Buying Advice Mule ATV
/ Mule ATV #1
jfd
I am a sheep farmer and am looking to buy a good diesel powered mule. Sometimes I have to pull a half tonne trailer uphill, so a reasonably powerful engine is necessary. I also want to be protected from the weather because it can be cold in winter.
Any suggestions based on experience?
/ Mule ATV #2
Sounds like a Kubota RTV1100 would satisfiy your need. The 1100 includes AC/heat, will pull your weight but it comes at a price, new you are looking at around 18K. I use an RTV900, no heat and picked mine up used off of a C list posting for 8K.
/ Mule ATV #3
You can also go with the Polaris Ranger Diesel. They are about 13k and have a $1000.00 rebate or 2.99% financing at the moment. I think they are powered by a Yanmar diesel engine.
2012 Polaris RANGER Diesel UTV : Overview
/ Mule ATV #4
or a gas burner Ranger if you are only going to tow 1000 lbs. Plenty or power for that.
/ Mule ATV
Leaving aside the air conditioning and heater, is there any difference between the 1100 and 900?
/ Mule ATV #6
1100 includes the factory cab, a little more HP and I think the cab is pre-wired for a stereo. I didn't look at the 1100 real close because of the cost. I can live without the AC.
/ Mule ATV #7
/ Mule ATV #8
Get a john Deere 855D gator great workhorse.
/ Mule ATV #9
I believe most of the side x sides will tow 1,000 pounds and can be fitted with a enclosure....for a lot less than $18,000.If it doesn't have to be diesel there are a lot of options.
/ Mule ATV #10
In the diesel debate, I often find myself wondering why professional lawn care folks don't use many of them? They sure put enough hours on them, but you see many more big gasoline powered Z turn mowers than diesel. I have both, and like both, and having put 1500 hours on an air cooled splash, and paddle Briggs garden tractor, and having gotten a very good trade in price for it I'm not sure I understand. Perhaps if you are going to be doing a lot of towing with it the diesel would be a much better choice. Most of them are a bit too wide for use on many o my trails so I may never find out. :(
/ Mule ATV #11
I own a ArticCat Prowler 650,1000lbs isnt anything behind the larger sideXsides
/ Mule ATV #12
We really like our Rhino, but for real work the farmers around here go with the Polaris and Kawasaki Mule. Kubotas are great and drool over the cab model every time we go to the dealer, but the price is a real killer.
/ Mule ATV #14
I run a 3010 Diesel with a 120 gallon spray tank and a big boom system. I can tell you they are an awesome machine. I looked at all the brands and cannot come up with any negative on the Mule for a machine made to work. Some other rtvs are made for play, go fast, ride like a car. But for real work, the Mule is a stud.
/ Mule ATV #15
Years ago I was painting towers at a ski area. They had a mule (gas), I'm not sure what model. They let me use it to bring painting equipment up the hill. Until then I was an ATV guy but that thing impressed me. I ended up with a Honda because of price otherwise the Mule was the most likely option. I wanted a SxS that load it and a trailer with firewood.
Around here the Kubotas RTVs are used by contractors doing road work. They often are moving light towers and e-signs around or hauling fuel to fill them up. But I can't remember seeing one owned by a farm or homeowner around here. I think they are just too work oriented. The mule is a great balance between work and play in my eyes.
I don't think I would go with a diesel. The nice thing about these over a small pickup is weight. The gas engines have more than enough power and they start well in all conditions. You would have to put a lot of hours on one to break even on the cost.
/ Mule ATV #16
I love those tires and wheels.:thumbsup:
Buckshot 15x7 wheels
SuperSwamper TSL 29/9.50-15 tires
They should last the life of the Prowler:D Total cost$800 "new"
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
Hydraulic Stump Grinder Mini Skid Steer Attachment (A61572)
Hydraulic Stump...
Bush Hog 3715 Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Bush Hog 3715...
RAIN FLO 1200 WATER WHEEL TRANSPLANTER (A63291)
RAIN FLO 1200...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
