Another Mini-Dozer
/ Another Mini-Dozer #221
Hi Rawinok2,
I agree with Renze on this proposed modification. As shown, your dozer will be going about twice as fast as you have it now. You may be breaking keys or belts and if they don't break, you may be thrown off the back of the machine if the engine is powerful enough.
As I stated previously, changing the pulley on the motor to half its diameter will slow the speed down by half. Did you try that yet? You can put idlers in the center of the belt (top and bottom) if you have too much belt slop.
Changing to the smaller pulley would give you twice the torque at startup also.
Seems to me that all you need to do this would be a new pulley and possibly a new belt if you don't want to introduce the idlers to take up the slack.
Rick
/ Another Mini-Dozer #222
I may have missed it but what is the length or "wheelbase" of your tracks?
I would put the pulleys opposed to what you sketch in the pictures, when the big pulley drives the smaller one, the speed will increase...;)
OOPSY DAISY !! You are absolutely right ! :ashamed: As the kids say "MY BAD !!". (See new sketch.)
I'm not qualified to speak on the dozer project, but when I start a reply and want to change it (like to a multi-quote) I simply hit the "Back arrow" on my browser which SHOULD take you o the prior screen, and start all over. If the text I was writing was good, I copy it BEFORE going back.
Be well,
David
THANKS FOR THE HELP !!!
Hi Rawinok2,
I agree with Renze on this proposed modification. As shown, your dozer will be going about twice as fast as you have it now. You may be breaking keys or belts and if they don't break, you may be thrown off the back of the machine if the engine is powerful enough.As I stated previously, changing the pulley on the motor to half its diameter will slow the speed down by half. Did you try that yet? You can put idlers in the center of the belt (top and bottom) if you have too much belt slop.
Changing to the smaller pulley would give you twice the torque at startup also.Seems to me that all you need to do this would be a new pulley and possibly a new belt if you don't want to introduce the idlers to take up the slack. Rick
OK, but I am taking the advice of someone who stated earlier, that I should plan on Installing a hydraulic pump when I can afford one. Would the added shaft and pullies not be a good idea as long as I assemble it correctly as shown in sketch ?
/ Another Mini-Dozer #225
Thanks. Just trying to get a reference for overall machine size.
/ Another Mini-Dozer #226
Didn't you say earlier that you were building this from the struct corp plans?
If so did you deviate from them or is this just the way that their machine runs as well?
/ Another Mini-Dozer #227
Hi Rawinok2,
I suggested you go hydraulic when you can afford it, but I don't think your extra pulleys at this time would save anything in the future. When you go hydraulic, you would have the hydraulic pump mounted on the engine shaft and then hydraulic hoses running from the pump to two separate hydraulic motors that will have chain drives to sprockets attached to the final drives on your rear drive wheels. So I think you would be cutting some of your pulleys out to switch to hydraulics.
Speaking of drive wheels, I noticed you put drive sprockets on the front rear of your dozer. On dozers, usually the rears have the drive sprockets and the fronts have what look like idlers that run on top of the inside track. I believe it is done that way to reduce wear on the pins. Just curious why you did it that way even though it does look like you have four wheel drive. LOL
Bob, I hope you don't take my input the wrong way. I think your project is a beautiful piece of work and I've welded on many occasions over the past 30 years but I can't come close to the nice welding I've seen you have on your machine.
Keep up the good work!
Rick
Didn't you say earlier that you were building this from the struct corp plans? If so did you deviate from them or is this just the way that their machine runs as well ?
I think I mentioned on the first page or two that I used the Struck plans just for, what I refer to as, "the transmission". That would be the size and location of the pullies, belts, sprockets, chains, shafts, bearings etc. The frame, body and track were my design.
Hi Rawinok2,
I understand what you are saying but that is something I'd never do with this particular unit. If I ever can afford to build a hydraulically driven unit, I'd start from scratch. I figure if Struck's pulley driven units have worked for them the last 40+ years, then I shall get this one going tweak by tweak or else! :D The hydraulic pump that I was referring to would be a small one for operating the attachments (front and rear blades etc.). Then I could get rid of those lousy electric actuators! :)
I am not sure what you are talking about here. Do you, by any chance, have a photo of an example of this? I have attached a photo of the keyed rear drive sprocket as well as the free-wheeling front sprocket fitted with sleeve bearings. Hope this clears things up for you.
Bob, I hope you don't take my input the wrong way. I think your project is a beautiful piece of work and I've welded on many occasions over the past 30 years but I can't come close to the nice welding I've seen you have on your machine. Keep up the good work!
Rick I appreciate any and all critisism. One is never too old to learn.
I just read through this, nice build!
Thank You !
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
