2012 F-350 - First Impressions
/ 2012 F-350 - First Impressions #41
That F250 they slso ordered will not last long. Its a good looking truck just like your F350.
Chris
/ 2012 F-350 - First Impressions #42
I find the integrated key/remote fob is a PITA.
The key doesn't fit in my pocket comfortably with other keys on the same ring. I liked the key and remote as separate pieces. I don't carry a lot of keys, 5 including the truck key, but it's this one key which is almost 4 inches long that is a pain.
I absolutely agree on the USB pots, there should be more. My 2011 Chev 2500 only has one.
The key deal though....why not just carry it by itself? Thats what I do with the key o my 2008 Taurus. Works real good.I like it better just by itself.
/ 2012 F-350 - First Impressions #43
Yeah, I see it all the time... There's a vocal minority(aka whiners) who badmouth a brand. Look, I'm no koolaid drinking robot, but I have real world experience. I've recently had a ford 6.4 diesel(really liked it) and a new 2011 6.7 diesel(love it). F the forums, I'll tell you how it really is.
That would help but I know me. I would end up leaving that single key behind somewhere or leaving the balance of my keys somewhere and trying to retrace my steps to locate them.
My daughter bought a VW Jetta with a key which folds up like a pocket knife. I thought that was a good idea. Keys seem so outdated anyway, I can use the keypad on the drivers door to open the vehicle, just another small step to start it by the same method and do away with keys altogether or make them the secondary access method.
If the drivers information display, that 4.2" screen on the dash between the tach and the speedo can show me what gear I'm in when the tranny is in Manual, why not show the current gear all the time? Wouldn't it be nice to know what gear the tranny is in at any given time while driving just as a point of information?
The same display could be used to graph vehicle speed along with the gears and engine rpm. You could see how the tranny reacts and shifts with various loads.
Also why can't the computer figure out that it doesn't always need first when starting from a dead stop when there is no trailer connected or no load in the bed? I would think that for mild acceleration with no load other than a couple passengers that second gear could be used and the computer could be smart enough to figure that out.
/ 2012 F-350 - First Impressions #46
Why can't it also send a report to your iPhone so you can review the data in more detail later? That way you could cross reference other charts and determine how to optimize. Those computers are fantastic but totally under utilized.
/ 2012 F-350 - First Impressions #47
Just FYI, it sounds like I've got the identical truck as you. The screen will show you what gear you're in. Put the truck in drive, and tap the + on the shifter. After that, the gear will always be displayed. Tap the - button to make the gear indicator disappear.
/ 2012 F-350 - First Impressions #48
You can also tap the "-" to limit the top gear or force a downshift when in "D".
Thanks, I'll give that a try. Didn't read anything about that in the manual and didn't see it anywhere else.
/ 2012 F-350 - First Impressions #50
Thanks, I'll give that a try. Didn't read anything baout that in the manual and didn't see it anywhere else.
Not sure about the pickups, but the F450-F550 C&C trucks always display the actual gear even in auto mode, without tapping the +/- button... They did not come from the factory that way, but thru the numerous software updates we've been thru, that function has been incorporated.
I would think the dealer could change that option with a dealer service tool if you cannot option it yourself..
/ 2012 F-350 - First Impressions #51
I can't speak to the Chevy/Duramax engine brake but I have a 2012 Ram 3500 with the Cummins and the engine brake is awesome. I haven't towed too much with it yet but if I shift the auto trans down manually when stopping I hardly use the brakes at all. It has more power than I can use. So far a great truck.
Matt.
I have to second that :thumbsup:Exhaust brake is awesome my ride.JPG
You can do that in a round about way. The data gets sent to Ford using your phone and Ford Syncョ, then it is emailed to you at the email address your registered with Sync. I wish you could connect via BT to the computer and then run an app on your phone to show whatever your want. There is an app called TORQUE available on Android Market which uses a BT transmitter that plugs into the diagnostic port and connects to your phone and does just that. Garmin also makes an adapter that will connect to some of their newer GPS units or to your phone running their Garmin Mechanic app where you can see way more information than is allowed on the trucks display.
Found this photo which shows what I;m talking about for those who have not seen it. You can see the gears displayed along the right margin, I don't see that on my display on any of the screens and no way to enable it. I will try hitting the + button on the shift lever next time I am in the truck, hopefully that will do it. If not I will ask the dealer if it can be programmed to show it.
Well it worked. I tapped the + button and the gears are now displayed, thanks.
I used my dump trailer to move the Bobcat today. A short tow only 10 miles. Truckdrove like the teailer wasen't even there. Of course at only 7600 pounds it wasn't much of a load either.
I did have one problem, I got a 'diesel exhausr fluid system error' onthe screen. It said the truck would go to limp mode (max 50 mph) starting in 50 miles. I got the message again a couple miles later. Both messages came up while towing. After I had shut the motor down and restarted it the error message and the system error icon on the screen were gone and did not come back.
/ 2012 F-350 - First Impressions #56
You had better talk to the dealer about that. That limp mode is not really a limp mode, it is a government mandate to force you to keep your DEF system working and fluid filled. It will eventually limit you to like 5 MPH or something if you try to ignore it. It sounds like yours is malfunctioning :/
/ 2012 F-350 - First Impressions #57
So many problems with these DEF systems already. Color me surprised...
/ 2012 F-350 - First Impressions #58
I just read all 3 pages here, I must really be turning into a dinosaur! Nothing against you fellas that like all those "gizmos" on your pick ups, but I'd gladly trade all that (computer) **** for a few more thousands in sheet metal thickness, real bumpers, and a metal dashboard to hold my magnet clip for my paper notes and reciepts!:laughing: oh yeah, give me some wing windows also! I'm still pushing a couple of 7.3 and for the life of me just don't understand how they get away with selling a PU truck @ 50K+? My "old" trucks, (01 350 and 00 450) were at least 15K less when new, not all that long ago. Now they don't have all that electronic stuff, but all those gadgets wont drive a nail or get a lick of work done on the job. And I don't get anywhere near that much more for my work (as they charge for these trks) on the jobs as a contractor, and even back then I wondered if I was working for the truck or was the truck working for me?
Sorry about the rant, it prolly is Mr Jim Beam talking, he helps out my knee pain after a long day on the job site!
/ 2012 F-350 - First Impressions #60
Jeff beat me to it. You can still buy a plane work truck for a lot less:thumbsup:
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
2015 Freightliner M2 106 Petersen TL3 Forestry Grapple Truck (A61573)
2015 Freightliner...
2016 Ford F-550 Ext. Cab Enclosed Service Truck (A61573)
2016 Ford F-550...
Can Am Defender (A63688)
Can Am Defender...
2006 Ford F-150 4.6L V8 Gasoline Engine (A61573)
2006 Ford F-150...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
