Oil & Fuel EZ Way to Refuel?
/ EZ Way to Refuel? #81
The flexible funnel tube from one of my 5 gallon cans is at the bottom of my fuel tank. It fell off the can and into the tractor tank one day. Doh!!
Tractor supply has a pump that is about 39 dollars and all you do is hook up to battery and pump just like at the gas station.
what i did was make a long cable and put a cigarette lighter adapter on it and plug into tractor and pump away about 15 gal per minute
/ EZ Way to Refuel? #84
That is remarkably cheap. Even HF charges about $120 for a 12V gas station style pump system. You sure it isn't $139???
/ EZ Way to Refuel? #86
Now that I have 2 tractors I am considering getting a 100 gallon square tank and putting it on a metal base with slots for forks. I will load it on the trailer, boom it down, drive to town and fill it up. Bring it back home and unload it with the FEL. I will use a 12 volt transfer pump. I can take it off site if I ever need to.
/ EZ Way to Refuel? #87
I just use a 55 gallon drum. I have one of those el cheapo harbor freight moving dollies under it so I can roll it around in the garage. Cheap and works well. Plus it's got the right size hole for my pump to screw into it.
/ EZ Way to Refuel? #89
Could you post a direct link, I couldn't find it on their web page.
/ EZ Way to Refuel? #91
Looks like we've pretty well run the gambit on fuel refilling methods, so I would like to temporarily hijack the thread to ask a related question.
Some of you have mentioned storing your fuel for a year or more. I would like to know if it ever goes bad. I realize it has been sitting far below the earth in some form for eons, but once it has been refined and mixed with additives, is there any sort of shelf life for diesel fuel or gasoline for that matter?
This would be better in it's own thread. If you search in the Oil, Fuel, and Lubricants forum: Oil, Fuel & Lubricants - TractorByNet.com you should find extansive discussion of this subject. It is a very valid question, but you will find much more information over there.
/ EZ Way to Refuel? #92
I think its 139.00
Yep. I have the HF version which combined with a TSC filter and a 30 gal poly tank I got from a car wash work very well. I think I got it for just under $100 by using a 20% discount and sale.
/ EZ Way to Refuel? #93
I did not like the new trigger type spouts, but found a good use for them.
Ran a chain down with a U-bolt on the end. Hook the U into the handle of the fuel can and drive under. Pull the trigger. Going to try to add photo.
/ EZ Way to Refuel? #94
ball n chain gas cans.
i hope my mom never gets wind of this. or i can see me pulling up a bunch of cans in the barn. if i ever go out of town, or go back down with some medical probs.
Pair of 26in. 8 Bolt Combine Rims (A65640)
Pair of 26in. 8...
3ft Metal Star (A65583)
3ft Metal Star...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T800...
Vision 250/50R15 77D Golf Cart Tires (A65579)
Vision 250/50R15...
2014 MACK GRANITE (A65643)
2014 MACK GRANITE...
