed it and problem solved.
HD Round Bale Feeder (A66408)
HD Round Bale...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
2025 Mini Excavator Rake Attachment (A64553)
2025 Mini...
Longhorns (A65583)
Longhorns (A65583)
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
