Broken Mount For LA724
/ Broken Mount For LA724 #61
I was wondering HOW the OP moved the machine with the hoe. Some operators like to have the FEL bucket in the full dump position and raise the front end up a bit (some pick the wheels all the way off the ground). If he had the bucket in that position and then used the BH to pick up the rear and push the tractor to the side, all the torque would be on the parts that broke.
/ Broken Mount For LA724 #62
I have to chime in here. The bottom line, IMO, is pour design and I don't care what color it is. I also don't agree with lifting the whole tractor completely off the ground by many inches while using the BH either, especially the front end. Just sayin!
/ Broken Mount For LA724 #63
The loader bucket position was covered in the original post in this thread:
"When I use the backhoe I lay the FEL bucket flat on the ground so that it will slide when I reposition with the hoe."
So he was fine with it, in that respect .... I've done similarly once or twice myself :D
/ Broken Mount For LA724 #64
If you dig a trench between two buildings, you will end up moving the tractor off of the trench with the backhoe. That is a very common maneuver. To do that, you have to have the bucket flat on the ground to keep the front end from falling into the trench. Kubota should know how backhoes are used and should have anticipated any tractor that would accept a backhoe would be used in this way. I feel they have a design problem.
/ Broken Mount For LA724 #65
They look like yours. Solid on the outside with a pattern cast into them on the inside. No plates welded on.
My GL3240 w/LA724 purchased the fall of 2008 also has no extra plate welded, just the castings. If Kubota made a loader mount design change it had to be over two years ago as my tractor was built in early 2008 and sat on the dealer lot for 6 months when I bought it.
I don't know when they stopped putting the reinforcing plates on the brackets but I do know of one 2010 L3240 that will have the plates.That one is mine as I just finished making the template for them and will get the plates cut out tomorrow.I am thinking of 1/4 inch plate welded on both sides of the bracket.Some people will probably say that if I make that area stronger it will just break somewhere else.Maybe true but after studying this whole loader assembly,I definitely think these brackets are under built and are the weak point of the whole assembly.I am certainly not an engineer but I have worked around steel long enough to know a few things about it.I will add the plates regardless if Kubota replaces the brackets or I have to repair my own.I normally have quite a bit of faith in Kubota quality but this is one instance where I think they could have made a better product.:2cents:
/ Broken Mount For LA724 #67
Kcender,
I'm currious as to what the design change was, exactly. Being a designer of castings, myself, my prime suspect is that the amount of long welds on the plate were cost prohibitive for manufacturing, and someone in a kwality circle or a cstcttng team got a paltry bonus or company coffee mug for eliminating it. My suspicion further suggests that this was accomplished by thickening the web of the casting to provide a similar dimension to that of the casting + plate.
Could you humor an obsessive design engineer and take a measurement across the thickness of your part? From the attached pictue I have a casting thickness of 7/8" with a 1/4" plate filet welded onto the web:
Thanks. Oh, happy (belated) Canada Day, by the way!
-Jim
/ Broken Mount For LA724 #68
Kcender,
I think you're exactly right.. the scenario was something like this..
"Ok, we had to weld stiffeners on the 724 loader brackets to keep them from cracking. Let's calculate how much more material we need to put in the mold to compensate for the lack of the stiffener plate. We'll save the cutting and welding time for the old plate and streamline the process."
Sean
/ Broken Mount For LA724 #69
Kcender,
-Jim
Jim - I have a LA854, not a LA724 loader, so I have a somewhat beefed up arm in the area but it is of similar design. The section is 150 mm deep by 20 mm wide or 5.9" x 0.79". Calculating the moment of intertia, it is 13.5 in^4 in the fore after direction and 0.24 in^4 in the side to side direction or 56 times stronger in the normal loader forces direction. If I am run into a bank to load my loader in float, there is no resistance from the lift cylinder so all force has to go through the main loader arm and that section has the lowest strength before it really enlarges into the torque tube weld. But it is designed to be very strong in that direction. Now visualize the bucket being firmly planted in the ground, raise the rear end and move the tractor with a backhoe bucket. If you scoot the tractor fore and aft it should be the same load as running the bucket into a bank or back dragging = no problem, working against the strong section. Now visualize pulling it side to side. If the bucket sticks for some reason it can put a high side load into the arms and that rear web is the most highly stressed point. If you go back to the first post in this thread and look at the cracked side, you can see the crack starting from the outside and actually being a vee shape. That matches the rusty area on the fracture surface of the broken side. If you anchor the bucket and try twisting the tractor in the loader frame, you end up with the loading that creates this stress. So I look at the failure and think I understand the load condition that caused it, but I have no clue as to whether Kubota should have designed it to be strong enough to withstand all the twisting load possible by pulling the tractor sideways with an anchored bucket (not that the operator intentionally put the bucket in a hole that effectively anchored the bucket against twisting load, but if it happened). Somewhere they had to draw the line or the loader would get so heavy and expensive we would never buy the product. The section needed to make that arm as strong side to side as it is fore and aft is 3.6" x 3.6" (that give a moment of 14 in^4 in both directions). Bottom line for me is I am even more glad I bought a mini-excavator instead of waiting for my Kubota dealer to find me a backhoe attachment.
