Loader CK 20s and round bales
   / CK 20s and round bales
Thanks for all the help. I figured it couldn't do it but was just hopeful. I guess I will just have to build the shed and convince my father-in-law to board his tractor here for the winter.
   / CK 20s and round bales #13
If you are feeding limited numbers of rolled hay bales, there is a way to feed them without the use of a tractor. Put the bales in the corner of the winter pasture field and line them up in single file and leave about a few feet between each bale. Then run a hot wire across in front of the first bale. When that bale is eat, move the electric cross fence back 1 more bale and when that bale is eat, move the wire back one more bale. I have a BIL that has used this method for many years. He does not even own a tractor. Ken Sweet
Ken that is a great idea. to start off with we will only have 3 - 4 cattle so I think this would work. I will have to remember this when I build the fence this summer.
   / CK 20s and round bales #15
Here is a rough drawing to show one way to feed round bale hay without a tractor. Ken Sweet
   / CK 20s and round bales #16
Bale grazing works well (the method Ken mentioned), or you can also just hook a tow strap or chain around a bale and pull it. I’ve had to do than when I had a flat on the tractor. Cows need to eat regardless. I don’t know anything about that particular tractor, but I do have some experience moving round bales near the lift capacity of my tractor. When the bales are new, it’s a little dicey on the hills, but not all that bad. But, in the winter and the bales now have a lot of moisture/ice/snow (weight), they’re all of sudden very tricky to move. Sometimes I have to back up hills just so I can steer. Remember, the lift capacity is typically at one certain point. A very large round bale is going to extend beyond that, reducing the capacity. If the farmer is able to make them smaller, great, but not everyone can or will.
   / CK 20s and round bales #17
At this rate, perhaps it's easier to move the cattle to the hay?
Thanks for your entertaining but accurate answers Ken. A good laugh is always welcome.
   / CK 20s and round bales #18
Thanks JonKioti, I can't remember the last time I have been called entertaining. I think I like it LOL Ken Sweet
   / CK 20s and round bales #19
The method Ken suggested works great.
An alternative is to get a single bale hay buggy with a hand crank winch and pull it with your tractor. It may still tip over, but only the buggy will go and not the tractor.
   / CK 20s and round bales #20
My ck20 lifts round bales with out any problems using the bale spear on the 3 pt hitch. But some bales can be a problem if its pretty green stuff and it's rolled to big
LOT: Flaring Tool Sets, Pipe Cutters, Brake Line Bender (A59076)
LOT: Flaring Tool...
2012 FREIGHTLINER CASCADIA SLEEPER TRUCK (A58018)
2012 FREIGHTLINER...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
