Subcut Maximum Towing Capacity
/ Subcut Maximum Towing Capacity #1
MARKMILES77
Member
Australia
Yanmar EA 2400
I am trying to find out the manufacturers recommended maximum towing capacity for the various brands of Subcut tractors.
If anyone who owns a subcut could check their owners manual and find out this figure I would be grateful (i.e. JD 2305, Kubota BX1860/2360, MF GC 2400 etc)
Thanks
Mark
/ Subcut Maximum Towing Capacity #3
Most of us would sheepishly admit we have towed far, far more than the 1700 lbs that a subcut might be rated to tow. Very, very slowly, on level ground.
Still, just because we have doesn't mean we should have or would recommend it to others.
/ Subcut Maximum Towing Capacity #4
tow capacity has to take into account braking. I'm sure most tractors can pull more then they can relaibly stop.. :)
soundguy
/ Subcut Maximum Towing Capacity #6
If you are shopping for a SCUT, towing spec is not something I would be hung up on. There are far more important things than that. Such as lift capacities, weight, dealer support, egronomics, etc.
Not to mention I think you would be disappointed in the specs for all of them. I think my L3400, which is a CUT and a bit larger than the SCUT's, is only rated to tow like ~2400lbs. So the SCUT's are going to be a good bit less.
Personally I dont worry about it. It is a tractor. If It can tow it, great, if not, the load is too big.
If you are asking because you are debating between a SCUT and a larger CUT, then again, there are other more important factors, such as the other tasks you plan on doing with the tractor.
/ Subcut Maximum Towing Capacity #7
I think Soundguy pretty much covered it, but it made me lookin the manual for any reference since it wasn't something I remembered. And it wasn't covered as far as I can tell.
I can say I have moved a horse trailer close to the same weight as my TC33 and it never balked. I would probably move even heaver equipment if needed.
I do look at my route and keep everything level, with a good landing zone in case I get a little push. :eek:
/ Subcut Maximum Towing Capacity #8
I couldn't find that info in the operators manual for my Massey...........so I guess I'll stop towing when the tractor won't move:thumbsup:
/ Subcut Maximum Towing Capacity #9
soundguy
So when you're pulling something heavy and precious you have to take extra precautions.
Wm
/ Subcut Maximum Towing Capacity #11
But when you can't stop it's already too late.
It doesnt matter how big the load or how small the tractor, the load can ALWAYS be stopped.
How far, or how long till the bottom of the hill........that depends.
/ Subcut Maximum Towing Capacity #12
Along those lines, "It's not the fall that kills you, It's the sudden stop at the end".
When it comes to a manufacture certifying the maximum payload for vehicles, the brakes must be able to absorb the worst case scenario. Bringing that vehicle to a stop from 70MPH down hill with hot brakes. If you are pulling something that heavy with a tractor you are already in low gear so you dealing with what 4MPH.
With a SCUT, you are not dealing with a large property so realistically the reason to use a tractor vs. the tow vehicle, is you are trying to park that trailer in an tight corner of the property where the bigger vehicle won't go.
/ Subcut Maximum Towing Capacity #13
You may not see a "tow capacity or weight", but you should see something in your manual about maximum tongue weight on the drawbar. That should give you an indicator of what you can tow.
/ Subcut Maximum Towing Capacity #16
:laughing: :rolleyes: YUP! I can relate.
Keep in mind that the 3 pt and drawbar, tongue, pulling ratings are different.
For example the BX24 rating is:
3 pt hitch lift 1210 lbs
Lower hitch tongue weight = 550lb
Lower hitch tow 1765lbs trailer weight
Like what BP fick is trying to say- you will be very surprised what a subcut can really do regardless what the "max ratings" say. Putting a small diesel in a small tractor can do wonders in ways you can't imagine. Its just a matter of time to do it compared say to a larger tractor.
If you are trying to get the most out of tractor for least amount of money, I'd say many subcut ratings are so close it doesnt matter due to what tractor really can do. The ratings are there for a reason. SAFETY!!!!!! (well - yeah warranty issue too. :laughing:) )
Its really about experience which will come with owning a tractor. Its more of sizing the tractor to the lot and task you plan to do. Why not tell us a little bit more about why you are looking for rating for all brands in subcut?
/ Subcut Maximum Towing Capacity #17
/ Subcut Maximum Towing Capacity #18
Ive pulled 9000lbs with my tractor with no problems. If I woulda been going downhill then I woulda had major stopping issues. But on flat ground its no problem. I think I could get away with pulling 12,000lbs. But my manual says 7200lbs max. So chances are regardless of what its rated you could pull more.
The reason I asked the question was because I was surprised to see that the Cub Cadet SC 2400 Owner Manual lists the maximum towable mass as 300kg (661 Ibs). My little ride on mower can tow that, so it seemed to me to be a ridiculously low figure.
/ Subcut Maximum Towing Capacity #20
I thought it was a little low too so I checked. According to the website specs its 3-Point Hitch Lift Capacity @24" Behind 661 lbs
Sc2400 Sub Compact Tractor
That is the 3 point hitch [lift,not towing. But its still odd to me as for whats the weight capability. It kinda way too low, more like then half. perhaps its a mistake?:confused:
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2020 Ford Transit 350HD Cargo Van (A61573)
2020 Ford Transit...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
2004 INTERNATIONAL 9400 T/A DAY CAB ROAD TRACTOR (A63291)
2004 INTERNATIONAL...
CASE TV450B SKID STEER (A64279)
CASE TV450B SKID...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