Kcender,
-Jim
I just measured my bracket in the same spot as you show,it is also 7/8".From what I can see from your photos the web pattern from the casting is different on mine.Where yours is showing three depressions across the width
of the bracket,mine only has two.The third area is full thickness from top down quite a distance.It appears there was a slight change in the casting process to compensate for the lack of a welded reinforcing plate.Whether this is good or bad is debatable,I personally would prefer to see the casting process removed entirely from the fabrication of these brackets but I assume it is due to cost efficiency.I have added a couple of photos to help clarify.One shows the pattern of the webbing with the plates laying beside it that I have made to reinforce the bracket.The other shows how the plate will fit on the webbing side,it will be the same on the other side.I plan to reinforce the other bracket the same.
/ Broken Mount For LA724 #71
MHarryE-
Thanks for that information!
Kcender-
7/8" it is, then. I am kind of surprised at Kubota and I really think someone should lose their employee of the week parking space, or at least give their mug back. I'll be dining on Blacksbird Pie tonight.
I'm fully in agreement with you about not liking a casting for this application. To be frank, I only use a casting where a weldment or hog out is highly impractical or very expensive - shapes like an engine block or pump housing. As others have stated, this looks like a perfect shape for a weldment of bent up plates and maybe some milled forgings/bar stock for the loader arm attachment points. I think your fix looks like it should work very well and be much stronger than what you started with, new. It wouldn't surprise me if you get some requests to make a few sets up for others on this forum. Please show us the finished weldments as I always appreciate seeing a job well done in it's completed form and you certainly know what you are doing. Maybe someone at Kubota will feel appropriately shamed after studying your solution. Shame is powerful stuff.
-Jim
I just got home from work to find Terry from my local Kubota dealership along with the regional rep for Kubota.The rep was anxious to see the brackets and said it has generated quite a stir up through the ranks at Kubota.Apparently they had never encountered this before and were quite surprised that it happened.He agreed to replace both brackets without question,saying it should never have happened and apoligized to me for it hapenning at all.Apparently he can find no record of any changes ever made to the manufacturing of the brackets but acknowledged the difference in the pictures of Baby Grand's tractor.He offered to try and get me these brackets but I told him I would prefer the original type of bracket so I can weld on the reinforcing plates.We discussed the welding of these plates and he thought it was a good idea.He has no trouble with me doing the welding as I am a certified welder but was willing to pay a welding shop to do the work if I had wished it.He also said for the dealer to have the brackets powder coated after the welding is done as that is how they are originally painted.They are going to try to find me a set of brackets in the system but if none are available,they will take a set off a tractor on the lot.As for the timeline,I broke the bracket Wednesday evening,my dealer came down to see the tractor Sunday evening on his own time[Friday was a holiday],and the rep came on Tuesday.The retail price of the brackets is over $1100 per side.I am more than happy with the response from Kubota and feel I couldn't have been treated any better.
/ Broken Mount For LA724 #73
That's great to hear that they're taking care of this, & in a timely manner.
/ Broken Mount For LA724 #74
Sweet man, finally a win for kubota this time, and yourself taboot! So sick of drinking all the haterade towards kubota on tbn lately. Sounds like youve got a good dealer and thats what counts! Post some pics of your plates when done.
/ Broken Mount For LA724 #75
kcender,
Good for you and good for Kubota and the dealer!
Some days you're the bug and some days you're the windshield, today you're the windshield and you win.:thumbsup:
/ Broken Mount For LA724 #76
Glad to hear things are working out well, I was pretty sure Terry would be willing to do what he could. It's good to see Kubota standing behind their products, even after the warranty has expired.
Like we said the other day, I'd hate to pay to build a tractor from parts. $1100 per side is pricey enough, let alone labour costs.
Interesting that they had no problem with welding the new ones, maybe if they see a few more break Kubota will go back to welding the reinforcing plate on.
Sean
/ Broken Mount For LA724 #77
Glad Kubota is helping out! I see a redesign coming to a dealer near u!
/ Broken Mount For LA724 #78
Outstanding ! :thumbsup:
/ Broken Mount For LA724 #79
MHarryE-
Kcender-
-Jim
Well Case would disagree with you. There are parts on my 580K that are cast and even have the words "do not weld" cast into them. Things like the front axle and the backhoe boom are ductile iron.
/ Broken Mount For LA724 #80
Glad to hear about Kubota replacing them. My personal opinion is I would lift the bucket before moving the tractor in the future. Just making the brackets stronger will just transfer the stress somewhere else. If these brackets braking was something that was happening across the country and was a known problem then I would think differently.
2018 JCB 3TS-8T SKID STEER (A62129)
2018 JCB 3TS-8T...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
UNUSED INDUSTRIAS AMERICA 190-9' SCRAPE BLADE (A62130)
UNUSED INDUSTRIAS...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
