Wet brakes
/ Wet brakes #1
winston1
Super Member
gilmer tx
Bobcat CT235
Had a question come up on another Yanmar forum about wet brakes. Knowing there are a lot of curious folks out there I thought I might just post a couple of pictures of an 1802 and 2002 wet brake system.
/ Wet brakes #2
While your on the subject, have they ever come up with the boots that go on the rod into the brakes? When I was dealing in Yanmars that was an item that was a deal breaker when selling one of those models. They just were not to be found.
/ Wet brakes
Here it is, rather expensive and I have been there twice. Yanmar Tractor Parts: BRAKE ROD BOOT_
/ Wet brakes #4
Out of interest what does the boot do and where does it go? I have a F215 which has wet brakes and therefore I assume it also needs this boot.
/ Wet brakes
You have to look at all 3 drawings in post #1 to get the whole picture of where the boot goes. Looking at drawing 49 the boot slides over item 49-16. Looking at drawing 48 the boot slides over item 16. Looking at drawing 45 the boot is item 9 and held on by item 6. The entire brake disc area is lubricated with unpressurized hydraulic/transmission fluid. Best brakes I have ever had on a tractor. I have always been fearful of not being able to find parts. Googling part numbers only brings up the boot. I may have to drag a stick on the ground if anything interior gives way. :D
/ Wet brakes #6
I think moisture was the biggest enemy of the old dry brakes. They seemed to last forever. The wet brakes will probably outlast you if your over 10 years old. :2cents:
/ Wet brakes #7
My friend just the other day was talking about this and he has a 2620D I was not even aware of wet brakes that are that way on purpose and he swears he has them and they are leaking trany fluid so he is replacing the boot.
Hoye doesn't show his or mine as being that way in the parts list not saying one doesn't fit all I guess they would know.
Now I wonder if mine are the wet type maybe need to get my manual out unless someone knows? tia
/ Wet brakes #8
Don't worry, the 215 has no rubber booties !!!
/ Wet brakes #9
You say your's is like mine. No wet brakes. Just had my brake shoes re lined. $75.00
/ Wet brakes #10
Thanks! Yes they are so close sitting side by side especially with the 160 Koykers it would be hard to tell them apart!
I didn't have my tractor here when I posted that so last night when I got home I looked and I then was pretty sure they wernt after that going off Winstons diagrams.
/ Wet brakes #11
One other question concerning wet brakes.
I leave the handbrake on on my F215 tractor all through the winter when the tractor is not in use assuming that being wet brakes they cannot sieze on.
Is this assumption correct?
/ Wet brakes
Good question, I suppose fluid condition could weigh in on the answer. I don't lock mine during storage time but do on a regular basis while changing implements, etc. None of my manuals has any information on this. :confused:
/ Wet brakes #13
If it was my tractor, I would not keep the brake on, I would just block the wheel with a block of wood.
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2012 Jeep Compass SUV (A64194)
2012 Jeep Compass...
John Deere 185 Hydro Riding Tractor Mower (A66285)
John Deere 185...
2022 EZ-GO ELITE...
2013 CATERPILLAR 120M2 MOTOR GRADER (A63276)
2013 CATERPILLAR...
