Any Subaru owners?
/ Any Subaru owners? #21
Iv noted that Subarus tend to lose value faster than most others.
The prices hold very well in PA and even better further north (I don't know about the western states).
You folks in VA and further south don't regularly get those tough winters as folks in the NE do. Winters in my area aren't normally that severe (but every so often we really get walloped!), but snow removal on rural roads in PA can be quite hit or miss.
/ Any Subaru owners? #22
I have a 2002 subaru outback. I really like it, and will get another when I am finished with this one. They are the perfect car for snowy areas.
My wife severely overheated the engine at ~80k miles, and I am still driving it. The issue is that the overheating has caused a leak of both water and oil. It isn't burning it(no smoke, either black or ethylene glycol).
My question is whether this is related to the head gasket issue. The oil pools in the spark plug hole. I'd like to fix it, but this would be a 2000$ mechanic bill where I live(a college town). If it gets fixed, I will have to do it.
Thanks in advance for the help.
Chris
/ Any Subaru owners? #23
I WOULD NEVER BUY ANOTHER ONE, ENGINE GAVE UP AT 80,000 MILES DUE TO VALVE PROBLEMS. HALF SHAFT ON THE FRONT END WENT OUT AT 40,000 ALL PARTS ARE OUT RAGESS. THEY SOLD THE WARENTEE TO A PRIVATE COMPANY AND REFUSED TO COVER REPAIR. OVER PRICED PEACE OF JUNK. DO YOU SEE MANY HIGH MILAGE EXAMPLES ON THIS THREAD ?????
/ Any Subaru owners? #24
I have 900,000 on 3. Approx $2K total in repairs.
larry
/ Any Subaru owners? #25
Owned 3 Legacy's. Two Outback AWD's had cooling system issues as previously described. A '98 had a head gasket problem, a '00 had a cracked block. An old FWD version ('93?) ran forever, sold it back to the guy I bought it from when it had 190K on it. I think the Forester is better for the 2.5L cause it's lighter. The '00 Outback I owned had 2 sunroofs=more weight.
The mileage @ problem time was 125K-150K. Other than that, great cars. Good in snow.
/ Any Subaru owners? #26
Chris
The oil pooling in the spark plug holes are just the valve cover gaskets getting old/dry When you put a new head gasket on, this will go away. SOME of your oil leak could be just the VCG; have you confirmed coolant leakage?
THERE'S ALWAYS GONNA BE SOMEONE WHO HATES ANYTHING :D
I appreciate any reply, the pros seem to be more than cons, which is what I'd expect.
But as far as high mileage goes, all the used ones I've seen had 150,000 and up. Some had 250,000+
I call that high milage, especialy compared to the 75,000 this 01 has.
JB
/ Any Subaru owners? #28
JB
I hear you. Like the fact it is low mileage and agreed it is a wonderful car but. (-: I too am a tech and repair shop owner and I am getting a little tired of them.
We get mostly higher mileage ones, like all cars they have their Achilles heals, head gaskets and oil leaks being chief offenders as others have already pointed out.
What tires me is the oil leaks, replace cam belts and replace all the cam and crank seals oil pump seal and orings ect thinking all is good to go.
Come back leaking oil, replace VC gaskets, come back head gaskets leaking oil. Just seems when they get 150 k on it they want to leak oil, period.
Had one a few years ago would overheat sporadically. Could never pin down a combustion leak, would be good for 4000 miles then overheat for no apparent reason, check-over, do this and that works great, comes in for service everything is fine, two weeks later bang, overheat and comes in on hook. Finally get to test positive for leaking head gasket, new gaskets, put mirror finish on heads as required.
Could see had been apart before and looked as though the finish was rough so figured that was the cause of problem, finish up, no problems, get in for service about 3 k later, everything fine, two weeks later overheated and on the hook, this time she was cooked.
Cost me some money and frustration, have harbored a grudge since. (-:
But like i said, like your low mileage. As others have said, check out that PO 420, Cats are not cheap. Regards, Roy
/ Any Subaru owners? #29
I just checked my current one. It has 273K -- not the 250 I said earlier. I had the oil leak fixed around 220. Ill hit 300 by next yr if it keeps going. ... Seems ok. :confused3:
larry
Thanks for the real life experiance.
I've been really dragging my feet on this car, I don't need it right now. But I have been stalking it :laughing: been driving by her house and it's still sitting there.
Was thinking of offering her $3500. but haven't gotten up the nerve yet.
She left me a message today that she had someone coming to look at the car and they sounded serious, she is very nice and I know she woud like me to get the car, so she was giving me a first chance of refusal.
I just got the message a few hours since she left it and I'm worried that she may of sold it. If so i won't be to upset, if she didn't sell it I have a better chance at her taking less for it.
JB.
Update,
Well she did have a serious buyer but they backed out, so since I was kicking myself all week for not buying it, when I found out it was available again I gave her a hundred bucks to hold it for me til I can bring it to my buddies shop and put it on the lift to make sure there are no major problems underneath.
I did look underneath and there is no signs of anything leaking anywhere.
The Check engine light is on now though, My brother has an 01 outback which has 190,000 miles. He said his light has been on for 2 years, as long as it's not effecting performance not to worry about it?
He's done the head gaskets and timing belt. He did have the viscus drive unit go bad, but the suby tech told him that is so rare he never saw it before. He does use his hard, he's a carpenter and has that thing loaded to the roof with tools and equipment.
He told me there are so many Subarus in Vermont where he lives, you can't find your car in the store's parking lot.
