Which 4.5 inch angle grinder to buy
/ Which 4.5 inch angle grinder to buy #11
Many pros use Metabos. Also I like Makita.
I want a metabo, they just cost too much. I am thinking I will just glue up the handle on the elcheepo, and use it with a wire wheel until it dies (I am kind of wondering how long the motor will last). The 7 inch can use a cut off, and the 5 inch can use a grinding wheel. When the motor dies in the elcheepo, I will replace it with a milwaukee or makita.
/ Which 4.5 inch angle grinder to buy #13
Well my backup angle grinder, a cheep old clarke strongarm, finally needs replacement. . . I am thinking either another makita, a milwaukee, a dewalt, or a bosch, which would be better, and which should I stay away from.
I have several, both 4.5" and 7": B&D Industrial, Craftsman, Makita, and two Milwaukees. All of them have served me well. The Craftsman is the oldest, probably close to 30 years old. (I believe it is a B&D, but not positive about that)
The Craftsman and Makita were bought new. The others were bought from a used tool salvage and surplus store where my cousin works. (I just can't pass up a bargain) :thumbsup:
I got my B&D industrial 7 inch for $45 at a pawn shop, and I dont thnik I will ever kill it.
/ Which 4.5 inch angle grinder to buy #15
Picked up an El Cheep O today at HF. Best 4.5" they have. The one with the paddle switch. $29.95. Only a 6 amp machine, I wanted 6.5 or 7+. In the next 2 or 3 weeks it will get a years worth of work. If it does not hold up, back it will go.
Stay tuned for the results.:laughing:
/ Which 4.5 inch angle grinder to buy #16
The last grinder I bought, a Dewalt, was about the most powerful (amps) they sold. It's a 13 amp 4 1/2" but it's a 7" or maybe even a 9" frame. It's a little bulky so if you want to get into tight places then you'll struggle but if you're going to be grinding lots of weld and don't want to wait every 15 minutes for the grinder to cool down then this will not let you down.
/ Which 4.5 inch angle grinder to buy #17
DO NOT BUY THE HARBOR FREIGHT PADDLE SWITCH. TOO MANY SHORT COMINGS.
No cam or lock of any kind on the back washer. Step on back washer too tall for it to tighten onto HF cut off disks. Have to add a worn out disk in order to tighten up a new one.
Power is just OK at best. Being as its sold as Heavy Duty, way to weak. It did pick up a little power after about an hour of use.
Only have about 2 hours on it, will give it some more tomorrow. But a very good chance it is going back, and be replaced with something better.
/ Which 4.5 inch angle grinder to buy #18
I was a rent a slave to a General contractor for 3 years on a tuckpointing and resealing project ( 1 building, lots of scaffolding and lots of time and material labor). Burnt up 3 milwaukees, 2 porter cables, and 2 dewalt 4.5 grinders. I bought 2 new Makitas at the start of the last year of the project, and they are both still around. I have used them to build 3 trailers, (1 tilt 20' bed car trailer, one 13' flat deck, and one frame to mount a box truck box on) a massive logsplitter, and several other repairs as needed. The one Makita shuts down if you push it too hard, so you don't burn up the motor.
/ Which 4.5 inch angle grinder to buy #19
That's the spirit, fix up the old one.:thumbsup: I have thought about replacing tools numerous times, until I priced a new one. I have been teased beyond telling about fixin' old tools instead of replacing.:laughing: I take a lot of them to work and get harassed by all my mechanic coworkers.
hugs, Brandi
/ Which 4.5 inch angle grinder to buy #20
My old power tools are my good ones! The ones I have bought in the last 10 years or so have seemed pretty unimpressive except for some of the newer millwakie cordless stuff. While I was in Oregon last winter I found a lot of good used stuff for cheap on Craigslist for setting things up there, name brand stuff in great shape for about the same price and less than harbor freight.
Rick
Oh yea this is about grinders, got a 20 something yr old millwakie, couple sets of brushes, new cord, and new switch and still going strong, have killed a sears, dewalt, and almost done in a makita during that same time.
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
(INOP) 2014 FORD TAURUS (A59823)
(INOP) 2014 FORD...
HYDRAULIC TANK WITH COOLING SYSTEM (A60736)
HYDRAULIC TANK...
