Tym 273 glow plugs
   / Tym 273 glow plugs #11
What were the conditions that it started hard in before? How does it start now?
Any smoking or does it burn really clean now (for a diesel anyway)?
   / Tym 273 glow plugs #12
i don't think smoking or clean burn have much to do with glowplugs,probably injectors. mine eats injectors for some reason.
   / Tym 273 glow plugs #13
If you can't find the P/n in your manual. Look up Grow Prugs. ( I'm dead serious that is how we have had to find a few in the manuals) :duh:
   / Tym 273 glow plugs #14
That made my day a little brighter with a chuckle!
   / Tym 273 glow plugs #15
Does anyone know what the part # for the glow plugs on the Mitsubishi s3l motor used by TYM? I can't find it listed in any catalogs. I would like to buy it threw my local napa store. Thanks in advance. Any other part # from NAPA would be very helpful. Fuel, air , etc.. My TYM dealer closed up shop. Thanks again for you'd help.
TYM Tractor Response from the Service Departemnt. The Mit.... Part Number is 32A66-03100 for Glow Plugs. If you go to the TYM Web Home Page you can by Zip Code find the next closest dealer and order throught them and have our Parts department ship to You after the transaction is complete with the Dealer. CAUTION...FOR INFORMATION. USING A JUMP STARTER IN THE HIGH AMP STARTING MODE IT WILL BURN UP THE GLOW PLUGS IF YOU PREHEAT DOING STARTING MODE WITH CHARGER.
   / Tym 273 glow plugs #16
CAUTION...FOR INFORMATION. USING A JUMP STARTER IN THE HIGH AMP STARTING MODE IT WILL BURN UP THE GLOW PLUGS IF YOU PREHEAT DOING STARTING MODE WITH CHARGER. Does this mean never use boost to start these tractors?
   / Tym 273 glow plugs #17
I believe that the warning is for using a booster while the glow plugs are activated.
I have always cycled the plugs before trying to start ( unless it's warm of course). The dealer, when dropping off my unit, told me to crank it while the plugs were "lit." I waited the extra few seconds for the light to go out, and then started it. I may be wrong, but it's the way I was taught...
Thoughts anyone?
   / Tym 273 glow plugs #18
Thoughts anyone?
The plugs heat up fairly quick. ( and they cool down just a tick slower) They draw a lot of amps too. As soon as the light goes out I usually fire it up. This way I know the plugs have reached full temp. Its not going to hurt by counting 1-2-3 and firing it up while the lights lit.
As far as ALKYS question. Use common sense procedures whenever jump starting a vehicle. Turn the key on and let the the glow plugs run through their cycle, Then apply boost amperage. Remember to turn off the boost when you turn the key off. This would apply to just about anything with a glow plug circuit that is automatically activated by the ignition circuit. ( most newer tractors/ trucks)
   / Tym 273 glow plugs #19
Thx for the info. It's pretty much as I thought. I always thought that waiting until the cycles complete and hitting the starter immediately was the way to go...
I just picked up the cutter today. Appears to be a beast compared to my old KK 5-footer.
Once it warms up ( supposed to get some snow tomorrow... ), I'll hook it up and post a few pics!
Lunk
   / Tym 273 glow plugs #20
Hello, After reading this I double checked in the operators manual for my tractor ( T330hst ) which is the earlier model of your T353 and it says after the glow plug light goes out to start the tractor. I thought it sounded wrong to start it when it was lit as part of the voltage is used to charge the glow plugs which will drop the voltage the starter has to use.
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
1972 Chevrolet Cheyenne 10 4x4 Pickup (A57453)
1972 Chevrolet...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
