JD 3x20 Wheel Spacers?
/ JD 3x20 Wheel Spacers? #41
Well..my spacers have been shipped...in that the bolts are not easy to check once the spacers are installed I'm thinking of using loctite when I torque the bolts to spec....thinking that even loctite red's bond can be broken with heat...can anyone think of a downside to this plan? Obviously I wouldn't loctite the wheel bolts (at least not with loctite red)
/ JD 3x20 Wheel Spacers? #42
Personally, I think loctite is a good idea. I'd also torque stripe the bolt heads (use a paint marker).
/ JD 3x20 Wheel Spacers? #43
Thanks....I've already torque striped the bolts on the wheels, etc etc (didn't know that what its called...and agree its a good idea.
I used the blue loctite when I torqued my spacers. Haven't had any loosen in over a year of use. Agree striping is a good idea but I didn't do it.
/ JD 3x20 Wheel Spacers? #45
Yup, I used a generous application of BLUE also, on every fastener, then torqued them about 5% higher than the manual called for. Have not had any problems, over a year, much heavy work accomplished since then.
/ JD 3x20 Wheel Spacers? #46
Like the idea of the spacers. Question though. I have a 375 backhoe on my 3720 and am wondering if spacing the rear wheels out will increase the forces around the tranny/axle housing in the rear and cause bigger problems or even breakage.
/ JD 3x20 Wheel Spacers? #47
That would be a possibility. The longer the axle, the more flex it'll have..and flexing metal is fatiguing metal.
Now, if you only install the backhoe when needed, I doubt you'd see too much increased wear and tear.
/ JD 3x20 Wheel Spacers? #48
Are you worried about the backhoe involvement with wheel spacers causing damage due to the weight it adds to the back? Or because of the forces when digging? Or interference with the tires? Or something else?
My 375 backhoe has been on my 3720 all summer working its butt off on many many projects. I am looking forward to finally getting the backhoe off and doing some other work. Mine has 4 inches of spacers per side. I don't feel the weight of carrying around the backhoe, nor when digging with it, is as significant as the forces when digging with the boxblade scarifiers in old crushed rock driveway.
My opinion.
/ JD 3x20 Wheel Spacers? #49
The 4" spacers arrived today....hopefully can find some time tomorrow to install them....I'm assuming the installation is obvious.if not I'm sure someone will set me straight..it appears as though the original lug nuts fasten the first spacer to the tractor, then one bolts the second spacer to the first and then one uses the supplied nuts to fasten the tires to the protruding bolts of the 2nd spacer.
/ JD 3x20 Wheel Spacers? #50
They should work well. A concern I had but others may not have on this forum, is that the original bolts when putting the first set of rings on don't go all the way through the hubs like I would expect. The original position is that the bolt thread takes up the whole thread in the hub, but the spacer is thicker than the original wheels. So I went to Napa and got some metric lug-bolts that are long enough to go through the hubs. I just didn't feel comfortable with only 3/4 of the thread in the hub. For whatever it's worth. Then I blue lock-tited everything up and has been good for a year with a lot of excavating with a 1500# block on the back.
Once it's on there is no way to check it anymore with a torque wrench but I take a visual on it quite often/
/ JD 3x20 Wheel Spacers? #51
I've voiced this before here, I'm not excited about spacers. Has anyone sent an inquiry to JD?
I have 475 BH and it's about 500# heavier than the 375 with a lot more digging power so I'm not sure I'd want spacers on it.
You have to understand the physics of it, each inch away from the hub adds a lot more force on the axle and bearings. 4" is a lot of distance and the stress on the axle and components could mean a shorter life. You may not see it in a couple of years but in time you might be asking for trouble.
Personally I don't find the 3x20 that tipsy. I was mowing on a hill and it got pretty steep according to my tilt guage and I didn't feel like it was near going over. I just hung on the handle and went slowly. I sent an email to Deere when I got my tractor and they said keep the wheels in the wide position. (valves on the inside) which I did.
A cab does add 500# to a 3000# tractor so you shouldn't dismiss it's affect on center of gravity but still i don't hear a lot about people going over.
