Blowing Fuses on 2165
/ Blowing Fuses on 2165 #1
Ottodrome
I have a 2165 that has been working great. All of a sudden I started to blow the 20a fuse between the battery and ignition switch. It happens sometimes in the middle of snow blowing. It also happens when I shut the unit off and then try to re-start it.
Any ideas? I do know my ignition switch is a bit loose. Not sure what it could be.
Any help would be appreciated.
/ Blowing Fuses on 2165 #2
would look at connections to or the ignition switch itself as the culprit. A test light or VOM should help you isolate the short.
/ Blowing Fuses on 2165 #3
Put a head lamp across the fuse holder. You may need a switch with fuse in series to get it started. Wiggle wires and connections and look for the light to get bright.
As it turns out it was the fuse holder wire itself. I changed it and problem solved.
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
NEW Wolverine 78" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 78"...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
(16) Kinze 60 Cell Bean Plates (A65640)
(16) Kinze 60 Cell...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
2017 Metso Lokotrack ST2.4 Screen Plant on Tracks with Feeder (A65579)
2017 Metso...
