Ventrac choices: engine advice?
/ Ventrac choices: engine advice? #1
MountainMomma
None yet
So, we're about to pull the trigger on a Ventrac 4200 of some description (and, yes, we've already come to that decision through much research--see this thread), and are only looking at Ventrac's liquid cooled engines, which narrows the field to four machines: 2 gas and 2 diesel. In combing the Ventrac section, I came across this:
"Ventrac provides tractors with 31 hp Gasoline and 31 hp Turbo Diesel engines. Both can operate safely on 30 degree slopes. However, the Gasoline version is rated for intermittent operation only--meaning no more than 10 minutes at a time on a 30 degree side slope. The [TURBO] Diesel engine has had modifications (by the manufacturer Daihatsu) to allow for unlimited continuous operation on slopes of up to 30 degrees. I switched to the Turbo Diesel in order to get this capability since I mow a lot of slopes. Incidentally, both engines have virtually the same torque response with the Turbo Diesel having a slight edge. In most practical tractor applications you can't tell the difference in performance."
MOST of the land that I need to mow is hilly. with many 30 degree slopes, but also lesser slopes intermittently. In other words, I can climb to a more level spot pretty frequently when mowing the truly steep areas. I've checked the current owners manuals online for the 4200 series, and the above is correct information according to the specs--the 31 hp diesel has same constraints as both gas engines, but the Turbo Diesel can run continuously.
Do I read this correctly to say... what? We can only mow for 10 minutes on such slopes with all but the D Turbo, and then...? Cut off the engine? Go to a level place for a breather...? In other words, what do the non-turbo engines need AFTER 10 minutes of mowing on a 30 degree slope?
/ Ventrac choices: engine advice? #2
I can't answer that question, but having owned/owning both gas and diesel, I now buy only diesel when available.
/ Ventrac choices: engine advice? #3
It may be an oil issue, and not related to the turbo at all. Most machines may not be designed for the engine's oil pump to pick up oil from the pan at that degree of an angle, which would cause them to stop lubricating the moving parts if operated like that for more than just a few minutes. Running an engine without oil will do serious damage quickly. I don't know anything about Ventracs, but it could be that the turbo diesel engine has been modified to pick up oil from the pan regardless of angle.
Run time issues aside, if it's in the budget I would lean toward the turbo diesel anyway. Diesels are generally more fuel efficient than gasoline engines, and the turbo generally gives the engine a little more seat of the pants power.
/ Ventrac choices: engine advice? #4
I was going to post in your other thread to get the Turbo Diesel, but I figured you had already made your decision. Since you have not, get the Turbo Diesel.
As for your question, I don't know for sure, but I feel confident the issue is a potential lubrication issue. I think the correct response is to limit the amount of time on the slopes for those engines, and seek to get to a flat place, or at least a much flatter place as soon as possible.
/ Ventrac choices: engine advice? #5
If it were my purchase, I'd go for the turbo-diesel also. As noted, it's almost certainly an engine lubrication matter, and their top of the line model (also the most costly), is designed for the steepest slope conditions. With a purchase in that price range and knowing what you'll be doing with it, it just seems prudent to go for the one best engineered to deal with mowing on hillsides.
Be sure to get the dual wheels. Don't know if your place requires the rough cut mower or one of the finish type mowers. I'd suggest you look seriously at the loader attachment. While it's costly, no doubt, loaders are some of the handiest attachments on any tractor. The other stuff, well you can figure out what's needed as you proceed. I don't know if Ventrac offers a "package deal" for attachments bought with a new tractor, but it's worth checking. That's pretty typical for other tractor manufacturers.
Yep; we're being quoted package deals. The difference is not insignificant: about $8K, but I'd hate to have to put a 10-min. stopwatch on every mow of a 30 degree hillside.
By the way, how do you judge the degree of hillside... just by looking? Seems that they make a distinction between 25 and 30 degrees... pretty fine for my eye. Are there tools so that we can "take soundings" (as it were) on our land?
/ Ventrac choices: engine advice? #7
/ Ventrac choices: engine advice? #8
How about some pictures so we can understand the angle that you'll be working on?
DevilDog
OK: here are shots of my terrain, in different seasons...
winter shot of one slope
Summer shot is the same view in green in April. This grass is now WAIST high! We need a mower for sure!
Other side of our property just this month: valley with significant slope and, oh yeah, multiflora rose bushes galore to pull up. Fun!
/ Ventrac choices: engine advice? #11
Angles of incline should not be a consideration if these pictures represent what you will be mowing, since it appears to be no more than 10-15%. Also, the diesel engine's oil capacity will be considerably more than the gas.
Goatman:
Just wondering: How can you tell that these are 10-15 degrees...?
