Jan 6, 2011 / Lubrication - valve levers #1 PointyHairedBoss Bronze Member Joined Jun 11, 2010 Messages 97 Location Orrville, Ontario Tractor Kubota B21 TLB, Kubota B2920 What lube do you use for hydraulic control valve levers? I was thinking white lithium. Attachments 1.pdf 366.1 KB · Views: 159
Jan 6, 2011 / Lubrication - valve levers #2 S SandburRanch Veteran Member Joined Oct 12, 2010 Messages 1,543 Tractor NHtd75 Silicone Spray Lubricant, Aerosol Can. Mostly invisible so it doesn't look as if it is accomplishing much but it is.
Jan 6, 2011 / Lubrication - valve levers #3 eepete Platinum Member Joined Sep 30, 2009 Messages 963 Location Efland, NC Tractor JD 4520, Kubota B21, JD 318 I've used white lithium, 30 weight oil, JD SuperLube and I'm sure the Silicone Spray Lubricant would work too. I suspect it's more import that you keep it lubricated than what you use. Did your levelers for the backhoe every get freed up? Pete
Jan 6, 2011 / Lubrication - valve levers #4 kennyd Advertiser Joined Jul 6, 2003 Messages 13,840 Location Westminster, MD Tractor John Deere 3720 CAB/TLB, JD455 Fluid Film for me.:thumbsup: Use it on just about everything.
Jan 6, 2011 / Lubrication - valve levers #5 devildog1 Veteran Member Joined Dec 3, 2008 Messages 1,612 Location Up-State New York Tractor Grand L 3540 HST-3, R4's kennyd said: Fluid Film for me.:thumbsup: Use it on just about everything. Click to expand... I agree, Fluid Flim is the best I've ever tried,:thumbsup: DevilDog
