Another Mini-Dozer
/ Another Mini-Dozer #261
One last contribution to the "drill press modification" hijack...
I've attached a picture of the speed reduction mechanism on this bigger drill press that I bought. Some of you may be able to poach ideas from it to adjust your own. I don't know if the motor pulley can be turned upside down like this on the smaller drill presses.
The first picture includes a full shot of the center idler pulley and the off-set pin that allows it to move in relation to the other pulleys. The second picture is the assembled drive mechanism.
What you have there is the exact concept my friend at the coffee shop in town was describing to me when I talked up the modification I'm planning for my DP.:thumbsup: Certainly simplifies it. My remaining concern is the puny "sewing machine " belt on mine. I'll have to see about changing that out somehow.
/ Another Mini-Dozer #262
I'll be up against the same thing. Changing out the pulleys should not be bad. I just wish they were cheap. I am going to look for a new (used) machine first.
/ Another Mini-Dozer #263
Since I have two of these DPs, I see no need for retaining the multi-speeds feature on the one I'm doing the mods to. Is there some way I can stay with the thin belt off the motor to the idler and then go bigger to the spindle from there without going all "Rube Goldberg" with it? Help!:p:confused2:
Yeah, I'm perpetuating the hijack of this thread, aren't I.
/ Another Mini-Dozer #264
C'mon man! The belt off the motor will still have to be replaced because it will be too long. It should be an easy pulley to replace. Send the sewing machine belt to Singer.
/ Another Mini-Dozer #265
You're right, of course.:laughing: What was I thinkin':ashamed::laughing:
/ Another Mini-Dozer #266
After all this talk about drill press speeds, i descided i should go out and check mine. I couldnt remember what speed ranges my old Delta DP had, all i know is it does a great job drilling. I was surprised at the range i can get....
/ Another Mini-Dozer #267
I looked at my sewing machine belted Craftsman yesterday. The slowest of the 8 speeds is 380 and the largest bit on the guide plaque is 9/16" in cast or medium carbon steel. Kind of a wussie machine to have come out of a machine shop.
/ Another Mini-Dozer #268
I guess it depends on what else they had in the machine shop. I'm tempted to keep my little drill press for the small jobs and for my sanding drums. Then I won't have to adjust my speed as much on the bigger drill press.
/ Another Mini-Dozer #269
Any updates Bob? Have you had a chance to try and solve any of the issues?
Chris
/ Another Mini-Dozer #270
Count me in loving your work! Very inspirational; good job!
Regarding the not being able to click back, try clicking a blank area on the webpage to go back. I'm not sure if this will work or not, but I like to use the backspace button to go back, and in order to do that, I have to click a blank area on the webpage; if I've clicked in the reply box or something, it'll think that the backspace command is for what I was typing. Maybe it's a similar case for the button.
/ Another Mini-Dozer #271
If you are on a PC, Alt+left arrow key is Go Back.
/ Another Mini-Dozer #273
mjncad,
"You know, you haven't your medical all-star here. Company doctors are like ship's doctors. Most are just one shuttle flight ahead of a malpractice suit." - Dr. Marian Lazarus
That's one of my favorite movies, have it on vhs, think I'll watch it tonight.
/ Another Mini-Dozer #274
mjncad,
Yep, I like it too, though I haven't seen it in ages.
Chris
I've ordered some parts but that's about it.
Last weekend was not a good one for me. You may remember that I wrote about my accident at work which left me disabled (page 12). Well, I had another incident where my ankle started bleeding and would not stop until I lost a couple pints ! It was just getting started in the photo below. I usually have to get down on the floor and raise my ankle above my heart in order to get it to stop. The garbage bag catches most of the blood. I will probably be inactive for a few weeks trying to regain my srength.
It will probably be after the holidays before I post again. So you all have a great holiday season ! :)
/ Another Mini-Dozer #277
Bob,
I am so sorry you've had another incident.
Please have a wonderful and Blessed (and healthy) Christmas and New Year's.
Be well sir.
David
/ Another Mini-Dozer #278
Bob,
Be well sir.
David
I will truly second this Bob. My deepest heart felt feelings for you. Take care and we will be waiting for your return.
Chris
/ Another Mini-Dozer #279
Hope you have a quick recovery.Take it easy and have a good Christmas and New Years.
/ Another Mini-Dozer #280
Dam Bob...that's a nasty bit of bad luck. Is that cellulitis in your left leg? Get well quick and do your best to have a good holiday season.
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A61567)
Challenger MT275B...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2021 Ditch Witch SK800 Mini Skid Steer (A61166)
2021 Ditch Witch...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
1989 Ford F600 Dump Truck, VIN # 1FDNK64P1KVA00407 (A61165)
1989 Ford F600...
