What do you do to keep your pressure tank/well head from freezing?
/ What do you do to keep your pressure tank/well head from freezing? #61
SPYDERLK said:
Item #3580K22 Near page bottom. Self regulating.
McMaster-Carr
larry
Yeah. I have something similiar.
But I need to run a 12/2 line down to do it right.. Tired of the extension cords...
/ What do you do to keep your pressure tank/well head from freezing? #62
Dan,
Do you want heat or light?
What I'd do- buy two regular pigtailed light sockets from HD or Lowes. Buy two 200 watt bulbs. Wire the sockets in series. The bulbs will last virtually forever running on 1/2 voltage but will produce 100 watts total of heat.
If that isn't the correct amount of heat substitute bigger/smaller bulbs.
The important thing is to use 2 in series so they last many years.
Try to set them up so you can see the glow from the house, maybe a clear lucite/acrylic rod through the pump house as an "eye". Glance out there occassionally in the winter to confirm they are working and turn them off in warm weather.
Attached is a pic of the sockets and one of a bulb.
/ What do you do to keep your pressure tank/well head from freezing? #63
:confused: Cant you get to pump power? Just tap 110 off that. Those shorter self reg tapes draw near nothing [fractional A] in cold operation and virtually taper to full off in Summer.
larry
/ What do you do to keep your pressure tank/well head from freezing? #64
larry
I've never heard of those..can you provide a link or something?
/ What do you do to keep your pressure tank/well head from freezing? #65
/ What do you do to keep your pressure tank/well head from freezing? #66
/ What do you do to keep your pressure tank/well head from freezing? #67
/ What do you do to keep your pressure tank/well head from freezing? #68
SPYDERLK said:
:confused2: HUH? ... I did provide a link in Post#51 -- to which you replied.
I'm sorry.. I was using the droid..
/ What do you do to keep your pressure tank/well head from freezing? #69
I got it now..
So if I tap the power.. And only need to cover 5 feet of 1 inch, that chart says we should use 1.3 feet of cable...
But could I tap a 60 watt bulb and a temp controlled switch in there?
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2013 Dodge Challenger Sedan (A60352)
2013 Dodge...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
2016 MACK CXU613 (A60736)
2016 MACK CXU613...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