JB
/ Any Subaru owners? #32
Sackett2
Thanks for replying, and sorry about they delay in getting back. The coolant leak is real, as it takes about 1 quart of coolant every fillup just to get it to the radiator cap. I check it cold, but the fill tank is always empty, and the fluid level is always out of sight of the radiator cap. Its oil/coolant use changed drastically at the overheat event.
My wife actually drove it through feedlot drainage area containing about 9" of manure, which plugged the radiator. She didnt' tell me for a while. It says something about the car that it made it through. Thanks for the heads up on the valve cover issue.
Thanks again,
Chris
/ Any Subaru owners? #33
Update,...
JB
I had a '98 Forester. At about 8 years of age the check engine light started coming on all the time. It was because the top of the fuel filler had become corroded, which kept the cap from sealing well. The dealer had a kit to repair it, so it was a common problem at that time.
Overall I liked my Forester, but it did have a lot of problems staring around 8 years of age. They were generally piddly, like the fuel filler, but expensive to fix.
Joe
There is alot of negative stuff online about Subaru's from that era.
This car with 76,000 miles, I hope will give me a few years of trouble free service? I don't mind the piddly stuff, or maintenance.
I wont be putting many miles on it as it will be second car, insurance is not bad either, net increase in my policy is gonna be under $500. since it's the 4th car in a household of 3 drivers, My most expensive vehicle will be the part time vehicle, lowering the cost to insure that one.
Have not bought the car yet but I'm 90% certain I will by the end of the week.
JB.
/ Any Subaru owners? #35
The viscous drive joint WILL fail if the car is run with tires that don't match exactly all the way around. Subaru has always had the need to replace all four tires at one time because of variations in diameter, even in the same maker but different year tire product. It was true of the old transfer case 4x4 and still true of the AWB models.
They lose front CV joints from time to time but it's not that big a deal using aftermarket whole axle units. I paid $49. each for both on an '87 wagon and ran another 100k with them in it.
If the engine sits without running and has dyno oil there's a chance of varnish forming on the valve lifters. They'll clatter like **** intermittently forever after. It can happen to pistons too but the lifters do it sooner. Embarrassing racket when they're sticky.
I dropped a valve at 140k in that '87. Drove home with a disintigrated piston and a guy put a Japan pullout shortblock in for a total of $406. Ran that car to 320k commuting and sold it for $3000. tired.
I've got my third one now - a '98 that just turned 49k miles. That's low milage in 14 years, eh? I retired and don't have to commute anymore.
All in all, subaru has treated me pretty well over 30 years. Not great milage but they'll usually get through and the wagon models cal be used like an enclosed pickup truck. You wouldn't believe the stuff I've carried in or on Subarus over the years.
I don't like the auto trans ones, but that's just me. I don't like ANY auto transes since I spent two years rebuilding them forty years ago. :)
/ Any Subaru owners? #36
Be careful they can be a money pit. I had a 98 forester, what a piece of junk. Transmission leak, front main seal, rear main seal and 4, yes 4 rear bearing replacements at around $500 apiece. I got one replaced under warranty and one they felt bad for me and the rest I had to pay for. Will never buy one again, I got it because the company I used to work for made parts for them. They burn oil after 80,000 miles and they usually smell like gasoline because I guess of poor venting. The transmission leak was $1,600 to fix. Plastic parts are brittle and also junk. Rubber on the steering wheel separates off the inner metal frame. If you get it, good luck.
My wife used to have an Legacy Outback. Don't know the year but it was before 2000. The same experience. There was always something wrong with the car. Usually small things but it cost about 50-100/month in repairs. I was glad to get rid of it after she rear ended a pickup truck. It used lot of fuel for the size. Needless to say she drove about 4 to 5000 miles a month so she put a lot of miles on it. It seems to me that after about 180k it just fell appart.
Well I bought the car for $3,800. tonight. Just came in from cleaning it up a little. I'm glad you mentioned that about the tires cause there is one non matching new tire on there. It is the same size stamped on the tire, but I'm sure being newer and a different brand that it isn't the same as the others.
I was thinking I'd have to get new tires sooner or later, but it will be sooner now. I don't mind spending a little already on it, as I have the receipts from work she had down to the car just in the last year and a half and very little mileage since. She spent over 2 grand on new front axles, new complete clutch kit, new front rotors and pads, new rear shoes, a complete tune up with plugs, filters, wires etc.
The car drove nice before I checked the tire's air pressure, found them to be under 30 psi, can't wait to try it after I filled them to the correct pressure of 44 psi. I haven't had a standard in 15 years so it's like driving a little race car for me now :)
It will need an oxygen sensor also, if I want the CEL to stay off.
I called a Subaru dealer with the VIN and they told be there is an extended recall for the dreaded head gasket problem, out to 2014 and 100,000 miles. they only do the work if the heads start leaking. I don't know how much of the cost is covered either.
It's had some kind of coolant additive as part of an effort to help with the head gasket problem somehow.
JB.
I'm not gonna put many miles on this car as it is a second car for me, so this thing will never see anywhere near that many miles while I own it.
But it is interesting hearing the negative stories about Subaru's, I thought they were near infallible before I started looking closely at them.
JB
/ Any Subaru owners? #39
JB.
OK, what is the code that says you need a o2 sensor?
Head gaskets; the additive MUST have been used; so make sure it has it in. They will only do the head gasket IF it leaks coolant.
/ Any Subaru owners? #40
JB.
If I remember it right the correct tire pressure is 29 psi front and 28 psi rear. The required pressure is on a label in one of the doors frames.
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2022 EZ-GO ELITE...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2021 TORO MRTX2500 68138HD STAND ON CONCRETE BUGGY (A63276)
2021 TORO MRTX2500...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
John Deere 2840 Tractor (A64047)
John Deere 2840...
