First 2520 Mods
/ First 2520 Mods #1
PCABE5
Wisconsin
John Deere 4066R Cab and loader
Besides the seat, I found two mods to do today. I relocated the "thermos" which might look like it is in the way for seeing implements behind you but it does not affect my visibility. Now to figure out what I want to use it for as I keep the manuals in the shop, not the tractor.
Next I noticed the battery has a drain tube for battery acid which I did not like so I took one of the wifes old olive jars and made a catch for any acid. The bottom and bottom edge are wrapped with a stick on rubber in case of vibration/rubbing.
I also took Kenny's idea and made the lock out kit the stop for the deck height. Just in case the draft control stop moves the deck cannot go any lower. I did notice overnight the deck will lower itself so the 3pt must bleed down a little overnight.
/ First 2520 Mods #3
Any pictures of your lock-up kit you made?
/ First 2520 Mods
No pics as it is the JD kit, I just used your idea to use it to set deck height. I might look at some sort of quick adapter so that I can set deck height and quickly change to full lock-up without having to rethread the turnbuckle everytime. If I come up with something I'll post it on here.
Edward the "bullet box" makes a great tool box.
/ First 2520 Mods #5
AAHH thanks, I mis-read your post and thought you made your own kit...
/ First 2520 Mods #6
I thought 3pt's were never suppose to bleed down? This is the number one reason I see people avoiding the independent lift kit for the deck, it bleeds down while your mowing and before you know it, your scalping!
/ First 2520 Mods
It only does this when the tractor is turned off. It won't bleed down when running.
/ First 2520 Mods #8
Well sort of, a quarter inching value will leak down, and a position control will to, but because it is position control it will correct itself.
