Verticaltrx
- Joined
- Dec 30, 2009
- Messages
- 1,908
- Location
- VA
- Tractor
- Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
We're dealing with a tractor here, not a china cabinet after all. I doubt that moving it with the bucket bottom flat on the ground would put enough twisting torque into the mounting brackets to break the way they did. If anything, I think they should have broken out of the engine block since that is only bolt threads into cast iron.
From what I've seen of broken Kubota parts on TBN lately, I'm thinking they have a potential problem with steel quality in their attachments. The broken backhoe booms and now the loader bracket make me think there's more to this than just use or abuse. Steel shouldn't break like that, without bending first.
Thank God they aren't building bridges.
Sean
I don't see any abuse in this case either, nor do I think that the OP should have spent the extra money for a 'real' TLB. As far as I'm concerned even the standard Kubota tractors are what I would call commercial grade. Compare their loader and especially backhoe design with other compact tractor makes and it will reinforce this.
Now I'm speaking about the B-series here, because that's the only one that I have directly knowledge/use of. But the B26 is 90% a B2630, with a upgraded loader and backhoe (and third hyd. pump for BH swing). The subframe on the B26 is a little bit heavier, but is essentially the same design as that on the larger B-series. The main difference is that it is one entire weldment on the B26 vs. being bolted together on the standard B-series. The new BH77 is very similar to the BT820, except it has a slightly shorter boom/dipper, and less breakout force. The BH77 actually has more dipper stick force than the BT820 however. The TL500 loader is a good bit more substantial than the LA403 or LA504, but is has to be because of the greater lift capacity.
My point on all this is that the Kubota TLBs really do share a lot in common with the non-industrial tractors. They use some upgraded parts and weldments here and there, but otherwise they just combined parts, features and attachments from different models to make a tractor more desirable to the commercial contractor. Would I rather have a B26 over my B3200, probably not. Would I like to get a B26 in addition to my B3200 someday, definitely. The B26 can't do what my B3200 does, nor could my B3200 do the job of a B26 nearly as efficiently.
Now, the bigger issue here is what appears to be the lack of good materials and/or Quality Control. I may get bashed for this, but I think it has to do with the typical American spirit of buy materials as cheap as you can and build it as quick as you can to turn a good profit. Notice that almost all of the catastrophic metal failures that we read about in the Kubota forum have to do with either loaders or backhoes. Is it a coincidence that they are made in the USA, while the rest of the tractor comes directly from Japan? I can say without a doubt the welds on my LA504 loader are not nearly as nice as those on the tractor itself. I think it's time for Kubota Corporation Japan to have a talk with their American counterparts.