/ Ventrac choices: engine advice? #13
I'd tend to agree with Goatman, with the stipulation that pictures are frequently deceptive regarding slopes. At the risk of making a fool of myself because my trigonometry skills evaporated decades ago, think about it like the pitch of a roof. Rise vs run (that is, how far laterally vs how far vertically). If your hill goes up 12 feet for every 12 feet you move horizontally (12/12 pitch... a very steep roof), you've got a 100% slope, or 45 degrees. That's half way to vertical (90 degrees), right?
If it's going up 6 feet for every 12 feet laterally, that's half as steep, or 22 1/2 degrees, 50% slope and 6/12 pitch in roofing terms.
Your hillside looks like it's maybe half that much or less, just using an eyeball estimate. 3 feet of rise for every 12 feet laterally, 11 1/4 degrees, 25% slope and 3/12 pitch.
If you have a good level, a measuring tape and some straight sticks, you can make your own measurement on a representative part of your hillside. Just place a longer stick jutting out horizontally and level from the hillside and use another stick from the end going vertically down to the ground. Measure how far out horizontally and how far down vertically. The vertical distance/horizontal distance x 100 is your slope in percent. Best to use sticks that are several feet long.
If our eyeball guesses are right, you'll probably be OK with any of the Ventrac's. If we've been deceived by the camera, and it's above 25%, stick with plan A and get the turbo diesel.
/ Ventrac choices: engine advice? #14
Optical illusions abound. One could hold a level plumb (straight up and down) and butt it up against something like this
General Tools 29 Plastic Protractor and Angle Finder with Articulating
and get a pretty fair estimate of what is going on.
I see very little my BX could not handle, unless I am fooled, but many of those places I would not want to be sideways on the hill with the front end loader on and up. But, I get squirrely about almost any slope with the FEL involved.
The Ventrac does not seem to have much ground clearance, so I suppose if a wheel dropped in a hole on one of those slopes, you would bottom out well before much chance of a roll over.
If you now decide that gas is an option instead of diesel, I still lean toward diesel and I think diesel is still to be preferred.
/ Ventrac choices: engine advice? #15
I know this is an old thread,but i wanted to chime in here on the gas vs diesel debate....I am a diesel fan for heavy equipment and trucks 3/4 ton and larger that run loaded and tow more than 50% of the time...but the gas vs diesel isnt always clear cut with small power equipment..
In the case of articulated Ventracs and Steiners,both machines are better off with LC gasoline engines.In both cases the diesel option will not last longer than the LC gas options,in fact they will not last nearly as long,they do not hold more oil,they hold the same amount,and in both cases the LC gas engines are more powerful,have more torque,much less vibration,and are much cheaper up front.
The reason the Ventrac gas engine (D950G) is rated for intermittent 30 degrees has nothing to do with the oil sump,as the diesel and gas are the exact same bottom end,and oil pump/pickup.It is just because the diesel has no carburator/float bowl. The gas engine under the most extreme situations can "burp" hiccup or even eventually stall because the machines on a steep angle,and the fuel in the carb is finding its level...the diesel has an injection pump that doesnt care what angle it operated on as long as the fuel pickup in the fuel tank doesnt suck air,it will inject fuel as designed.
First off I want to say that the 31HP Ventrac turbo diesel is a hunk of crap engine.This engine is also used in many zero turn mowers,chippers,and other applications.In every application,it fails to live up to the diesel engine standards of long life,and reliability.There is only one reason its used,it is the most compact diesel engine in the displacement range,and power range.But this comes at a price,reliability,it just isnt built heavy duty enough for industrial applications it was designed for.Its too bad this is the top option for Ventrac buyers,since it has several design flaws and fixing them voids the warranty with Briggs and Stratton.The breather is routed poorly,resulting in many hydrostatic lock issues immediately after an oil change.This bends a rod slightly and results in an engine miss/skip,and eventual failure if ignored.The oil feed to the turbo has a screen which clogs,and burns up the turbo.The turbo rarley lasts more than 800-1000hrs.These engines rarley see over 2000hrs,before throwing a rod,and they cost in excess of 5000.00.Parts are very hard to get and expensive.The heads frequently crack under 1000 hrs on the turbo model,epsecially if youve run it over 210 degrees at all.The non turbo engine (26.5) hp is much better,it doesnt have the head,hydrostat,turbo issues,but it still rarely makes over 3000hrs before catastrophic failure...the gas LC which is no longer made is the diesel engine,modified to burn gasoline,compression is lowered,an aluminum head is added with carb,and distributorless ignition is added.This is the same crank, block and oil pan as the diesel,with much lower compression,and associated engine stresses from the lack of high compression and constant diesel fuel knock...think about it,this gas engine is grossly overdesigned,which is why it is the one to have,will it use a little more fuel,yes it will,but the reliability is