Any Subaru owners?
/ Any Subaru owners? #81
Yeah, I've been enjoying this car. you can lug it around like a little old lady or drive it hard like a rally car. Can't wait til it snows!
I did the timing belt today, well I should say I started it cause I didn't have all the parts to finish it. I didn't start til late in the day, at first I was just gonna look at it, so I took the small cover off. didn't look to bad but definitely not new so I know it's 10+ years old.
Then I just said the heck with it I'm gonna do this, watched a bunch of tutorials on YouTube so I knew what to look for. It was really pretty simple. 3 small size wrenches and sockets and a breaker bar and larger socket for the main crank pulley.
The tensioner did not look to healthy so I got a new one and just figured might as well get all three idlers. At 76,000 I'm not gonna do the seals and water pump. $350 in parts (genuine Subaru) so not to bad. still have to pick up one idler in the morning. I think I got all the marks right, it's like painting by numbers :)
Just hope it all comes out right.
The ten year old belt looked pretty good with no cracking at all, so maybe it could of went the 30,000 more miles to get to 105K. but it was bothering me thinking about it being past due to change due to it's age.
JB
Every timing belt I ever changed looked not new, but pretty good, so I have decided not to let that concern me.
Once, I changed a belt on a 1992 subaru, and its tensioner had a fluid in it, and a spring. As soon as I started it, it jumped time. I put it back in time, and before I started it again, I turned the engine with a wrench in the proper direction to make sure that the slack would be in the tensioner area instead of distributed around to various places.
Then I went in the house to get a beverage, to allow time for the spring to push, and the fluid to redistrubute properly. They I started it, and drove away, no more issue.
So, from then on, if I am using a spring loaded tensioner, whether it is fluid filled or not, I ALWAYS rotate the engine in the proper direction by wrench to make the slack all arrive at the tensioner, then I wait a few minutes before starting it.
Thanks, I'm gonna do just that. since I got a new tensioner it already had the grenade pin in it so I didn't have to deal with compressing the old one.
The tensioner did have oil on the top and wear on the top of the plunger.
The idlers could have gone back in, but since the dealer gave me garage/ wholesale prices It was worth it to replace all of them.
Was actually cheaper with the price the dealer gave me than the NAPA prices, I think they took pity on me doing it myself, cause the first prices they gave me were way higher. Plus I called them about 6 times going back and forth about should I change this or that. They even had a tech look at my old parts, and also let me talk to one of the techs on the phone to resolve an issue I was worried about.
The only issue even just a decent back yard DIYer would have is that 22mm crank pulley bolt, there is a special tool to hold the pulley to break it free and to torque it. I did the starter trick to break it free, that is a little hair raising for the inexperienced. But am thinking now with a standard, couldn't I just leave it in gear and torque against the drive train???
Well I say it's so easy, but we'll see in an hour when I put it back together :eek:
JB.
/ Any Subaru owners? #83
JB
Yeah. Thats what my 10 yr belt looked like at 230Kmi. Service on those seem highly related to time and secondarily to type and amount of use. Used regularly over a 10 yr period those belts will wear out the water pump and you can just replace everything together. Used irregularly, esp in latter of 10 yrs, and youre liable to get cracking at the roots of the teeth regardless of low mileage. Thts probably why the conservative change interval - to cover the very worse cases.
larry
Well it's all back together and working great. I was a little concerned when I hand rotated the crank to where the marks on the belt lined up with the timing marks on the engine again, but the marks on the crank and cams were way off. But when I brought the crank mark straight up, the cam marks were lined up correctly again.
I guess eventually the belt marks and the pulley marks would all come together again after X number of revolutions, but are mostly there for initial setup.
Engine definitely running smoother, not just a placebo effect. especially noticeable at higher rpms, over 4000. before it seemed like the engine was working hard, making more noise when shifting at 4000+ rpms, now it sounds like it's much happier.
This engine red lines at 6000+ rpms. I can't imagine wringing it out to red line, 4500 is very aggressive driving.
Oh yeah my first tankful of fuel hand calculated to just under 25 MPG, with the new belt I suspect it may be a tad better. So that's at least twice the mpg's I'm getting with my other 3 vehicles.
JB.
/ Any Subaru owners? #85
Discovered this week I need to get an axleshaft and front brake calliper. Ah well.
I heard the axles are pretty cheap, I have no idea how much labor is involved to change one. This car has 2 new ones in the front already.
I'm sure there are all kinds of video tutorials on replacing axles on line.
JB.
/ Any Subaru owners? #87
I have the FSM on disc. I suspect the hardest part to doing the axle shaft is separating the ball joint up front.
I really cannot complain, I have not babied the car and it has served me well. I should do some protective measures under it. I can see where rust is going to be a costly problem.
Update:
Liked the Subi so much I got another, 2001 forester, this one has an automatic, for my son. $3,500. one owner with 120,000 miles on it.
