Buying Advice L3800 or MX4700 or MX5100?
   / L3800 or MX4700 or MX5100? #21
One thing to think about, if you spend all your money on HP... you will still need to buy implements!!! I've spent about 1/3 the price of the tractor for USED implements. The bigger the tractor the bigger $$$ the implements. :) Just to let you know that buying the tractor is the "tip of the Iceberg"
   / L3800 or MX4700 or MX5100? #22
Very true. Once you get up into the MX and M series the stuff from TSC or other short line mfg's just won't hold up. Your looking at either high quality category I or category II implements, and therefore much more $$$.
The attachments are what do the work, they are really what determines the success of your job. Even a small tractor with the right specialty implement can often do a job much quicker than a big tractor just trying to use brute force. We used to clear brush with nothing but a big loader tractor with a standard bucket. It worked ok, but a small tractor with a tooth bucket and a grapple is much quicker, cleaner and more efficient. Same thing with gravel roads. For years we just used a 65hp JD with an 8' rear blade. It did the job but not very precise, and real easy to make a mess with if you aren't careful. Now I use my little Kubota with a combination of a box blade, loader and landscape rake and can fix about any drainage/driveway problem that comes along. I might even look into one of those new grading scrapers to further increase efficiency.
To the OP, I hope all that everyone is suggesting doesn't confuse you even more. But there are a lot of things to consider when looking for equipment, things that can only be found through experience. Once you decide approximately what size tractor you are looking for, go look at one of each (even if your local dealer doesn't have one in stock). Sometimes just seeing each model in person can help determine if it is/isn't the right model for your tasks.
   / L3800 or MX4700 or MX5100? #23
You can get an 2011 ,L3800dt 4wd with ldr,5'box blade&5'shredder for $17,150 and get just tractor 2011, MX 5100f 2wd with ldr for $19,300.I have the 2011, M5040 4wd,ldr $26,900 some really big price jumps,witch ever you deside I think you will be happy!:thumbsup:
   / L3800 or MX4700 or MX5100? #24
You can almsot never go wrong by buying a little bigger than you think you need. I made that mistake .. Bought a 28HP compact and replaced it within the first year with a MX5100. I really like that new tractor tractor. I larger tractor in most cases is more smoother riding and comfortable to sit and work in.
Finding the "right" size can be difficult. I agree with Stan about going a bit bigger than you think, BUT, up to a point. Larger tractors give you more loader lift but decrease in maneuverability as the size increases. I use my "little" Kubota more than the big one just for that reason.
   / L3800 or MX4700 or MX5100? #25
The M series may be overkill but since it's a RV park he may need to move trailers around. Some of the RV parks I've been to have had land "out back" that they would store trailers there for cheap and they would move them for you. Kind of nice leaving that gas guzzling truck at home if you have a distance to drive and don't plan on staying at the park.
I like using my tractor over my truck for moving trailers. You can see the hitch so connecting it up is easy and it turns much tighter so it's easy to move them around. Just food for thought.
   / L3800 or MX4700 or MX5100? #26
I think for the uses you described, the L3200/L3800 would be perfect but as others said, the problem with the jerky thee point hitch would probably frustrate you to no end with your intended uses. That being the case, I'd go with the L3240 or L4400. Both should be more than capable of doing the jobs you outlined. The L3240 has probably just the right amount of hp for what you want in a slightly bigger frame and is much heavier than the L3800. It also has lots of nice features (HST+ transmission, great 3ph, tilt steering wheel, flat operators platform, cruise control, integrated FEL controls). The GL40s are definitely the "Cadillacs" of Kubota's lineup. Here's a good overview of them:
An Overview of Kubota痴 Grand L40 Series | OrangeTractorTalks
The L4400 has a slightly bigger frame than the L3240, 10 more hp, and weighs about the same without all the bells and whistles.
If you're a numbers kind of guy like I am, check out the specifications for the tractors on kubota's website:
http://kubota.com/product/L40/pdf/gl40_spec.pdf
http://kubota.com/product/L2800/pdf/l_series_spec.pdf
The bolt on cutting edge is great but probably something that most people could do without if you want to save some money. The guy I buy soil and bark dust from has one on his L4240 because he is scraping material off asphalt all day. That's the kind of use I think of where you would really need one. I would probably say the same thing about the HD bucket. Of course it just depends on your intended uses.
