Loader CK 20s and round bales
/ CK 20s and round bales #1
dengar256
Sherbrooke, Quebec, Canada
kioti CK20S
I have a CK 20s and love it. I have a question about loading (FEL or 3 point). This summer I am looking at getting a couple of beef cattle and will most likely be feeding them round bales this winter. My guess is the the FEL on my CK 20s won't be able to handle the weight but I was wondering if I could put on a spear on the 3 point and work that way. Or could I get the farmer who will do the work for me make the bales "small tractor friendly"? My other option is to "encourage" my father-in-law to keep his CK 30 in my new shed for the winter (assuming I find the time to build it this summer).
I think I saw a thread on this a while back but could not find it so sorry if this is a re-post.
Thanks for the help.
/ CK 20s and round bales #2
CK 20 and round bales won't be a safe combination. Also, a good way to mess up the hydraulics on the tractor. Ken Sweet
/ CK 20s and round bales #3
The 3pt capacity is listed as 1300 pounds so I don't see why small rounds won't work.
If you could get big squares made would be better yet.
/ CK 20s and round bales #4
From Specs, You could theoretically lift the round bales, you would just be unsafe and also break the tractor. We sold those exact tractors for several years. Ken Sweet
/ CK 20s and round bales #5
The rated lift capicity will break the tractor? If so I guess they are some real POS.
/ CK 20s and round bales #6
The rated lift capicity will break the tractor? If so I guess thet are some real POS.
The main problem is the narrow track width of the tractor. Makes for VERY unstable tractor with a 1300 lb round bale on the front or back. Ken Sweet
/ CK 20s and round bales #7
You could do it IF you kept your bales small. I would not push my luck.
/ CK 20s and round bales #8
So what is the problem that they are unstable or it will break the tractor?
I wouldn't suggest a 1300 pounder anyway. I am thinking something like an 800 pounder. That is why I suggested squares, can be made smaller yet and kept closer to the tractor.
/ CK 20s and round bales #9
I used to move 500lb ish rounds with a wee tiny Allis Chalmers 616. It was not easy to lift them, but once I did it was fine. Then I'd tip the bale feeder on its side, drop the bale beside it and push the feeder over it. Worked fine for years.
Just don't get over-confident because before you know it you can be doing the old "oh ya, I can do that" and things get busted.
/ CK 20s and round bales #10
When the tractor turns over, then it breaks. Ken Sweet
Thanks for all the help. I figured it couldn't do it but was just hopeful. I guess I will just have to build the shed and convince my father-in-law to board his tractor here for the winter.
/ CK 20s and round bales #13
If you are feeding limited numbers of rolled hay bales, there is a way to feed them without the use of a tractor. Put the bales in the corner of the winter pasture field and line them up in single file and leave about a few feet between each bale. Then run a hot wire across in front of the first bale. When that bale is eat, move the electric cross fence back 1 more bale and when that bale is eat, move the wire back one more bale. I have a BIL that has used this method for many years. He does not even own a tractor. Ken Sweet
Ken that is a great idea. to start off with we will only have 3 - 4 cattle so I think this would work. I will have to remember this when I build the fence this summer.
/ CK 20s and round bales #15
Here is a rough drawing to show one way to feed round bale hay without a tractor. Ken Sweet
/ CK 20s and round bales #16
Bale grazing works well (the method Ken mentioned), or you can also just hook a tow strap or chain around a bale and pull it. I’ve had to do than when I had a flat on the tractor. Cows need to eat regardless. I don’t know anything about that particular tractor, but I do have some experience moving round bales near the lift capacity of my tractor. When the bales are new, it’s a little dicey on the hills, but not all that bad. But, in the winter and the bales now have a lot of moisture/ice/snow (weight), they’re all of sudden very tricky to move. Sometimes I have to back up hills just so I can steer. Remember, the lift capacity is typically at one certain point. A very large round bale is going to extend beyond that, reducing the capacity. If the farmer is able to make them smaller, great, but not everyone can or will.
/ CK 20s and round bales #17
At this rate, perhaps it's easier to move the cattle to the hay?
Thanks for your entertaining but accurate answers Ken. A good laugh is always welcome.
/ CK 20s and round bales #18
Thanks JonKioti, I can't remember the last time I have been called entertaining. I think I like it LOL Ken Sweet
/ CK 20s and round bales #19
The method Ken suggested works great.
An alternative is to get a single bale hay buggy with a hand crank winch and pull it with your tractor. It may still tip over, but only the buggy will go and not the tractor.
/ CK 20s and round bales #20
My ck20 lifts round bales with out any problems using the bale spear on the 3 pt hitch. But some bales can be a problem if its pretty green stuff and it's rolled to big
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
(2) STAINLESS STEEL HOG FEEDERS (A64278)
(2) STAINLESS...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2019 CATERPILLAR 299D3 XE SKID STEER (A65053)
2019 CATERPILLAR...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
