Heat Pump question...
   / Heat Pump question... #61
What is home warranty? It sounds like a homeowners association for appliances :confused2:
If you buy a house you can buy a warrenty for like 1 3 or 5 years. Unless you buy an older house with old systems and your not very handy there not a very good deal. Im thinking for my house when i bought it a few years ago it was going to be several thousand dollars. I tried to tell them that they would need to do better as i have all new applicances that i bought with the loan for the house as well as 2 new heat pumps. One old one remained but they way we have it worked we dont even use it and havent for 3.5 years. They said oh it covers everthing including your coffemaker and i think TV and water heater. The kicker is that there is like a $100 fee for calling them out. So your not gonna call on anything worth less than $100 ie coffe maker toaster etc. And if my older water heater goes out im going to replace it myself so it will only cost me a few hundred more than the call plus i did not have to pay out the huge lump sum ( and all my other major appliances were under manufacturer warrenty anyway). If the roof had minor leaks i would fix them to for minor cash. They really dont make sense like i said if you do your own work and you ahve new systems in the house. Again if your handy a leaky toilet is no big deal usually $20 in parts fixes it, but if you had to call a plumber the warrenty may be not so bad?
   / Heat Pump question... #62
In process, I've got a home warranty, so I must use them...
David
Well, if you have a warranty you did the right thing - wait until it breaks completely and let them replace it. If you actually owned it, you might have saved some money by calling for service before it died completely.
They tell me heat pumps rely on the skills of the installer. I firmly believe mine has been running trouble free for 17 years because I got bids, then went with the guy who impressed me as knowing what he was doing. He wasn't the low bid, but was reasonable, and did more work than the other contractors were proposing.
   / Heat Pump question... #63
Im thinking it should be 7-10 degrees warmer than the room air if its funtucioning correctly.
It should be much more than that, especially this time of year.
@ 30-40 outside, mine is 20-25 degrees warmer.
Down about 17-20 degrees outside, the air comming out is only about 10-11 degrees warmer. And any less than that, propane becomes more efficcent. If only 10degree warmer air is coming out, I can see the thing having to run non-stop and not make much headway
   / Heat Pump question... #64
A heat pump doesnt pump out hot air, it just graually warms the indoor air up a little at a time till its at the set point.
   / Heat Pump question... #65
It should still pump out well more than a 7-10 degree increase:confused2:
7-10 degrees is VERY poor when outside temps are above 30
My unit manages a 15 degree rise down to the low twenties ambient temp.
And is closer to 30-35 when outside temps are 40+.
At only a 7 degree temp rise on a 40+ day, something is very wrong. I'd almost wager a bet that resistance heat would give you more BTU's in the house for a less wattage draw
   / Heat Pump question... #66
the differential will vary depending on how cold it is outdoors. On a colder day it will be less than a warmer day. Not sure what the actual differentials will be, but will NOT feel like hot air blowing out of the ducts.
   / Heat Pump question... #67
I just checked mine. It's low 40's outside. Checking a vent within 3' of the furnace it is 13 degrees above the room air, but 15 above the basement air temp. Since it pulls from the basement some too I'll just say it was 15 degrees above air temp. The air feels very warm to me. I can't imagine it blowing air 35 degrees above room air temperature. That must feel like a blast furnace when it kicks on. That seems like it would be inefficient since it would be kicking on and then off so soon.
   / Heat Pump question... #68
I know all this. That is EXACTALLY why I gave outdoor temps as well. And what it "should be" at those temps.
Checking it as soon as, or close to as soon as it kicks on isnt accurate.
It takes it a few minutes to get everything warmed up. All that cold duct-work and all. But on an average 40's day outside, my return air is 68-70 degrees, and I am getting upper 80's to lower 90's comming out.
Lower twenties outside, same room temps, and I get lower 80's air comming out.
I had another thread last year and I am not trying to hi-jack this one, But I have been monitering my system for over a year now. Knowing the CFM of the blower, and temp rise, it is very easy to figure your BTU output. And easy to compare that to the wattage used by the heating system.:thumbsup:
And some hard #'s for ya. My HP draws 12 amps. I have a 1000CFM blower. That equates to 10900BTU/hr if the heat rise is only 10 degrees.
That same 12A if were used as resistive heat would have produced 9800BTU. So a 10 degree temp rise on my system only equates to 1.1x's more eff than resistive. And is actually the break even point for my propane B/U.
And even the 90 degree air I get out of my vents doesnt feel "hot". It is just warm. My propane gets 140+ easy.
Again, if you are only seeing 10 degree rises in temps, something is really wrong with the system, or it is really cold outside. Mine isnt even a newer unit. It is 15 years old and a 10seer:confused2:
   / Heat Pump question... #69
Forgot to mention, something else to check is how hot the copper "in" line is going to your furnace from the outdoor unit. On a 40 degree day, the freon going into the furnace is 130-140 degrees.:thumbsup:
   / Heat Pump question... #70
First of all, based on the most recent post you may have an issue. Have a pro look at it.
