Building welding/work table?
/ Building welding/work table? #11
Glad you made your decision, but how about it guys- what is wrong with say a heavy wood frame bench-say 2" planks (1-1/2") work surface covered with 1/4" plate (A36). I built such a bench with a 2' x 2' plate on one end. I welded four studs (each corner) then bolted it through the planks. I also have a very large -and old_ commercial grade vise bolted through in the right hand corner. Haven't burned the barn down yet!
/ Building welding/work table? #12
That's close to what I have and it works for me .
/ Building welding/work table? #13
i guess it depends on what you are doing.
a large part of the reason for using a thick piece of plate is not just to prevent being bent from hammering down on it, it's to prevent moving around when you are hammering things at an angle. say you have something tacked to the table and you are swinging sideways with a sledge hammer... thats when the mass of the thicker table top comes into play.
you want to table to stay put, no matter how hard you wail on it.:)
/ Building welding/work table? #14
I have a bunch of different work benches. My favorite right now is my Arc Station from Miller. It's only thirty by thirty and three eighths plate. But it's handier than a pocket on a shirt.....
/ Building welding/work table? #15
I have a 5' by 5' 1" thick top on my table(sorry no pic's) at home, got wheels and a hitch to pull it with the tractor. Been using it outside for 2 years and in the summer heat when I build jigs ontop, then heat and bend thick steel I get some bounce out of it. With 3" wide and 1/2" thick bracing every foot and running full lenght on the bottom. I got 4" sch 120(think not sure might be thicker) for legs, the only thing I paid for was the top. Everything else was scrap that I found or was given to me. If I do it again Im gonna try and find 2" or 3"thick. Got a 3" thick table at work and with a 20lb sledge the welder and I can get it hopping.
In another forum I read a few years ago, they said to get as thick as you can handle, and afford. And I to started out wanting just a hobby welding table, I thought mine was overkill. But that went out the window as my skills, knowledge, and desire grew.
/ Building welding/work table? #16
1/2" plate is a good choice for the top. I also used 4"x4" for the legs and have adjustable feet made with 1" bolts and some homemade washers with thin rubber glued on. The supporting structure is all 3/8 x 3". This was my first project with my big welder and I went a bit overboard, warping the top a bit. It hasn't caused any problems using it over the last 15 years, but pride of workmanship would have preferred I hadn't warped it. Be very careful. I wish I had asked for some advice before starting the welding. The bottom rails are 2x2 and easily support the bench for moving with a dolly and floor jack or pallet mover. Please excuse the junk in the pictures as I just recently moved here and everything is still piled wherever it would fit. I have a truck motor I usually store under this and the combination weighs 1300 lbs. I can do anything I want with hammers, pry bars, etc. and it's as solid as a rock. One of the most useful projects I've made. Size is 30x60
/ Building welding/work table? #17
Get the drill press first -- a good one though. Chuck should be a morris taper of some sort. And as slow a speed as you can get, floor mount of course. The mill/drill is slower to use, not as versatile.
I ad a too small floor model (wood worker sized) then go the drill/mill. Later found a much better (cough -- HF even-- cough) drill press. MT taper (#2 I think) chuck, almost as slow as I wanted.
/ Building welding/work table? #18
Thanks guys. I decided to pick up the 1/2" plate and the money save is going for a floor drill press :thumbsup: or maybe a combination mill and drill press :drool:. Now that will be another question I will be asking later on...:D. If the weather gets warmer this weekend I will be building this.
i had been looking for a decent used drill press for ages, and i came to the conclusion that finding one was like finding a needle in a haystack. everyone has a sears or lowes/home depot bought press on craigslist, and while they may be great for wood, they are a little on the light side for metal. i found a nice jet that i liked, but the $750 price tag put me off, and then i found the harbor freight version of it (part number 39955). i just looked it up and it's now $569 on sale, plus shipping. i would have sworn is was $398 plus shipping this summer. but anyways, while i was looking at the dealer that sold jet, i saw the mill drill combos. i ended up looking at them and for the heck of it i did a craigslist search for the surrounding states, and found a used enco one for $550 about 3 hours away. it's a 2hp, 700lb machine, and the new version (including stand) sells for $1500 and up. i also got a tote full of tooling. mostly end mills, but nearly all appear new or hardly used, and they are almost all usa made trw ones. i'd think they probably cost as much as i paid for the mill.
i can drill large holes through thick steel with no pilot hole, and i've got a very heavy piece of machinery for not much more than the cost of a mid-grade drill press. i've used the milling capabilities on a few occasions, and while i'm not trained with it, i have been able to produce the desired results. i'm sure the machine isn't super precise, and i know i'm not, but let's face it, if we're building tractor parts, we aren't dealing with 1/10000 of an inch. if you can get one for cheap, i can guarantee you'll find uses for it you never thought of.
/ Building welding/work table? #19
The Harbor Freight Drill presses are pretty stout. You can get nice floor length models. I have used mine extensively for 4 years and no problems. Of course, I have my little HF table top close by that my dad bought in 1984.
/ Building welding/work table? #20
I am glad you went at least 1/2" top but I would still drop back 6-8" underneath and do the subframe as already mentioned. That way it is not springy.
I would advise aginst wood with metal top. At least for what I do. I'd end up burnign the wood. I tack stuff to the bench, and lay parts on the bench to heat with the torches all the time.
But I personally like the heaviest bench I can. I want to KNOW it is solid when I am putting heavy parts up on it, pounding on it, etc. We had a monster in the maintence shop where I used to work. It was 4'x8' with a 2.5" top:D with the vices mounted, legs, shelf underneath, it weighted about 4100lbs. Needed a forklift to move it, but it was rarley moved.
Reciever is a great Idea for the vice too. We did the exact same thing. TSC has the 2.5x2.5 seamless tube with the hole already in it. All you have to do is supply a peice of 2x2 heavy wall and a flat plate to bolt the vice to. We did this for 2 reasons, 1, you can get rid of the vise and have a open table to if the vise is getting in the way. 2. we use a granberg file jig to sharpen the chainsaws. A vise is almost a must for sharpening. Now we can just throw the vise in the back of the truck and have it at the woods whenever we need to sharpen.
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A61307)
Bulk Lot of over...
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
2015 Ford F-250 Service Truck w/ Liftgate (A59230)
2015 Ford F-250...
2017 Thompson 32HPU 55kW Towable Trash Pump (A59228)
2017 Thompson...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
