Help with Big Fence Project--Rookie!
   / Help with Big Fence Project--Rookie! #11
My own view is that pounding is the best way to install posts. I had about half of mine pounded but augered holes for the remainder myself. The pounded posts went way quicker and was much more cost effective if I factor in even a modest wage for my own time. The horses have since loosened some of the augered posts but all of the pounded are still secure.
We're into clay. maybe your sandy soil would give different results.
Big ditto on this. My neighbor and I share equipment, he owns a pounder that I used last summer to do our 5ac pasture. I own a PHD and it's a pain. FWIW, we used high tension electric fence, requires far fewer posts and costs way less. Also invisible.
The post we are getting are square. We would need round posts to use the pounding method, correct?
   / Help with Big Fence Project--Rookie! #13
We are fencing in 6 acres for horses this summer. It's a big project and we're rookies, so I'm trying to ask advice from those who have done projects like this! We're in northern Michigan with mostly sandy soil. Our plan is to rent a post hole auger for our Ford 3600. Line and corner posts are 5"x5"x8' black locusy. They'll go 3' deep. Gate posts are 6"x6"x10' locust. They'll go 4' deep, I think. Boards are 5/4"x6"x8' white oak. We're going to screw those in.
Anyway, I'm not clear on how to brace the corner posts. I can't seem to find any drawings or advice on how to do this. Also, I did not order bigger 6"x6" posts for the corners, just the 5"x5". Will the 5x5"s suffice for the corners?
Also, I've read conflicting advice on whether or not to put cement in to secure the gate posts. Some folks say this will tend to gather water and rot the posts. Others say you really should cement them. Others say just tamping well will do. I've also heard adding crushed gravel or pea gravel will make a more solid bed for the posts. Any thoughts on this?
Any words of wisdom are welcome! Thank you in advance.
I would not worry too much about bracing the corners of a board fence. The boards themselves are plenty.
How high up you going?
How many boards up?
What is the planned distance between post?
Any stallions?
You will probably want to add an electric fence, at least up around the top board.
See Post #14 http://www.tractorbynet.com/forums/projects/156233-board-fence-2.html#post1809077
BTW, I'd buy an auger.
I would also have something along the lines of crusher-run to use for back fill. It has always amazed me how you can make a hole for a fence post, put the fence post in then put the dirt back in and not have enough dirt.
   / Help with Big Fence Project--Rookie! #14
I'm not sure if you NEED round, but I suspect it would be tricky to keep square posts square to the rest of the posts. That would be important with a board fence I would think.
Isn't that the truth! :D
   / Help with Big Fence Project--Rookie! #15
Since your soil is sandy, I'd concrete the braced corner sections' posts & the posts on all intermediate fence sections (in stronger soil I probably wouldn't use concrete at all).
Here's a drawing I did that was based on my using 4x4's for all corners, brace sections, line posts & the actual horizontal brace itself.
I did use 6x6's for my main gate posts, but only for looks. Concreted 4x4's with the horizontal brace member & diagonal brace wire shown are very strong.
attachment.php
   / Help with Big Fence Project--Rookie! #16
This can also help one decide to go ahead & use at least some concrete :thumbsup:
If you're not going to fill the entire hole with concrete, I'd at least pour some in the bottom, then dirt on top of that, & then some more concrete at the top.
Thanks, again, everyone.
Gizmo2--We are doing 4 board and 8' spacing between posts. The fence will be about 5' tall. We'll sink the 8' posts 3' down, leaving 5' above. No stallions. Two quiet mares, but hope to add some Irish Draughts eventually, who do like to jump! We will be adding a line of electric on the top board, I think.
I've found some "crushed gravel" at a local place. It has some clay and sand in it. I think it might be just right for setting the gate posts.
Also--trying to figure out how to come around a 90 degree corner when I'm placing the boards on the inside of square posts. It seems I'll either have to put in two posts at each corner, or one board will have to go on the outside of that corner post. Any better solutions?
Beppington-thanks for the drawing!
   / Help with Big Fence Project--Rookie! #19
Around here the boards go on the outside of the post so the 90deg corners are no big deal. No bracing on the corners and gate post are usually cemented.
   / Help with Big Fence Project--Rookie! #20
You need one more short 2x4. 1) Attach the fence boards on one side first (the red ones). 2) Cut a 2x4 the length from the top edge of the top red fence board to the bottom edge of the bottom red fence board. 3) Nail or screw the 2x4 on to the face of the red fence boards as shown, using nails or screw long enough to penetrate through the red fence boards into the corner post. 4) Attach the fence boards on the 2nd side (the blue ones), nailing or screwing them into the 2x4.
Top view:
Massey Fergusson 4710 (A60462)
Massey Fergusson...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
Kubota RTV-X1140...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
43023 (A59228)
43023 (A59228)
