Using RTV to rake grass and leaves
   / Using RTV to rake grass and leaves #1
jcombs
Member
McKee, KY
Kubota L3200
I would like to find a way to use my RTV 500 to rake grass clippings and leaves. I don't need a collector or anything, just a way to pile the stuff up, even if it is small piles. I'd also like to be able to use the RTV to pile up brush when I'm clearing an overgrown area. Of course I'd like to get by as cheaply as possible, which is probably going to be the challenging part.
Anyone have any ideas?
   / Using RTV to rake grass and leaves #2
You can get a pull behind lawn sweeper, other than that the tasks that you want to do are best done with a tractor.
David Kb7uns
   / Using RTV to rake grass and leaves #3
David Kb7uns
That's true....You can push moderate sized brush piles with a snow plow, but that ain't cheap.
   / Using RTV to rake grass and leaves #4
The thing is it is a RTV500, a 900 or 1100 can get the hydro broom and plow with mounts but then you are a good ways of money to a BX.
David Kb7uns
   / Using RTV to rake grass and leaves #5
David Kb7uns
I think the plow on my 500 was around $1500...From Kubota. Aftermarket is probably less. Thats some good money for sure.
Thanks for the replies. I'm starting to consider buying a cheap chain harrow and using it with the tines pointed up to rake grass and leaves. Would this work? Or would I just be wasting my money?
   / Using RTV to rake grass and leaves #7
why not just mount two leaf blowers in front or behind the rtv ?they do move alot of leaves and with two of them i bet it would clear out a path in no time.
2016 Kawasaki Mule (A55973)
2016 Kawasaki Mule...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
2019 Deere 35G (A53317)
2019 Deere 35G...
2004 BMW 545i Sedan (A55853)
2004 BMW 545i...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
Kubota M5-111 (A53317)
