Tym 273 glow plugs
/ Tym 273 glow plugs #1
Deniza
Tym t273
Does anyone know what the part # for the glow plugs on the Mitsubishi s3l motor used by TYM? I can't find it listed in any catalogs. I would like to buy it threw my local napa store. Thanks in advance. Any other part # from NAPA would be very helpful. Fuel, air , etc.. My TYM dealer closed up shop. Thanks again for you'd help.
/ Tym 273 glow plugs #2
TYM Part # 32A66-03100
Thanks crossed the number over to NGK. Have them coming for the weekend. Let you know how they work out. Thanks for all your responses!
/ Tym 273 glow plugs #4
Do you mind sharing the NGK# ?
/ Tym 273 glow plugs #5
Do the glow plugs give much trouble? I know a lot of people have had trouble with the relay. I have 350 hours and have never had any problems with either.
I think I got the relay wet one time, then ran it with the light on. That said I just ohm check them and had to replace one. Started much easier. I have about five years into it.
/ Tym 273 glow plugs #7
Hi Deniza,
Like Myyaz33, I too, would appreciate it if you'd share the TYM Glow Plug cross reference to NGK #? Anytime anything can be cross ref'd it's good knowledge to know. Thanks. Greg
/ Tym 273 glow plugs #8
I had a lot of trouble with cold starting my TYM273. Finally completely burned up the glow plug relay (so bad they had to replace the plug and end of the main wire harness). Thank God for the warranty. At the same time they replaced the battery cables with cables nearly twice the diameter. Now I do not even have to plug in the block heater in cold weather to get it to fire right up. Good luck and please pass on the cross reference number for our own records.
/ Tym 273 glow plugs #10
Just following up on the new glowplugs. Did you fit the NKG y114T type and what are the results??
/ Tym 273 glow plugs #11
What were the conditions that it started hard in before? How does it start now?
Any smoking or does it burn really clean now (for a diesel anyway)?
/ Tym 273 glow plugs #12
i don't think smoking or clean burn have much to do with glowplugs,probably injectors. mine eats injectors for some reason.
/ Tym 273 glow plugs #13
If you can't find the P/n in your manual. Look up Grow Prugs. ( I'm dead serious that is how we have had to find a few in the manuals) :duh:
/ Tym 273 glow plugs #14
That made my day a little brighter with a chuckle!
/ Tym 273 glow plugs #15
TYM Tractor Response from the Service Departemnt. The Mit.... Part Number is 32A66-03100 for Glow Plugs. If you go to the TYM Web Home Page you can by Zip Code find the next closest dealer and order throught them and have our Parts department ship to You after the transaction is complete with the Dealer. CAUTION...FOR INFORMATION. USING A JUMP STARTER IN THE HIGH AMP STARTING MODE IT WILL BURN UP THE GLOW PLUGS IF YOU PREHEAT DOING STARTING MODE WITH CHARGER.
/ Tym 273 glow plugs #16
CAUTION...FOR INFORMATION. USING A JUMP STARTER IN THE HIGH AMP STARTING MODE IT WILL BURN UP THE GLOW PLUGS IF YOU PREHEAT DOING STARTING MODE WITH CHARGER. Does this mean never use boost to start these tractors?
/ Tym 273 glow plugs #17
I believe that the warning is for using a booster while the glow plugs are activated.
I have always cycled the plugs before trying to start ( unless it's warm of course). The dealer, when dropping off my unit, told me to crank it while the plugs were "lit." I waited the extra few seconds for the light to go out, and then started it. I may be wrong, but it's the way I was taught...
Thoughts anyone?
/ Tym 273 glow plugs #18
Thoughts anyone?
The plugs heat up fairly quick. ( and they cool down just a tick slower) They draw a lot of amps too. As soon as the light goes out I usually fire it up. This way I know the plugs have reached full temp. Its not going to hurt by counting 1-2-3 and firing it up while the lights lit.
As far as ALKYS question. Use common sense procedures whenever jump starting a vehicle. Turn the key on and let the the glow plugs run through their cycle, Then apply boost amperage. Remember to turn off the boost when you turn the key off. This would apply to just about anything with a glow plug circuit that is automatically activated by the ignition circuit. ( most newer tractors/ trucks)
/ Tym 273 glow plugs #19
Thx for the info. It's pretty much as I thought. I always thought that waiting until the cycles complete and hitting the starter immediately was the way to go...
I just picked up the cutter today. Appears to be a beast compared to my old KK 5-footer.
Once it warms up ( supposed to get some snow tomorrow... ), I'll hook it up and post a few pics!
Lunk
/ Tym 273 glow plugs #20
Hello, After reading this I double checked in the operators manual for my tractor ( T330hst ) which is the earlier model of your T353 and it says after the glow plug light goes out to start the tractor. I thought it sounded wrong to start it when it was lit as part of the voltage is used to charge the glow plugs which will drop the voltage the starter has to use.
2011 Ford E-250 Cargo Van (A66736)
2011 Ford E-250...
Ford 340B Loader Attachment
Ford 340B Loader...
Front Tank Bracket (A64126)
Front Tank Bracket...
2012 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2012 INTERNATIONAL...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
