Powersharp chain
/ Powersharp chain #1
jlsmith
Murchison, Tx.
MF 285 Long 560 MF2670 CX100
Ok i have a poland pro 3500 series and i put a Oregon Powersharp chain and sharpener on it. WOOO! i have cut 1 1/2 cords and droped 3 more trees with it and that thing still cuts like a hot knife threw buter. A great investment I must say.:thumbsup:
/ Powersharp chain #2
If I remember correctly, is that one of those top sharpening things that go on the nose of the bar??
IF so, those arent bad for the ocassional user.:thumbsup:
But If you cur several cord per year, it is well worth the time to learn to file your own chains. And a granberg file jig with a dozen files will only set you ~$40
/ Powersharp chain
Yes its a top blade chain. I usually cut 4 to 5 cords a year plus all the clean up around the farm so we will see how it holds up
/ Powersharp chain #4
I watched that sharpening tech on Ask This Old House yesterday. There was a pile of sparks that came out as they showed how to use it. For now I will stay with the classic chain. ( I can not stand using safety chain )
That is why I order 50' rolls and make up my own.
Craig Clayton
/ Powersharp chain #5
So much does this cost? And do you have to use their chain? A guy at work was tell me about this just this past Thursday, but he did not know the price.
/ Powersharp chain #6
The ones I seen were for 3/8 low profile chain only, has this changed?
/ Powersharp chain
You have to get the kit to start with which comes with the bar chain and sharpener. It starts at about$ 75. If you need a new chain after original purchase they run about$ 30 all about the same price as the standard bar and chains
/ Powersharp chain #8
Put a Powersharp 18" kit on my JD CS36 last weekend. Wow.. Nice chain and sharpener. The kit was $59.99 at Home Depot. I used a 10% off Lowes Coupon (get them at local post office in movers kit -- home depot will honor). I also noticed there is a $10 rebate. That brought it down to $48 after tax and rebate. Not bad for a bar, chain, and sharpener. The time saved is even better!!
I'm not a pro and just want to use my saw with minimal downtime for sharpening. This is perfect for me....
PowerSharp Rebate Offer from OREGON
/ Powersharp chain #9
Sharpening a regular 20" chain in the field on the chainsaw takes literally 2 minutes, and it only takes about 5 minutes to learn how the first time. I can't see how this setup is any better than the traditional, even for occasional users. I guess many people think of sharpening chains as some sort of art that takes years to learn to do correctly, when that couldn't be farther from the truth.
And $30 for replacement chains that probably only have half the life of a regular chains at best? Boy, they really got you by the balls with that one...
/ Powersharp chain #10
Yeah its not that difficult to hand sharpen a chain, although for some they're better off with a device that give a more accurate angle,
for example: my son has my old chainsaw I showed him how to sharpen it, and he give effort to try:cool: although he brought it to me one time thought the bar had somehow got bent, he said the saw would cut in a curve not straight through, I took a closer look at the teeth and found that he was getting the right side teeth sharpened but the left teeth were not, :eek: He told me he couldn't get the file to go into the teeth on that side,he said it would bind with him:cool: ...
Hmmmm, so i guess he wasn't sharpening those teeth,:( no wonder it was cutting in a curve:confused2:
so for some folks they need this tool :thumbsup:
/ Powersharp chain #11
In my case I can sharpen a chain but not in 2 minutes. Takes about 10 minutes and focusing on the task. I'd rather just do it with the powersharp in 30 seconds and get on with cutting. I'm a rare saw user and prefer to cut wood when I want to cut wood. I hate spending time messing with sharpening a chain or worrying about hitting the dirt and dulling it again. I have a friend that makes plenty of $$$ but prefers to heat his home with wood. He does lots of sawing and gets frustrated when he dulls the chain from hitting dirt. Why get frustrated if you don't have too??
It's like alot of things in life. I just want the easier method since it's what I prefer.
/ Powersharp chain #12
Ditto. But many cant learn in 5minutes. Those that need this will gladly bear its rather significant increased expense. I cant imagine it really saving any time either because theres a big time overhead of assembly for each sharpening, higher replacement time/frequency from grinding away the chain, replacement of the stone with each new chain. :(
larry
/ Powersharp chain
larry
Well I dont need it to sharpen a chain but it is faster. It takes 2 seconds to put the sharpener on the saw and 5 secs to sharpen the chain. As far as add expense, I needed a new chain and bar anyway and it was about the same price. There is no higher replacement time and if and when you need a new chain the stone comes with it. I have cut ALOT of wood since starting this tread and have not noticed any more wear and tear on this chain vs the original chain that came on the saw.
/ Powersharp chain #14
agreed
sharpened my first ever chain (16") in a few minutes after watching another do his. Basically, you can't mess up with a good file. Just need to know where you started so you know where to stop!
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
2017 Case CX145D (A62177)
2017 Case CX145D...
