Chain Storage Ideas Wanted
/ Chain Storage Ideas Wanted #1
Scotty Dive
Ct
Yanmar 2020D
Looking for ingenious and or not so ingenuis ways to store about 25 foot of chain on the tractor. I have a small tool box on the fender that I use for a hammer etc. but cannot figure a good safe place for the chain....any ideas? Pictures?
/ Chain Storage Ideas Wanted #3
I haven't done it but a piece of 3 or 4" pvc pipe on the loader post with a drain hole in bottom cap and hose clamped to post.
tom
/ Chain Storage Ideas Wanted #4
On my pickup I used plastic newspaper roadside delivery box that was bolted in the vertical.
Those 'bins' are tough and well vented as well.
/ Chain Storage Ideas Wanted #5
I use a small horse bucket (black ...helps with evaporation) with several 3/4" holes in the bottom for water drainage. A 25ft chain just fills the bucket. Get a bucket with a flat side and it won't bounce around.
/ Chain Storage Ideas Wanted #6
I usually leave my box blade on all summer and i keep a 35' chain wrapped around two of the scarifiers, I have used the tractor with this setup all summer and it has worked well for me.........Craig
/ Chain Storage Ideas Wanted #7
I added golf bags to carry tools and chains. The photo below shows chain hooks peeking over the edge of the first bag.
I liked that so much that I added a kid-size golf bag strapped to the inside face of the right loader column. I carry the chains there now. (Two 12 ft chains).
With the bottom of the golf bags supported, neither bag has torn in the 5+ years since I installed them. (When they do, back to Goodwill for another $2.98 out-of-style bag :)).
Photo better showing the back golf bag
. Bow saw and pruner for the orchard; shovel, weed hoe, and mattock for irrigation reservoirs around new trees.
/ Chain Storage Ideas Wanted #8
My father and I have a pvc open pipe attached to loader support on our tractors. We just put chain inside pipe and hook on top and it works good.
/ Chain Storage Ideas Wanted #9
Cal, I am a cheap SOB as well, and would use that if I had ROPS on my tractor. Now if I need a chain, I drop the implement, grab one of the trailers, and use it to pack the chain to where I need it. Or use the 4wd pickup to get it there, and maybe use it to get the job done.
/ Chain Storage Ideas Wanted #10
The bracket up front for suitcase weights works well to store chain on or around for me. With weights attached, I just wrap it around the frame for the bracket, connect the ends together, and use a small bungee cord to ensure the grab hooks don't disconnect. On one machine, I have a plate welded on the bottom of the bracket, and it is deep enough to just carry a chain down in there. It's out of the way and clean.
/ Chain Storage Ideas Wanted #11
For me, sometimes the chain is just laying on floor in front of clutch pedal, but mostly I leave it wrapped around the forks on FEL
/ Chain Storage Ideas Wanted #12
... would use that if I had ROPS on my tractor. Now if I need a chain, I drop the implement, grab one of the trailers, and use it to pack the chain
I see the YM186D in your avatar. When I bought mine I was frustrated with the lack of space to carry stuff like I do on the YM240. At the minimum I need to stow my windbreaker as the morning warms up. I really should carry drinking water too.
For the YM186D I finally slung saddlebags off each side of the cowl, anchored from s-hooks hooked into the cowl next to the fuel cap. The lower end of each saddlebag is wired to whatever I could find low down.
The left side saddlebag (visible in this photo) is a tiny backpack like I've seen motorcyclists use, while the right one is an insulated bag (for a couple of 6-packs??) that has backpack straps.
A pair of childrens backpacks would work if you don't mind a Rainbow Bright or H. Montana motif on your tractor. :D
These saddlebags are sufficient to carry my jacket, gloves, pruning shears and folding pruning saw, and a half gallon of water, all of which are essential to get any work done.
As for chains - I have wrapped chains on the Quick Hitch which is nearly always on the YM186D. Some day I want to make a toolbox/chain carrier to go on the Quick Hitch. Sometimes I have hung a square plastic pail from the front edge of the QH (visible in the photo referenced above) to carry stuff. A more robust version of that would work for chains.
Rt side saddlebag:
/ Chain Storage Ideas Wanted #13
tom
I'll 2nd this idea, the only thing I did different was to just use a loop of wire at the top so it could be portable. When I need the chain somewhere else I just grab the wire{pvc with chain in it} and hang it where I need it.
Great ideas.....do you have a picture of the pvc pipe and wire? Have a hard time picturing that in my mind
/ Chain Storage Ideas Wanted #15
You might look at the loader frame mine had a hole alread put through at the right spot for mine.
/ Chain Storage Ideas Wanted #17
I was gonna say this to. Looking at Judds pic of him and his grand in the avatar pic i can see the bracket up there. Just wrap your chain back and forth around this in the style like they did on old 4x4s with the big bumper in the 70's 80's. I did this on mine with like 40ft of chain for weight before i changed the front bumper/weight i have up there. You can easily wrap way more than 20ft of chain on it.
/ Chain Storage Ideas Wanted #18
I just keep my 20 footer in my tool box behind the seat.
I pondered a real cool way to do it and after a lot of wasted time just gave in and did what came natural in the box it went. :D
http://www.tractorbynet.com/forums/...56d1306331638-odd-mods-img_1299-1024x768-.jpg
This is my fuel gage being shown in the pic btw. ;)
I was just about to say what? All i see is a tool box, but as the reply box was poping up i was thinking in my head what i saw in the pic and the rod came to mind and i got it!!! :laughing:
/ Chain Storage Ideas Wanted #19
/ Chain Storage Ideas Wanted #20
Sorry no picture, I just took a piece of PVC{4"} capped the bottom {drilled holes for drain} then at the top drilled 2 hole across from each other and fastened a loop of wire to it{could use rope also}. I then can hang it on what ever machine I am using or just hang it in the garage. The nice thing is that the hooks hang on the lip of the pvc so the chain never tangles and is kept neatly stored out of the way.
2011 KUBOTA KX121-3ST SUPER SERIES EXCAVATOR (A64279)
2011 KUBOTA...
UNUSED WOLVERINE FORK FRAME (A64281)
UNUSED WOLVERINE...
2022 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2022 ASV RT-25...
CRATE OF NEW PARTS (A64280)
CRATE OF NEW PARTS...
2018 INTERNATIONAL LT625 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 INTERNATIONAL...
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
