Basic plumbing question
   / Basic plumbing question #11
Same thing happened to me. The wall behind my kitchen cabinet was wet, and I thought what the heck is this from. I went into the a room and sure enough the wall board was soaked.
I pulled the dray wall away and saw a pin dole leak from the mail line. The house was bought new and was five years old when I spotted it. Don't know if it just started or was going for a while.
I called the builder knowing full well he would say "sorry the house was only warrantied for a year'. To my surprise he said he would send out the sub contractor to inspect. Next day the sub showed up and agreed it was from their install. ( how could it not be it was in the wall? )
Next day a HAZ MAT crew showed up. Yes I said HAZ MAT. These guys came in with space suits, set up temp walls out of plastic film, brought in special haz mat fans to do negative pressure inside the plastic room that was once my kitchen and laundry room.
They took everything down to the 2x4's treated the mold and rebuilt that section of house.
Didn't cost me a dime. I couldn't believe it.
So if you have mold it's a pretty serious thing. Have it inspected and do it right or you will have health issues.
   / Basic plumbing question #12
I am an electrician ( wrong trade ) yes I know. I roughed in my bathroom in the basement and I called in the building inspector and I (PASSED ) everything was correct.
I found all the info on the net.
I found a site The City of Winnipeg building dept that explains about TY s and which direction they go on.
When the rough in is passed the only thing left is to mount the fixtures. I have not mounted the fixture because the girls graduated before I got the job finished.
Now that I have some spare time I want to mount to WC, basin.
Then I will have to mount the light fixture ????
http://winnipeg.ca/ppd/pdf_files/PlbgInfo.pdf
This is the Canadian code. Not much difference except ABS verse PVC.
It all flows down hill
   / Basic plumbing question #13
Does a plumbing job like this need vents? Should this waste return also have a vent pipe?
Where is the tee, before or after the trap?
An alternative would be to replace the tee and cap with straight couplers. This would eliminate the gurgling and remove a void which is going to eventually fill up with something nasty.
Sorry. I was actually thrilled to find it. Consensus is you need a vent (from what I pulled up.) Also, consensus is most jurisdictions will allow you to use a device such as this:
STUDORョ MAXI-VENTョ | IPS Corporation
Now..I don't even know where they are suggesting you put that thing.
Edit: This link could be helpful.
Home Tips : Drain, Waste & Vent Plumbing Systems
I am thrilled you found it for me. Thanks!
Added to my favorites. Future reference, since renovations are *never* done.
After the trap.
Agree with what you say. Thanks.
1999 24DTA pintle hitch trailer (A52128)
1999 24DTA pintle...
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52128)
2009 Lee-Boy...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