You should invest in a GOOD programmable thermostat. The upper end Honeywell units (IAQ, 8000) have "intelligent recovery". With this, when you set back, it will bring it the temp without the electric backup heat, and learn the time it takes to do it. It will then start the recovery early to meet your temp at the programmed time. You can also add an external temp sensor and use that to lock out the backup when you are above a preset temp outside.
paul
   / Heat Pump question... #71
The unit has a 10 year compressor warranty, but no one gets more than a 1 year installers warranty (at least that i know). Settings are probibly just not set right. asking it to run at too low of an outdoors temp.
My aux heat is a 95% efficient gas furnace so if it clicks on im not too worried.
Was thinking i had either 5 or 10 year labor warrenty. I know my neighbor has a Train. And i know he has a 7-10 yr warrenty. Thats the biggest piece of high priced junk there is. The guys come out to fix it twice a year at least. I think its had several switching valves and this latest time the heat would not work and the burner is burnt out on the gas backup and there ordering one to replace it under warrenty. This is at least the thrid time in 3+ years i have either seen or he told me that there was a problem with it!! Also said its there there more than that too.
   / Heat Pump question... #72
I checked this when it was in the 30's outside as i thiught my heat pump wasnt working right and i got something like 12 degrees maybe. Its been a few years and i cant remember. Id say its in the 50s now and there is no way i think id be 30 degrees warmer blowing out, thats almost like oil heat! But i havent used my HP yet this year, been heating with the wood stove alone.
Im thinking the reason is that i swapped thermostats with an older programable i got off ebay. It wasnt compatable with heatpumps if i remeber right and would not let the heat or something work so the heat wasnt working. I took it down and put the original tstat back up which even brought the whole register heat rise topic up with the contractor that put it in. I took the other t stat and put it at the farm and got rid of the old mercury one that would not allow me to cut the heat off when i closed up the hose for extended periods in the winter.
   / Heat Pump question... #73
Pics of proof.
41.8 outside
70.9 vent return TO furnace
92 out of vents.
The 92 degrees was taken about 4 minutes after it kicked on. To allow all the duct work to get up to temp:thumbsup:
Using my spreadsheet I made last year, this equates to 23018 BTU/hr with my system. With the amps it draws, it is 12.5cents per/10000btu compared to 26 for propane and 29 for electric resistance.
So 2.3x's more eff than electric and a little over 2x's more than resistance.
If you guys are only getting 10 degree rises, either you have a blower blowing WAY more cfm to result in lower vent temps, or you have something wrong.
And I mean actually checking it with a thermometer. NOT just feeling it and guessing it isnt very warm. Because I assure you that 92 degree blowing air does NOT feel hot.
Most likely low on freon and it has been running with poor efficiency for a while. Now the pressure is too low and not allowing the compressor to run. Your EM heat is a pretty simple setup and I don't see why it wouldn't work. I assume that you can select it from your thermostat?
BINGO!!! HVAC guy just left. he foud a loose connection on the pressure side and he added just over 5lbs freon.
This very well could fix the efficiency problems also. I will monitor it.
Home Owner warranty covers all the appliances and major systems. All I pay is a $100 co-pay. just like a warranty on a used car. costs me ~$500 per year.
David
   / Heat Pump question... #75
The guy who installed my system said 20 degrees of heating or cooling was appropriate. He took the temperature differential from the grill of the return air duct to the grill of a floor vent.
   / Heat Pump question... #76
Lets just say the room is 65 and the output is 85, your body's temp is 98.6, so it will still feel cold.
I have had the same issues with radiant floor tile heating in bathrooms. I get calls that the system isn't working. They have it set at 68 and complain that the tiles are cold. I show them with an amp meter that there working and try to explain that a 68 degree tile will feel cold to a 98 degree person. But just try to convince them to increase the Temp to 100F for the tiles.
There too cheap. They'll spend multiple hundreds of $$ to buy the mats, but wont actually use them to provide warmpth...
but again i digress. I have a tendency to go off course like a Chinese train.
   / Heat Pump question... #77
Just checked mine, have 5 year old 13 seer Janatrol system. Thermostat set at 69 degrees, 44.2 degrees outside, 87 degree air coming out of the vents. Have it serviced in the spring, heat strips will come on if I raise temp more than 2 degrees. My wife thinks it hot in the house, but I'm getting older (51) and 69 feels good to me.:D
Had fun reading this post.
Eddie
GRS,
What T-Stat do you recomend? My unit is like a 2007 unit, Carrier.
I would like more control over its performance.
Thanks in advance,
David
   / Heat Pump question... #79
GRS,
Thanks in advance,
David
Im not a HVAC contractor, but my system is a Honeywell vision PRO 8000 (TH8000) and works great. Has alot of programming feaqtures that the average guy (me) doesnt understand,. My installer set it up, but since he and i were friends, he walked me thru it :laughing:
Sorry :ashamed: Asleep at the keyboard.
Forgive me?
David
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
HOMEADE 8' X 22' TRI-AXLE TRAILER (A60430)
HOMEADE 8' X 22'...
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
2012 KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
2012 KOBELCO...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
