Lubrication - valve levers
/ Lubrication - valve levers #1
PointyHairedBoss
Orrville, Ontario
Kubota B21 TLB, Kubota B2920
What lube do you use for hydraulic control valve levers?
I was thinking white lithium.
  • 1.pdf
/ Lubrication - valve levers #2
Silicone Spray Lubricant, Aerosol Can. Mostly invisible so it doesn't look as if it is accomplishing much but it is.
/ Lubrication - valve levers #3
I've used white lithium, 30 weight oil, JD SuperLube and I'm sure the Silicone Spray Lubricant would work too.
I suspect it's more import that you keep it lubricated than what you use.
Did your levelers for the backhoe every get freed up?
Pete
/ Lubrication - valve levers #4
Fluid Film for me.:thumbsup: Use it on just about everything.
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
Zero Turn Mower (A59231)
Zero Turn Mower...
REDDICK 300 GALLON SPRAYER (A63291)
REDDICK 300 GALLON...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
