Not pretty, but...
/ Not pretty, but... #1
irvingj
Elite Member
Etna, NH
2007 MF GC2310 TLB
Didn't know if I wanted to put a pic of my welding on here, I'm strictly a beginner!
But I decided that I just couldn't live without hooks on my FEL any longer, and I don't have a large arc welder so I grabbed my oxy-acetylene set and started out....
Did the first hook (center) with my right hand on the right side, then tried the torch in my left hand for the left side; won't try that again. Not pretty, but I think it'll hold OK. Second hook went better, had a better idea of how much heat to use. One more hook to go.
Any comments? (How'd the student do?)
Should I even bother to try the wire-feed I have, or would that just not be up to the task? (It's a Lincoln 115V SP-125 PLUS with no gas, just flux-core wire.)
/ Not pretty, but... #2
Don't know if the Lincoln would be up to the job but I'd say your welds look good for O/A.
They should certainly hold.
When I have ****** welds I smear some "No More Gaps" in the cavities prior to painting - no one will know!
/ Not pretty, but... #3
Oh sure, let our secret out to just everybody!:D:D
Really I think most of the welds look pretty good, the left handed one is not as pretty, but you knew that. I bet they stay stuck!
James K0UA
/ Not pretty, but... #4
I have a Lincoln Pro 100 wire welder and I use it for everything (including my bucket hooks). I have welded 1/4" and even thicker with it using multiple passes and it works, although I throw the breaker a lot on thicker metal. It's what I have so I use it and so far all my welds have held!
I'd say give yours a try, but make sure to use good wire in it (like Lincoln-branded wire). It makes a big difference. And for the record, your torch welds probably look better than my torch welds would...
/ Not pretty, but... #5
With a little grinding and a cover pass of flux-core that left side weld might look better. You might even use it all around to spruce things up.
/ Not pretty, but... #6
The first picture looks the best, but you need to add more filler to the crater. All the other welds I'd grind out and do again! ;)
/ Not pretty, but... #7
I second that !! Cleaning it up & knowing it won't fail is better than hoping it won't fail & being wrong. MikeD74T
Thank you all for the great suggestions! I really hadn't thought of adding wire feed as filler before painting.
HiTechTed, thanks for the tip, though I have no idea what brand the wire is- bought the machine used, for a great price.
I, too felt it was more important to get deep penetration (don't we all wish for that- oops, sorry!) than to have it look good, though a smooth appearance is nice. I made sure metal was good & hot and almost melting as I was adding filler; that much I learned --the hard way:laughing:-- from the class I took a year or so ago. Saw a couple of my "jobs" pop right apart with a moderate hammer rap.:ashamed:
'K- Thanks for the tip! I wasn't sure if I was remembering that part correctly.:thumbsup:
OK, last hook is done, some paint sprayed on...
Decided to stick with the gas welder. It came out much better than the other two, here's a pic of the "bad" side. Practice does help!
While I had the torch out, I threw on the cutting tip to notch a couple of bars I made up to hold the ROPs in a sort of half-way position, so it would stay out of the way of the 3PH while not having to raise it, lower it, raise it again, etc... (Did I mention I crunched the garage door opener last week with the ROPs up?:ashamed:)
Seems to work quite well! Holds the ROPs at about a 40-degree angle.
Thanks again to all for the tips & advice!:thumbsup:
  • last hook 6:12:11.JPG
"You're satisfied with that?"
To quote Arlo Guthrie, "I knew that it wasn't the best song I ever wrote..."
I think so.... though I'll admit it doesn't look it, it did melt up & into the hook.
(Why- does it look that bad?:()
And here's a question for you welders... I was wondering if at least part of my problem with cratering was a result of the force of the gas flow out the tip. I used the biggest one I had, but that was a Linde #15. I had to really crank up the flow to get enough heat. Would a larger tip have worked better? (Same heat, but lower gas velocity?) It seemed that the puddle was often blown away by the jet of flame.
/ Not pretty, but... #14
That could be, I know a few times I've O/A welded with a large tip and I had that happen.
In my opinion you're on the upper limits of O/A welding!
Personally I wouldn't trust that hook with much of a load, if you were closer I'd re-weld it for you for free! But then again you may not trust my welding! ;)
/ Not pretty, but... #15
I've borrowed a sp125 in the past and I think it's up to the job of welding those hooks.
I probably spent less than ten minutes of actual welding time on each one, but did end up using about 5 feet if 3/32" filler rod. But keep in mind- I'm slow!:laughing:
I think one of the reasons the last pic (last hook) looks so flaky is that the only spray paint I had around was Semi-Gloss-- too shiny!:p
That Linde #15 I used has a hole in the tip that's about 1/16" --maybe. I think it may have been a bit small for the job- any thoughts?
/ Not pretty, but... #18
O/A welding is hard. If I were you I would find someone with a mig to make a couple of passes. I always try to think "whats the worst that could happen if it fails"
Did you make the welds in one pass or mutiple.
One thing I realized is the more I had to grind the better welder I became :).
More interesting thoughts, thanks again for the tips & suggestions!
jamtuc, most of the welds I did --slowly-- in one pass, though there were a couple of spots I went back to try to fill in better. I had limited success in that. I was very carefu to ensure that metal was melting as I added filler, both the hook and the bucket surface.
I love the quote! I don't yet even own a grinder, but that's been on my list for a while. Any suggestions there for a not-too-often-used machine? One of those cheap imports with the right-angle wheel? Is that what could be used to get into a 90-degree joint like on my hooks?
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2007 INTERNATIONAL 9900I (A67714)
2007 INTERNATIONAL...
PALLET OF RAT PACK TOOLBOXES (A68842)
PALLET OF RAT PACK...
2007 CRYOGENIC VESSEL NITROGEN TRANSPORT TRAILER (A67714)
2007 CRYOGENIC...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
