SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,632
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Jerry/MT said:This formula gives the limit of stability slope angle;
limiting slope angle = arctan (1/2 the rear wheel track/vertical height of the cg).
In this case, the limiting slope angle was 36.3ー assuming no other loads on the vehicle. If you hit a bump and it tips the tractor slightly down slope, you could tip over at a lower slope angle.
This gives you an upper limit on stability. Given that tractors often operate on a rough ground, you really wouldn't want to operate at this limiting angle. I would limit myself to oerating at a maximum of 80% of this angle and keep my speed down to preclude big tipping from rough spots. You can also increase the track of the rear wheels and gain some stability.
Iif you know the effect of the loader installation on the verticle height of the cg, you can compute the limit for a tractor with a loader installed.
Only if the CG is directly over the rear wheels on a tractor. -- An impossible situation since it would back flip. You have to allow for the longitudinal position of the CG as well, and since its well forward of the rear axle its going to reduce resistance to sidetip. A tractor always simulates a tricycle. No stability contribution from the front.
larry
In parentheses you have given the reason your assertion is not correct. Think about it a bit. ... You have a triangle formed on the surface from the rear contacts and a vertical projection of the front pivot. The CG must stay within this triangle or you tip. The further forward the CG the less slope necessary to tip. ... However, a tip on a slight slope will be stopped on a 4 wheel tractor by the pivot stop on the front axle.The cg does not have to be over the rear wheels for this relationship to hold. It's just a simple static stability relationship. The assumption is that the rear track is the widest(and is rigid) and will react out tipping loads untill the line of action of the CG falls outside the rear track.(Front tractor axles usually pivot so they can't support a moment about the longitudinal axis.)
larry
