Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,090
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Have a JD. No doors, no rollbar,nothing, just two seats and a rear tilting deck.
Bought from wife's cousin who lives next door so I know some of the history. (only paid couple hundred)
One of those "used to work fine" but he got fedup with something, bought a new one.
Issues:
1. One plug sparks perfectly fine, other is dead. Pulled the coil out for dead, tested it via ohm meter, everything tested with continuity (presuming it's supposed to be that way!) These are brand new plugs. Tried the old one and it's also dead.
Sprayed some ether into it and it gurgled a bit which is a good sign. (I put new hoses, battery, new gas...did more than detailing here)
2. Carb: no fuel was getting to carb. Has an inline clear filter so could see nothing getting there. Pulled supply off carb, fuel got to moving and came squirting out. Presumed air blockage or something was keeping it from flowing into carb (bowl was dry as a bone) Took float off.... it's not flooded. tinkered around, and now, have fuel at carb. In fact, it's dribbling OUT the (inlet) venturi.... I'm speculating it's not supposed to do that!!! Maybe the float needle isn't stopping (bowl is now getting fuel). Give it a gentle blowing test and it seems to start/stop the fuel easily.
I've not gone too much further into this. Taken me all day to get this far (I've had carb off probably 10 times.
Oh, and I do NOT recommend dropping into a gravel driveway, the non-magnetic crush washer used to seal bottom of carb....nor, to drop the non-magnetic spacer used to bolt a sensor onto the carb! Probably wasted an hour just looking slowly to find each of those.
Any thoughts on 1-2?
Issues:
