New DK45SEHST owner
/ New DK45SEHST owner #1
RJJR
Gold Member
NC
2011 Kioti DK45 HST
OK, I bit the bullet today, ignored the huge swarm of butterflies in my stomach, all the posts about the squealing HST transmissions and purchased a DK45HST. The final straw was seeing owners like TNEWBERN and others be willing to reccomend the tractor in spite of their problems. You are a very persuasive crowd. Also, I felt like it was a good tractor and a good deal that I hated to miss. So I'm taking the plunge. I paid $20,500 which seems like a good deal based on the feedback here. It came on the dealers yard in March just before the price increase which is why it is somewhat lower. In fact it was $500 better than he'd sell me a new DK40HST so I had to go for it. Thanks to everyone that responded to my posts over the last few weeks on the forumn and by PM.
So here is where I am today. It comes with the 401 loader. I have access to a Massey and 7 foot bush hog so I bought a 72" roto tiller to have as ballast for the loader. It's about 800 lbs but the tiller will not be ready for 30 days so I have time to consider the following:
Is that going to be enough weight or do I need to consider another approach? Dealer wants $900 for the plumbing needed to run 4N1 or grapple. Is that fair?
He offered a water/antifreeze mix for $150 on back tires only. Pros or cons?
$600 for 2nd set of rear remotes? What would I use these for? I've got access to a box blade so I doubt I'll ever run a hydraulic blade?
Thanks again for everyones help. It'll be a loooong month before I can post pics. Looking forward to joining the Pack!
RJ
/ New DK45SEHST owner #3
RJ
Seems like a great price from what Ive seen. I have a DK45 cab HST myself, and LOVE it. More so every time i use it.
I had my rear tires filled with rimguard and i can lift whatever i can fill my bucket with without an issue. I even have a loader mounted snowblower that i lift without issue. I move a 30' gooseneck horse trailer with something like 1800-1900 pounds of weight, and don't need a ballast box. Love that rimguard.
The extra rear remote is great if you ever want to run a snowblower. the included remote has a detente ball which sucks for things like snowblowers, as they stick. but you need the detente if you ever want to run items like a rear mount log splitter.
I had my guy run a front set of hoses to the 2nd rear remote so i can operate the snow blade with the 2nd remote instead of the 3rd valve.
This hose only cost $450.00, and i added a mid set of quick connects for ease of loader removal. My guy wanted $1000 for the 3rd valve to rin front items. It cost $400 for 2nd rear remote. I rather would pay him to do it then for me to do it, seamed like alot of work.
oh...also, have your dealer run a loop of hose on the rear couplers (remotes) to prevent deadheading the hydraulic pump if the detent valve is accidentally engaged....save yourself alot of $$$$$$ for a little $$ now.
/ New DK45SEHST owner #4
That's great value for a very fine tractor. I'm sure you won't be disappointed.
I apologize but what exactly is deadheadng? I see you have two remotes on the back. I don't have any use for a snow blower so I really wasn't going to run the extra remote to the back but am considering the one on front for a grapple. My price was $600 on the rear remote and I just don't think I'll use it enough to justify it. I certainly do not want to damage anything though.
Thanks
/ New DK45SEHST owner #6
If you have no use for the 4 ports on the back (dual remotes) don't spend the money...they can always be added in the future.
The front aux valve for the 4 in 1 is reasonable priced. I would get that.
The machine is equipped with 1 auxiliary remote at the rear of the tractor. The lever to control the flow of that remote is located to the right of your right shin. If that lever gets locked into either or position with out having some thing hooked to your rear remotes, the hydraulic flow will be activated and have no where to go. That will cause a major amount of heat and cause your hydraulic pump to fail, I did have one machine here that had so much heat created that is melted wires and most of the orings on the hydraulic system.
The hydraulic ports on the rear of the machine acts as a valve. Flow can go either way depending on which way the lever is positioned.
/ New DK45SEHST owner #7
RJ
If you will be using that box blade much, you might want to get top and tilt hydraulics for your 3pt hitch. If that might be the case, then there is a reason and use for that 2nd rear remote. ;)
I know that many people can not imagine what they would need these for, but as they use their tractor and see the benefits of these, there are many people adding the remotes after the fact. You can get by without, but it sure is nice to have them when you need them.
$900 for the front remote is a fair price IMO and if you are going to get a 4n1 or a grapple, then it also is a nice option that you almost have to have.
Good luck with your decisions and enjoy your new tractor. :thumbsup:
/ New DK45SEHST owner #8
I agree.
I do use it for the hydro top link - didn't even know I needed one until I used it and now I can't imagine being without. Get the second remotes for sure!
Bob
BTW - congrats on the new machine.
/ New DK45SEHST owner #9
I agree.
Bob
Most people are that way, when they have never seen or used an item, they figure what would I need that for. :confused3: But once they use it, it is how in the world did I ever get by without it. ;)
/ New DK45SEHST owner #10
This will only happen if your valve is locked on for a period of time, probably
a minute or more. This is not "deadheading" the pump, since all pump flow
goes thru a relief valve.
This is an important distinction for the new user because sending the
implement pump into relief is very noticable, and it occurs all the time
when using the loader without any problems. Of course, it is only in
relief briefly as when the cylinders reach the end of their travel. There
should be no fear of deadheading a pump on a properly plumbed tractor.
I only mention this now because there is a current backhoe thread where
someone connected up his hoe backwards with a PTO pump, and broke
the casting of his valve. THAT was deadheading the pump, as the flow
was not protected by an relief valve. Bad.
/ New DK45SEHST owner #11
My dealer recommended removing the detent functions from the rear remote...
Thanks everyone. Called the dealer back and added the front plumbing for the grapple and decided to add a sun shade. Wallace was right on the money about the rear remote. My dealer told me there'd be no real savings on the back remote either way so I'm going to get used to the tractor and see what and if I really need them. Going to be a long month waiting on that tiller though. Thanks again. I'm headed over to the implement section to talk about grapples! :)
/ New DK45SEHST owner #13
Sorry I am late replying but another option that would save you some money is to just buy the kit and install the extra rear remote yourself. I'd use the first remote for a topping lift and then use the second remote to control a grapple or 4n1. I'd definitely go for fluid in the rear tires too. A 900 lb tiller will be good ballast too.
$900 for electric over hydraulic wouldn't be a bad price. I'd forgo a plain diverter valve for that money. The rear remote is just as good for controlling a grapple. Just need to get used to it as you would with 4 on the floor.
Congratulations on pulling the trigger. The DKse family of tractors is great. Love mine.
/ New DK45SEHST owner #14
Congrats on your purchase. Those butterflys will now be replaced with seat time!!!
The dealer describe it as another valve and a different lever being mounted beside the original so its not electric over hydraulic.
Thanks
RJ
The dealer describe it as another valve and a different lever being mounted beside the original so its not electric over hydraulic. Seems like it would be Ok since they are close.
Thanks
RJ
/ New DK45SEHST owner #18
i ude my 2nd rear remote to run my snow blade doing some gravel grading work. was real easy to use. no problems at all.
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
