Buying Advice L3800 or MX4700 or MX5100?
/ L3800 or MX4700 or MX5100?
Yep, what seems like common sense to some may be totally the opposite for some people I guess. Sometimes it amazes how different people think about things.
Chris
/ L3800 or MX4700 or MX5100? #82
Forget the big bucket and wheel weights in my opinion. The big bucket will make it harder to move around and get in and out of places. Then the wheel weights won't be necessary but filled tires are still a must with loader work (add rear ballast to the 3PH if needed).
The heavier bucket w/load will put more strain on your tractor and the very heavy rear tires with wheel weights will do the same. If you get in soft ground you'll be up to the floorboards in no time.
I'm still trying to visualize your needs as related to an RV park and surrounding acreage. The Grand L looks to be the right fit. There won't be a "trade up" thought because you'll already be there. There is nothing worse than "tractor envy" (well :D).
If you are grading and/or using a rear snowplow regularly the T & T will make your life a joy. Repeatedly getting on and off the tractor sounds fine now but eventually you'll get to the "close enough" or "settle" point and the implement will not do its job correctly. With a T & T you can make adjustments on the fly and readjust as necessary. That screw-type top link needs a lot of adjusting - even just for hooking up an implement.
$30K is a hefty budget. As others have said, invest in the tractor and scrounge for the implements. However, you will be surprised how well implements hold their value if well-maintained so there won't be many great deals out there on quality.
The same applies to something you buy, use, and decide to sell when its usefulness is done. Implements depreciate very little if they look good.
Hey guys,
Still searching around for both new and used, and the question of the day today is deciding between a new L3540 equipped like this:
- Rear Work Light Kit
- 3 Sets of Rear Wheel Weights
- Deluxe Fiberglass Canopy with Front Work Lights
- LA724 Front Loader
- Quick Coupler for Loader
- 72" Two Lever QA Bucket
Retail is $29,119.00 on Kubota.com and with the LandPride GS1572 Grading Scraper, the best price I've received is $27,004 plus tax, making it roughly $29,000 total.
Or, do I buy a used 2004 L4630 with the LA854 bucket, no HST+, but does have HST, but it also has 3 Rear remotes and a hydraulic box blade included for around $22K with 650'ish hours on it?
I like the idea of the bigger 4630, especially with the rear hydraulics, but it's also going on 8 years old too. The box blade, although sweet with all the on the fly adjustment, from what I can tell I'd probably still buy a grading scraper to do the majority of the road maintenance we have.
Not to throw another wrench in all this, but tomorrow I'm going to set a L3800 next to the L3540, both equipped with the standard buckets, drive them both, compares apples to apples, check the 3 point hitch operation on the L3800 to see if it's jerky, and try to make sure I'm not getting caught up with getting too much tractor, both size wise and/or price/feature wise too.
Anybody have any thoughts on any of this? :) I really appreciate everyone's help to say the least. This has been extremely eye opening and informational, to say the least.
Chris
/ L3800 or MX4700 or MX5100? #84
Only you can decide now... you have the information that you need to buy the right one for YOU. Just wanted to say that 700 hours is not many hours for 8 years. Don't forget to let us know what you get :D
Yeah, does that deal on the used 4630 seem like a good deal, great deal, or okay deal? Is there somewhere that you can price used tractors like NADA or KBB for cars to get a rough idea, by chance?
Chris
/ L3800 or MX4700 or MX5100? #86
Chris
Need to see it... is it clean and looks like it's taken care of? You can look at Tractorhouse.com to see what others LIST for (not sell for). Sounds good from here tho... ;)
/ L3800 or MX4700 or MX5100? #87
Hey guys,
Chris
The bigger loader on the 4630 would be a real asset plus the extra HP. I would consider it or strongly consider the larger L**40 with the heavier loader. Wheel weights and or 3pt weights are a must for any kind of loader work
/ L3800 or MX4700 or MX5100? #88
/ L3800 or MX4700 or MX5100? #89
When I bought my 2003 L5030 HSTC, last year, it had 735 hours and I don't consider that many hours at all. It was at the dealer where the guy bought it as he had it brought in to have it serviced and a new L57340 caught his eye.
A used tractor in really good condition is often pretty hard to find.
I really like my non HST+ 5030 and as I said previously can live without the HST+, I am very happy with it; spent the morning on it and will be on it again later this afternoon.
I didn't buy it because I couldn't afford a new one, it was just too good of a deal to pass up and thankfully so as we had to buy a new M8540 later that year.:(
As mentioned, only you can decide and it looks as though you are going about it pretty much like everyone else has. Trying the 3540 and 3800 together will tell you a lot and driving the 4630 will also.
Good luck and keep us informed.
Triple R, since you've purchased a L5030 recently, I'm curious if you think 3000 hours is too much for that tractor if it has been used for mowing? No front end loader on the machine. Oh, and it's a 2006 model. Any chance you would mind sharing what you paid for your 2003 with 735 hours on it? Do you know if it's even possible to get a Kubota Loader for it still?
Also, is there a normal amount or reasonable amount guys sell for versus what they list them for on these things?