unmatched,15000hrs is nothing for one of these engines if properly maintained....they literally run forever.In addition,the usual diesel advantages are not present with these briggs diesels because diesels need to do 2 things to be more efficient and reliable than gas engines,they are more efficient by taking advantage of the additional btu's diesel fuel contains per gallon,combined with running at lower RPMS...using torque more than engine speed...the ventrac diesels need to spin 3600....so they dont take advantage of this,and they do not make more torque than the gas because they have the same bore/stroke as the gas engine,instead of a long stroke which gives a low speed torque advantage.Running a diesel at 3600 negates 90% of its advantage over a gas engine period...diesel flame fronts move much slower than gasoline,at high engine speeds the diesel fuel hasnt had time to transfer all its slow moving energy(this is where all the diesel torque comes from) to the piston before being expelled,this leads to high EGT'S and poor fuel efficiency,(think this may have something to do with cracked heads,and turbo failures?) All your heat is going out the exhaust.This is why Semi's run down the road with large, slow spinning inline 6 cylinders,they get the most energy out of every squirt of fuel shot into the cylinders,they are built with very heavy duty construction,and the last forever..IMO 3000RPM is about the max a diesel should run,continously in order to deliver a good balance of power,and economy.The reason you'll never see a 3000RPM engine in a Ventrac or steiner is the bigger diesels(Kubota D1105),Yanmar 3Tn82/84 for instance that make 28hp-30hp at 3000,do not fit in the ventrac or steiner,the length of the front end,lack of space for cooling fan/radiator means the engine cannot be over 15" long...and with the single pump design limitations,they need 3600RPM to get enough GPM and pressure from the small 15 series pumps....machines like the Steiner 230 have a large engine compartment,and only 2wd with less hydraulic demands,and the kubota d1105 engine is the diesel option,it is THE engine to have in a Steiner 230,if you were buying a 230,that would far and away be the best option,it is a powerhouse,will last forever,and will run a 72" deck at 10mph and not strain one bit,however when considering a 430 Steiner,things are different.
The Steiner 430 diesel engine is in the same boat as the Ventrac,as in it is not the best engine for most appications,it just has different issues,first off its way to small,and overrated,fooling consumers into thinking its powerful enough for the demands of hills,duals,and 72" decks,and it isnt. It is only 722 CC displacement with no turbo option,it makes 15hp at best,although its rated at 21.Unlike the larger 953 ventrac diesels it is a good engine,and is reliable,will last quite a long time,but because it is constantly being overworked,they rarely run past 2500hrs without needing a rebuild,they are just worn out from the high duty/load..The engine is a dissapointment in power for someone who just paid all that extra money over a 33 generac,30 kohler,or 25LC Kubota gas.This diesel also vibrates a lot,more than average,and this vibration shortens the life of many components on the machine itself,like the radiator,exhaust,wiring connections and harness,It shakes the machine to death basically a lot faster than the gas engines do....the gas version of the kubota is also a converted diesel,it runs much smoother,its very overbuilt,and will run forever,and makes substaintually more power than the diesel version for a lot less money....
Until manufacturers find ways to fit larger slower spinning diesels into there small power equipment,I will be sticking with the LC gas options or air cooled when better...Every situation in different,and before us consumers lay out our hard earned cash we need to gather as much information as possible on which engine options will fit our use best,instead of using the generic assumption that diesels always last longer,hold more oil,and make more torque.So before you buy take a look at exactly what your comparing,and what the high idle on the diesel option is,if its the same as the gas option,id look further,and make sure it will fit your needs,and give you the extra power,efficiency,service life,and reliability your paying an extra 3500.00 for......Sorry for the long post,just wanted to mention these things no ones brought up so far,and they are important factors to consider.
/ Ventrac choices: engine advice? #16
Raw dodge,
Those are very sound points that you are making. When most people are looking to upgrade their two cylinder, aluminum block, air-cooled, garden tractor, they look at the diesel powered options with lustful eyes. Perhaps it's the delusion that they will be getting something like the 3406E CAT that is moving tons of freight up and down the road. Truth is that the small diesels (+/- 1.0L) just don't have the same "zip" as their 16L brothers. In the small engine class the gas and diesel are very closely matched. I'll agree that the decision between gas or diesel should be settled between fuel availability, serviceability, and track record, rather than solely the "intrigue" of the diesel.
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
2006 Hypac C530AH Pneumatic Wheel Compactor (A61572)
2006 Hypac C530AH...
Brake Drums (A62613)
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
UNUSED WOLVERINE HYD TRENCHER (A64281)
UNUSED WOLVERINE...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
