Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,743
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I have a Land Pride RBT1572 Rear Blade. While dragging a woods trail the other day the blade suddenly got all floppy. When I looked at it I could see that the large vertical cylinder that acts as a hinge pin for horizontal rotation had either dropped down out of the hole in the upper plate or worn so that it was no longer captured by the upper plate. I tightened the crown nut on top a full 3/8" to pull the cylinder back up into the frame hole. As you can see in the pic the crown nut is now way below the cotter pin hole in the stud. Normal ? I don't Know.
My question is this: How is that stud secured ? I tried to screw the stud back in with a couple jam nuts but couldn't move it. Land Pride does not show it as a separate part so it must be perminent.
I can't figure out if the pin was just caught by a hair and finally gave way after ten years of use or if the stud backed out and I should somehow get it back down. Does anyone Know ? I just dont want it to fall apart on me.
Thanks
gg
Thanks
gg