The other thing is that I have limiting implements. My snow blower is 59" and spacers would create problems with it along with my 60" rototiller.
Just my 2 cents.
Rob
/ JD 3x20 Wheel Spacers? #52
Deere Dude
Thanks...that's the same concern I had...thanks for the confirmation!
/ JD 3x20 Wheel Spacers? #53
unverferth sent me the 6 inch spacers I returned them when I realized my tires would be wider then my buckett and my 60 " tiller and pulverizer I agree with the early poster. I flipped my tires have 300 lbs in wheel weights and 500 lbs ballast box I feel completly safe in the machine now.
/ JD 3x20 Wheel Spacers? #54
I flipped my wheels around before I got spacers but had terrible luck doing that. It seemed to me that the wheel was formed in such a way that there were half a dozen high spots around the hub and the high spots were the places that were seating onto the hub. When I took the wheels off to put spacers on I noticed that all of these high spots were ground to shiny metal from contact so it seemed the wheel wasn't seated by a nice flat backing. I thought flipping wheels might change the width, look and feel, but maybe only changed it 1-2" and that wasn't worth it IMO. Although different tires may have different wheels and some may end up wider, but mine sure didn't. Big R-4's.
Another problem I had flipping wheels was valve stem breakage. Pulling a box-blade through brush, light brush, the brush would bet jammed into the wheel and then between the rotating wheel and the axle. After changing two valve stems in 2 days and losing 30 gallons or so of RimGuard, spacers and the wheels with the original setup was in order. Never a problem since with a lot of brush and box-blading.
/ JD 3x20 Wheel Spacers? #55
It's more than just bolts. Deere uses grade 8.8 on compacts. Which equals a tensile strength of 800MPa or 800 N/mm^2 with a yield strength of 640 n/mm^2. This is approx. a grade 5 SAE bolt. So make sure your bolt has at least 3 dashes placed equally around the head. Persnally I'd use a grade 8 SAE bolt in this application. (5 dashes equally spaced around the head)
I'd also use blue locking compound torquing the bolts to Deere's specs.
Rob
/ JD 3x20 Wheel Spacers? #56
Grade 5's are fine. Grade 8's tend to be more brittle. The issue isn't likely to be failure of studs and bolts, it will be the increased bending moment on the axle if you are fully loading the tractor.
Having the rears wider than the bucket doesn't matter for most material handling but will if you are clearing a path. Same for tiller's and blowers.
I happen to have 4" of spacer on either side temporarily as I lift a lot of bulky equipment and move it around. The outside to outside distance is 67".
I will remove the spacers when I am done with what I am doing so that I can put the blower on. In the summer I am likely to leave one spacer on either side for loader work. I have a 6 foot fine cut flail and tiller so most of the time it doesn't matter if the rear is a little wider.
/ JD 3x20 Wheel Spacers? #57
Pictures of 8" of increased track:
/ JD 3x20 Wheel Spacers? #58
/ JD 3x20 Wheel Spacers? #59
It would be nice to have 4" of overall spacing. Too bad you can not buy 1/2 a set. I would not want 8" but 4" with the tires reversed adding a few more inches over factory ship. The only thing better would be to have the spacer very heavy to add ballast and space. I suppose two neighbors could split a set. Not everyone needs 8".
/ JD 3x20 Wheel Spacers? #60
Fuse, if you look at his pics a bit closer, you'll see he has two 2" spacers installed per side and his wheels are reversed (note the valve stems are inside).
Using one 2" spacer (per side) and reversing the wheel would result in about 4" per side (that is, 2" for the spacer and 2" for the reversed wheel), 8" overall.
Just using one 2" spacer, with those wheels set in the normal (valve stems out) position would give you and I the 4" extra we're looking for.
I'm sure Charley will respond to my question about where he bought the spacers and the cost.
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
Kubota Skid Steer Pallet Forks (A64047)
Kubota Skid Steer...
2009 KENWORTH T800 (INOPERABLE) (A63569)
2009 KENWORTH T800...
2006 GMC C5500 4X2 BUCKET TRUCK (A59910)
2006 GMC C5500 4X2...
2011 FORD F-150 (A63569)
2011 FORD F-150...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
