Well pump light
/ Well pump light #12
I would go one side of the 240 to neutral, but here's another option. Two 120v bulbs in series would work on 240v. Of course when one lamp blows out they both stop working.
/ Well pump light #13
You can use a 120 v bulb on a 240 v pump. Just wire to one switched hot leg and the other side of the bulb to ground. Try to find a neon indicator light, since it is very low power and will last many, many years.
paul
Or just wire across both hot legs through a pair of light bulbs in series.
/ Well pump light #14
I wouldn't recommend putting 120V on bell wire nor on CAT5 cable. Although the wire could carry the current for an LED, the insulation isn't rated for 120VAC.
Moreover, if someone is doing maintenance at the house, they would assume such wire only carried low voltage or a signal, not 120VAC. That could be dangerous.
CAT5 probably would be a mistake but you can buy phone line rated for 300V. I can't say if it's still the case but used to be ringing voltage was 90V. I've been on the end of an incoming call.:shocked:
It would be best to label the light including the voltage.
/ Well pump light #15
Why not plain old wet location 12/2? Cheap, and nobody is going to mistake it for low voltage.
/ Well pump light #16
Yes, 12/2 UF or NC would be ideal. I believe LarryD was suggesting the light gauge wire because it is cheaper and easier to run.
However, I still believe that it is a bad idea and violates code to use light gauge wires with 120VAC on them. The breaker protecting the pump is also protecting all of the wiring to the pump and beyond. If the wire is not heavy enough to carry the amperage listed for that breaker, the wire could overheat without tripping the breaker. That could cause a fire, and that is why it violates code.
LarryD is correct in knowing that the light gauge wire would easily carry the tiny current for an LED. The problem is that if something went wrong and the wires got semi-shorted together somehow, then they could be carrying enough current to cause them to overheat without tripping the breaker.
On the other hand, I personally think that bell wire would probably just burn in two before it would cause a fire. Nevertheless, I wouldn't do it.
The only safe way to use light gauge bell wire would be to install a transformer (like a cell phone charger) next to the pump switch, and then run light gauge wires under low voltage to a low-voltage LED or lamp.
/ Well pump light #17
Jim, his tank is in the crawl space under his house. I do the same as you and just check the pumphouse guage every so often, but that's easy.
Larry, you don't have to check the tank gage. You can put a pressure gage in the cold water line under your kitchen sink; no wires - no worry. Remember, pressure is the same thoughout the system. If you want to watch your pressure and see if it is dropping, just open the door under the kitchen sink and look at the gage. If you have a leaking tank checkvalve or a leaky toilet, that gage will tell you as quickly as a light and require no wiring of any kind.
/ Well pump light #18
Obviously you haven't looked under the sink in my kitchen Jim! :D
A convenient pressure guage would certainly show a leak worth chasing in an hour or so's time. Could even check it before bed and then again in the morning. On second thought, my wife gets up several times a night, that won't work here.:confused:
And for something a little more attention getting, how about a Horn/Strobe used for fire panels. 85db in the middle of the night should alert you to a leak!:eek:
/ Well pump light #19
Different application, but would work for the OP.
At my camp during the winter, I put a "Christmas candle" in the window plugged into a temperature sensor. The light turns on if the temperature drops below 50 degrees F. Neighbors look for the light in the window and call me if they see it, to let me know the furnace is not running.
Cheap, readily available, bright enough to see but not so bright it's annoying. You could cut the plug off the wire and hardwire into one leg of the 240V pump circuit, other wire to ground.
/ Well pump light #20
Well, there are lots of places for a gage besides under the sink behind your "collection" of stuff. The inlet line to the water heater is another example of a great location. A simple "T" inline with a gage could just as easily be replaced with a low cost pressure switch just like the one on the pump. You can install it anywhere there is a pipe and use it's contacts for a low voltage circuit to drive a signaling LED or something similar if you have to have that irritating light.;):laughing: You don't have to go using the one that powers your pump. The pressure cycles throughout your plumbing and an auxiliary Square D pressure switch will run your light just as well as it runs the pump and you won't have to run a bunch of wiring nor get involved with 110/220 vac. You can make this complex or simple is my point. Simple is always my choice.:D
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
10 Safety Systems Barricades (A59317)
10 Safety Systems...
Pallet of Vehicle Seats (A59317)
Pallet of Vehicle...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2025 AGT Industrial MX-MRT14 (A60463)
2025 AGT...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