Going out right now to do the timing belt. The guy was asking much more for the car, but was getting scared by other potential buyer's mechanics about what the timing belt would cost. Since I'm a pro now :eek: I knew I could do it cheap and save some money.
The car is fairly clean in and out.
I'll get some pics later.
JB
/ Any Subaru owners? #89
I know my mom loves her '10 Forester, I was surprised how much room there is.
/ Any Subaru owners? #90
Update:
JB
Good deal.
Getting that ball joint separated was in fact the hard part. Cruise control switches are getting flaky. Must be 220k of use wearing them out. I use cruise constantly. All the way to work and back and much of the last 220k.
Yeah, I almost walked away from this car, for how it looked underneath, could see it had been sitting for awhile. But after I cleaned it up I think it is a decent deal.
This car looks very good on the outside and inside, but is not to pretty underneath, alot of rust and corrosion. I spray bombed it with anti corrosive PB blaster today.
I did the timing belt today along with the tensioner. The timing belt job is really like painting by numbers, it's that easy.
Fixed a bunch of little piddle stuff, like clock, weather stripping, window washer pump. Removed a mouse nest from the blower fan that was so packed the fan could hardly move, the nest material came from the hood insulation.
The tranny is something I'm a little concerned about, although the owner says he had the fluid flushed and replaced. There is a little evidence of seepage between the tranny and trans-axle, and on the trans-axle where the axle comes out.
Trans-axle fluid looked clean and between the marks, but I could not get the fill plug off the rear differential to check the level. And that was with a breaker bar and a 2.5 lb hammer, also a 1/2" Snap-On impact wrench (only 120 psi though). I was able to loosen the drain plug and I see there is fluid coming out, it looks clean, just not sure how much is in there.
JB
/ Any Subaru owners? #92
JB
What does the timing belt look like at 120K? Mine [1996] still looked ok at 260K when I had it changed. 287 on the car now.
larry
/ Any Subaru owners? #93
Wife bought a 2003 outback new.We lost the head gaskets and waterpump at 30000.Iwas disappointed.Just recently we lost the head gaskets again,AT 70000.She loves the car i consider the engine to be a lemon.She wants a new one ,would the 6 cylinder be more reliable and get us away from these repeated head gasket issues?
ALAN
/ Any Subaru owners? #94
ALAN
There was a redesign in about 2005 which corrected the issues from what I understand. My mother's gotten 120k on hers without such issues (2005 Legacy).
/ Any Subaru owners? #95
My 02WRX doesn't look especially pretty underneath either. Has never sat for very long (used to do 30k per year). But since I have to park outside and live in PA, I had the double hit of both salt on the road and not really able to wash it much during the winter.
larry
Not to bad, no serious visible cracks or fraying, but I think it stretched a little.
Engine sounds quieter with new belt.
I did my first one with just 75,000 on it, cause it was 10 years old.
Belt from Subaru dealer is only $75.00, they recommend replacing anytime you remove it for any other work, due to the risk of interference issues should the belt break.
I imagine it tightened your motor up a bit, changing that belt after 260,000 miles, must of been stretched for sure.
ALAN
I'm well aware of the head gasket issue, but have seen no evidence on either of mine. That's pretty bad to have them go twice in 70,000 miles :mad: Don't blame you for calling it a lemon. That's pretty faithful of your wife for still loving the car after the head gaskets fail twice. I do like the way these cars drive, must have something to do with it.
JB
/ Any Subaru owners? #97
We had two Subs. Loyale had zero issues until our son got hit by a truck and totaled the car.
1999 Legacy Outback is second on my list of cars I dislike. It was OK to maybe 120000 but after that it was a money pit costing in avearge 100 a month for something small like sensors, alignment, relay you name it. It had oil leaks, power steering leak etc. It had, considering the size, rather high fuel consumption and was underpowered. Since we live on a gravel road it was great in mud and snow though.
/ Any Subaru owners? #98
ALAN
Necro thread.
The 3.0 H6's don't have head gasket problems and use a timing chain instead of belts. They also had a five speed automatic instead of four. Mine has 175,000 miles on it, currently.
/ Any Subaru owners? #99
Wow 6 year old thread.we still have the 2003 it's still a good car and my daughter uses it for college .my wife now drives a 2013 outback we really like that one once again we bought the 4 cyl
/ Any Subaru owners? #100
I am glad this thread came back up. I have been considering trying a Subaru Forester as my next daily driver. I am driving a full size truck now and am thinking of replacing it with a used Forester and a used F-350 flatbed 4x4 for the farm. The feedback from Subaru owners in this thread has been very helpful....thanks
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 FREIGHTLINER...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2014 Peterbilt 337 S/A 18ft. Cab and Chassis Truck (A64194)
2014 Peterbilt 337...
2014 Kenworth T400 T/A Kill Truck (A64194)
2014 Kenworth T400...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