I second the grading scraper idea. Both Landpride and Woods make nice ones. I love mine. Worth every penny. I still would like to have a nice rear blade for ditches and scraping gravel back onto the road though.
Also, don't forget ballast in the tires. Rimguard is good stuff. It's made from beet juice so it's non-corrosive and safe for the environment (i.e. it won't kill grass) if you do happen to get a leak.
   / L3800 or MX4700 or MX5100? #27
The reason you are getting so much different advice, all excellent, is that you truly can do just about everything you mentioned with just about anything from a BX to an M. I did much of that for years with an old Ford NAA, but no FEL then with a BX2200.
We now have a BX2660, L5030HSTC and M8540HDC as our primary tractors and either "would" work, but one would be better overall.
I believe anything from one of the bigger B Series, my preference is the 3030 or 3000 due to position control and added features, any L/GL or MX will do all you ask. Only you can decide which is "ideal" for you.
I gave up on the one tractor concept, but for most of my life one and well used at that, was all I could afford and the "mid size" tractor seemed to fit the bill best for me.
As mentioned read a lot on here, go look at some tractors and drive all they will allow you to and I would even consider renting a tractor for a day or two to get a baseline for comparison.
One other thing, as a new tractor owner/operator, it is easy to be intimidated by size. I well remember how I felt stepping off of my NAA and onto a MF 375 then later into a cabbed unit and I grew up on tractors. Tractors tend to "shrink" with use and what may have felt really big on the lot doesn't seem very big after some time in the field etc.
Take your time and good luck.
You guys are great. I really appreciate all the help. So, if I understand correctly, all models of the grand L series are larger in size and heavier than the L3200/3800, correct? Plus, they have many more features, but for me I have no idea what all the options and features even mean...lol. When I go to spec one out, I have no idea what options to put on them.
Chris
   / L3800 or MX4700 or MX5100? #29
Great advice from all of the previous posters.
From your original post it seems like you will have a lot of grading and loader work. A tractor with a HST fits those need very well and will make those jobs much easier.
You may not want something TOO big since an RV park has tight areas, electrical outlets, and things shallow underground like water and sewage lines. A big heavy tractor could be a negative in those locations. Consider what tires you might want if there are large lawn areas. R1 tires will tear lawn to shreds.
You never mentioned you budget but, as a business, the costs can be written off with depreciation eventually.
My contribution to the discussion was mentioned before - a rear Top and Tilt kit. That will require at least two rear remotes but my advice is to get as many as you can or can afford.
Landpride makes quality equipment in my experience so get what you need now with the finance deal. Forget the extended warranty.
Like TripleR, my multiple tractors are a major convenience but unnecessary in your case. When I had a single tractor it was a L3650. Did fairly big jobs and small ones as well with ease. Something in that size range is very versatile.
The L3650 had a HD bucket but it wasn't a big factor over the standard duty bucket. You'd have to be using it in a gravel business as a dedicated loader filling trucks daily to notice wear. The regular duty is just fine.
The QA FEL allows use of different attachments/implements on the front. Forks and a boom might come in handy at your place as they do at mine.
If I was doing your jobs and could only have one tractor it would be something in the Grand L category. Every time you climb on it there will be a silly grin on your face and you'll be looking for work to do.
   / L3800 or MX4700 or MX5100? #30
We can blow your mind... if money is no object, and we are spending *your* money.
My ideal tractor (Regardless of HP but with implements that are sized correctly the for the tractor) would have:
First would have to be Front End Loader (duh)
Grapple and the hydraulics to run them.
Hydraulic top link and side link for three point hitch.
Couple extra remotes.
A backhoe.
Tooth bar.
Don't forget to save money for the normal run of the mill implements:
Box Blade WITH gauge wheels.
Rear Scape blade WITH gauge wheels.
Mowers, finish and bush hog.
Chipper.
Landscape rake.
...and the list goes on and on. What I'm getting at is don't blow the whole budget on the tractor. Take your time, read, and try and figure out what you'll need. Most of the campgrounds we stay at usually have an old beater tractor, not the high dollar ones.
When Fall comes, you might need this contraption for leaves...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
STORAGE FEES (A51222)
