looking for a stick welder...
/ looking for a stick welder... #1
chrisdvorak
Gold Member
RI
too many
/ looking for a stick welder... #2
I grew up with an AC arc welder. It's what I learned on by trial and error, and then taking metal shop in High School. It will get the job done, but it is also a real pain in the butt to get the rods started, and to get a really clean weld. There is also a lot of splatter.
Later on, I used a friends DC arc welder and was very impressed with how much easier it was to weld with, and how much better my results were. When I decided to buy an arc welder, it had to be a DC welder.
I didn't want to spend the money for brand new, so I waited until I found a used one in good shape. They never wear out, and are pretty much indestructible.
Search Craigslist, Ebay, the local free classifieds papers and whatever else you can come up with. I've even seen them at auctions and garage sales!!!! I spent $200 for mine with a crappy helmet and some old welding rods. I bought a new helmet and tossed the old rods out.
Good luck,
Eddie
/ looking for a stick welder... #4
I would look for used, nothing wrong with AC for your first machine, I got by with one for 30 years., but you should be able to find a deal on craigslist on an AC/DC like I did recently.
or at least get an AC cheaper.
I gave my old AC away and I know of at least a few others who have as well.
I got my old AC thunderbolt for free off the side of the road, it was beat up but I cobbled it back together and it lasted 30+ years.
Good luck, JB.
/ looking for a stick welder... #5
Well a couple of things, 6010 is really a DC rod, 6011 is made for AD or DC and is more suitable for the AC225.. I have one, it is a good old reliable tough dependable welder, and I havent struck an arc on it since I got my Everlast PA160 DC welder.. DC is much better, The results look better and are better, Your results will go up a notch just by getting the welder. If you want to stay with Lincoln, get the AC/DC model
James K0UA
/ looking for a stick welder... #6
I am looking for a stick welder to weld up to about half an inch or 6010 rod.
First 6010 is a DC rod, so the AC only machine you have found won't run that rod properly. 1/2 single pass is some fairly heavy duty welding. A 225 amp machine is just barely up to the task.
it seems to have good reviews and I was just wondering if it will burn 6010 rod and will hold up.
Lincon makes good machines, but you would be pushing this one at nearly its max, and you'll only get a 20% duty cycle. Burn a rod or two and the machine needs to sit and cool for 10 minutes.
We need to know about your intended use... Do you need to do a few inches of 1/2" weld once a month? Or are you building something that will have the need for feet of 1/2" weld?
/ looking for a stick welder... #7
Chris, for that price you can get an Everlast DC inverter welder. It's more portable and has better arc control. Look at the Power Arc 200. Several of us here at TBN have one so feel free to ask questions.
PowerARC 200 - Arc Tig Mig Welding Equipment, Plasma Cutters, Multi Purpose Units, Welders, Diesel Generators
I just now made an offer on the power arc 200, from Everlast. The price was $349.00 I offered $300, with free shipping. This welder has a setting that is optimized to burn 6010 rod, and a setting for 7018 rod. I already bought a Plasma cutter from them, using the make offer feature, and I was very happy with the price, and the machine works great. I don't know if I will get as good a deal on the DC welder, but I gave it a shot. I will post later when I hear back on my offer.
/ looking for a stick welder... #8
Chris personally I wouldn't drag that machine home if it was free! But I may have higher expectations of a welder than most guys here.
There was a discussion on another forum about the differences between AC and DC. I couldn't even remember the last time I ran a bead with SMAW on AC, so I went out to the shop and gave it a try. Right now I only have one machine hooked up in the shop that is capable of running AC.
I too bought a PowerArc 200 from Mark, I just love that little machine!
The first picture is a fillet weld I did on AC. I used Hobart's 1/8-inch 335A 6011. Soon as I struck an arc I was shocked at the sound, forgot all about the sound AC makes.:laughing:
The second picture is ESAB's 1/8-inch 10P-Plus 6010 on DC
/ looking for a stick welder... #9
Your AC weld looks excellent, you are an experianced welder. I guess the point is for inexperianced welder DC is easier, at least that's what everyone says, though for me it was not like night and day. That said I wont be going back to AC only any time soon.
Yeah that was the first thing I noticed about DC, alot quieter and smoother.
JB
/ looking for a stick welder... #10
And the 2nd thing I noticed, was less spatter, and less slag inclusions.
James K0UA
/ looking for a stick welder... #12
Nice welds shield arc. Have a question for you or others if don't mind. I have
bob cat welder generator haven't used it much for welding not satisfied when
finished welding with it.My question is are bob cat welders as good as electric
box welders. Any differents? Thanks.
/ looking for a stick welder... #13
It was directed to Shield Arc, but yes, they are as good as most AC/DC box welders, and close to inverters(but not on par) for performance...my opinion.
/ looking for a stick welder... #14
OR>> you could buy it from me directly. That's what I am here for.:laughing:
well, I am not going to be doing a ton of work but I do plan on building buckets and other projects alike that would need more than two rods at a time. It sounds like the everlast power arc 200 would be the way to go over the lincoln though, -what size of plug would I need to get wired to operate this welder properly?
-thanks chris
/ looking for a stick welder... #16
I have a Bobcat 250NT welder/generator. It replaced a 40 year old Sears AC buzz box. I use it quite often and think it works great. Last project I welded up was a 2'x4' carrier I can plug into the hitch on my 4 wheeler for deer season. Sure beats dragging them out of the woods. I mainly use DC for welding and it welds the same as the big Lincoln AC/DC welder we have at work. Maybe its the rod or settings you are using that is not giving you a satisfactory looking finish weld?
/ looking for a stick welder... #17
framer it's been years since I ran a bobcat, and I can't really remember the quality of the arc, sorry.
/ looking for a stick welder... #18
Well,
I have a Ranger if that tells you anything. I used Bobcats many moons ago on a summer job working on a welding crew. Big difference in the arc. But I have friends swear by them...:laughing: until they try a Lincoln.
/ looking for a stick welder... #19
-thanks chris
Plugs / Outlets with NEMA Rating 6-50 - LevitonProducts.com
The NEMA 6-50R receptical 6-50P plug is what I use, you will find many commercial welders with a cord already for this, you need a 50 amp 240 volt breaker in your box, I did not use this Leviton brand, I found a plug at Home Depot, for $15, but any builder/electrical supply should have this. Others have used a Dryer plug, but I believe the 6r-50 to be the correct plug. This is what my old Lincoln AC225 had on it. The everlast comes with some kind of Asian plug in the box, and not installed, that Mark recommends throwing away, I do too.
James K0UA
/ looking for a stick welder... #20
It will be best to use the 6-50, but it will depend upon what you have available...that's why there are no plugs attached. We realize that there are some "odd" plugs that people have for service. We have considered putting plugs on the ends many times, but with so many people telling us that they have this or that, any thing but the standard, it would create as many problems for people as it solves.
Unused 2023 Unused HLA 2.5 Yard Loader Bucket Attachment (A66734)
Unused 2023 Unused...
2009 FORD CROWN VICTORIA (A66091)
2009 FORD CROWN...
2012 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2012 INTERNATIONAL...
2006 Ford F-350 4x4 Ext. Cab Reading Service Truck (A66736)
2006 Ford F-350...
2001 STERLING LT7500 SERIES (A67714)
2001 STERLING...
2002 STERLING LT9500 SERIES CRANE TRUCK (A67714)
2002 STERLING...