Chris
I appreciate the response. For someone that may only put around 100-200 hours on that tractor, do you think that would be an issue? Lots of maintenance needed on something like that? What if it was around $16K'ish? Would any of that matter? I mean, I don't want to be servicing the heck out of it, that's for sure, so would it still be reliable with that many hours?
Chris
/ L3800 or MX4700 or MX5100? #92
Now you're starting to get into how much will a used tractor cost me. 3000 hours is going to be at the point where you may start having to replace parts due to wear. If you're handy and can live without your tractor then it shouldn't be an issue, if not then it may end up costing you.
Equipment dealers usually say that an hour translates to about 40 miles. That would mean a 3000 hour tractor would be equal to a truck with 120k miles on it.
/ L3800 or MX4700 or MX5100? #93
I agree with the crazy guy. 3000 hrs. is a long time. By that time it is well broken in. But it is a tractor after all.
You'll start seeing things that are worn out. Fuel injectors for instance. Tires are likely gone. Joints and pins are probably well worn - functional but loose. If you can live with that then go for it.
You might want to have a dealer give it a once over before purchase to estimate what it would cost to get it in A-1 shape. It will probably be in the neighborhood of $4000.
IF it was well serviced the power train should be OK but there is always a question without having the detailed records. Sometime during the 3000 hrs. it is likely that something has been abused.
There will almost certainly be several things that come up as you use it. One day this, another day that. My old Allis-Chalmers WD40 was that way. Twenty minutes to get it started, an hour of operation, and a half hour of repair.
After driving around the new one, then go see the old one. Plunking down the cash will make it hard to undo your choice. It more similar to a truck purchase than buying something from Walmart.
/ L3800 or MX4700 or MX5100? #94
Chris
It all depends on how it was taken care of and maintained. If it was serviced exactly how it should be and never abused it isn't crazy to think you could get another 3000hrs out of it before having to replace a thing. A lot of tractors will go to 10,000hrs before a major overhaul. There are some items like belts, hoses and the occasional seal that go bad with age, but a lot of that isn't related to the amount of hours. IF you are mechanically inclined and the tractor is in great shape it may be something to consider.
/ L3800 or MX4700 or MX5100? #95
When you test that 3pt on the L3800 try to get an implement on the back if at all possible. boom pole would be great, but box blade or rotary cutter would work ok too. Now if possible set the brake and get off and stand on the right side of the tractor next to the RR wheel and use your right hand to raise the 3pt as slowly as you possibly can while watching the implement. Do not raise it all at once, or let the dealer do it. That proves nothing. They all raise smoothly if the handle is pulled up all at once, they may be one little jerk at the end of its travel. This is not the problem nor is the lowering, They all lower as slowly as you want and as smooth as silk. The problem is trying to move the position control lever, slowly. If you try to move it slowly and continuously it will jump up with multiple jerks. See Chilly807 video. It is typical for the group. If you can raise it slowly without bouncing the heck out of the tractor. Then buy it. It is an excellent tractor and will serve you very very well. and is reasonably priced under 20K with loader, and maybe even a blade thrown in. Be sure to get hydro and cruise control if at all possible and be sure to get SSQA on the front bucket..Remotes can be added by others. both rear and front. If you can get it fixed like the thread started by jokergerm (search for them) then be happy and buy it but dont hold your breath on getting it fixed.. he is the only one that I know that had a good experience like that.. Please report back what you find. We have heard a few stories that some of the L3800's dont have the problem, yet we are not sure. and we have asked some new owners and have gotten conflicting results. We would very much like to hear what you have to say about this. Thanks
James K0UA
/ L3800 or MX4700 or MX5100? #96
[/ATTACH][/ATTACH][/ATTACH]
/ L3800 or MX4700 or MX5100? #97
Chris
I pretty much agree with what the others have said. I am in my 60's and frankly tired of working on tractors/cars/trucks/motorcycles, so while I use to think nothing of driving a car/truck/tractor etc. into the ground and dropping another motor etc. and keep going, I will be trading when things start going wrong.
If you are comfortable doing a little work on one then the 3000 hour tractor will be worth it, I know my brother would jump all over it.
At only hundred hours per year, it is going to take a long time to wear it out, so if it is in good shape now it still will be ten years from now or more.
My only caveat is have someone knowledgeable check it out. I think I know a little bit about tractors, but still have my brother who is a mechanic check one out for me. Over the years, we have gotten some pretty good buys.
K, thanks guys. I wonder if the dealer would let me video the two tractors side x side today to help some others out that are in my same shoes? :)
Chris
/ L3800 or MX4700 or MX5100? #99
I think I would be a little nervous to buy a 3000 hr machine. It depends on how they were used. Some machines run 18 hrs a day and some run 5 hrs a day at 10 minute intervals. I know any of my kubotas will not run 3000 hrs because of the way they get used and I do not abuse them. They just get used for short periods often. I'll bet every hour clocked has 3 or 4 starts in it. All this will wear a machine faster than a long steady day running.
Yeah I'm leaning away from it at this point. I'll keep everyone posted on what I discover today between the 3800 and 3540.
Chris
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
Rockport Mobile Command Center (A59230)
Rockport Mobile...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A59228)
2014 Jacobsen AR3...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
