For Those Without a BH, How Do you Do It?
   / For Those Without a BH, How Do you Do It? #11
Kyle,
Since you have a 4000LB TLB now, I cant imagine why you would not want one again, but also there are just some jobs that these machines cant do as fast or well as a larger machine or alternate methods e.g. stump grinding.
I have thought about upgrading my B21 (to an L39/45) but thats costly as you know, and since my neighbor has a CAT 416 and Excavator I hire him for low cost to do the heavy lifting as needed(3-4' rocks and such). He is not always available or the machines are at a job site so I have hired other work out too.
I tackle stumps up to about 8-12" but have rented a stump grinder and even hired a fellow for a flat rate of 350/day and he can grind about 10 30"-40" base in a day. The worse part about that is the clean up..
For large rocks (too big for my BH thumb) I use the bucket/chain method and wrapping the chain around the rock and to the center hook and tilt back.
The other option you might consider is a used L48 or L39 - these can be found for around $30-32K with not too many hours. The other option could be a older Case/Deere full sized hoe for $8-15K range.
   / For Those Without a BH, How Do you Do It? #12
Use one of my other five.:D Any size backhoe is better than none,
   / For Those Without a BH, How Do you Do It? #13
I have a JD 4120 with a 400X loader and heavy duty bucket. What I do to pop stumps, boulders, dig small holes, and move trees is bolt a 30" long piece of heavy, 12" wide x 3" channel-iron, flat under the center of the bucket. It sticks out the front about 20", making a nice, stout, 12" wide shovel. I dont know if Kubota makes a heavy enough bucket to get a way with a cheap trick like this, but it works very well for me. I only needed to drill (1) 9/16" diameter hole thru the bottom of the bucket on center to mount it, and also use (2) of the 9/16" toothbar mounting holes to attach the "shovel" with (3) 1/2" bolts. I also bolt a couple pieces of heavy, 4" angle-iron under the bucket in line with the lift arms on occasion for moving logs, etc. which required drilling a couple more 9/16" holes thru the bottom of the bucket, and again also using a couple of the toothbar holes. I dont have chain hooks welded to the top of the bucket, but I keep a couple loose ones in the toolbox, and again, bolt them to toothbar holes whenever I need hooks. Them toothbar holes sure are handy, even if I never do add an actual toothbar. I plan on digging a small pond some day with that tractor/loader, and I will probably spring for a toothbar before that job. The tractor is quite heavy up front though and does a pretty good job digging even without a toothbar, especially in the spring/fall when the ground aint too hard.
   / For Those Without a BH, How Do you Do It? #14
I've a small BH/B7610 combo. My eventual purpose, if I ever get retired and moved, was to use it to learn and also build narrow trails on my land. I've about 300+ acres in Ms of timberland, and 75 in Vt.
But until then I play with it on my little suburban lot in Va. I've attempted to dig out 4 stumps in Va. The first one I documented here
http://www.tractorbynet.com/forums/kubota-owning-operating/147380-my-first-stump.html
The next two were relatively small 8" pines, came out like greased lightning.
The last was a 30" plus maple with main lateral roots up to 12", I dug a 4' deep hole around it and it had big roots going down deep into heavy clay. It won.
Then to make matters worse, after I filled it in, thought I packed it down, and left it to sit for 2 months it bit me again. As I went to level the area around it I started sinking in, when I went to get out the front tire was about hub deep and came up against one of the 12" roots and I almost buried the little tractor. Now if I had had the BH on I could of lifted my self out maybe :)
   / For Those Without a BH, How Do you Do It? #15
Wow Newbury, how'd you ever get out of that hole?
Carl_NH, I know what you mean about missing a BH. My B20 has done a great job all round and the only stone/boulder that I could not move, I buried deeper (it was as big as my tractor). I haven't met a stump I couldn't remove but there have been some stubborn ones (big elms). I have looked at the L45 but it is too much money even though it's a beautiful machine. I have looked a little at used L39's or 48's but up my way there are not a lot around.
Newbury, I think you needed to yellow tape that area. Now that is a hazard!
   / For Those Without a BH, How Do you Do It? #19
If your asking the questioin... that means you want one.
You won't rest until you have it, Once you have it, you'll use it all the time.
Be safe!
   / For Those Without a BH, How Do you Do It? #20
"If your asking the questioin... that means you want one.
You won't rest until you have it, Once you have it, you'll use it all the time."
That's what I love about TBN: Not just idle chatter, but in-depth analysis.:)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JLG 600AJ SKYPOWER TELESCOPIC BOOM LIFT (A60429)
JLG 600AJ SKYPOWER...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
Kubota LX2620 (A53317)
