jambx
Gold Member
- Joined
- May 14, 2007
- Messages
- 282
- Location
- Southern CT
- Tractor
- B2920 TLB, ZD21-60P, 1949 US Baird Beaver
I just thought I would share something that I think worked really well for me. I knew well ahead of time I was going to be frustrated this winter plowing my newly installed stone driveway so I began to look at ways to mitigate the effect the cutting edge on my rear blade had on the gravel surface. Someone in the past posted how well ABS (not PVC) pipe worked when fitted to the blade edge. Sounded like it would work and purchased a 10 foot length of 2 inch for $20. I gave it a shot (well two shots). After the first storm of the year (12 inches) it worked like a charm....well almost until right at the end of the plowing the stone wore it down to the point it just cracked. I replaced with the second piece and it too showed major wear so it was evident this ABS pipe route was not going to work.
I then remembered someone here stated how well Horse Stall Mat worked as a blade edge (Tractor Supply 4'x6' mat - $39). So I run out and picked up a mat, cut a strip and bolted it on. The next storm (18 inches) it worked like a charm - actually pushed the majority of snow with almost no ill effect to the stone (which is small pea like gravel).
So, I now have an awesome snow blade for gravel, it wears like iron (after plowing showed no wear) and I can use the remainder as a nice foot mat in front of my work bench until I need to make another - hey I have enough to make 4 more!!!
Cheers,
~jim
Cheers,
~jim
