battery replacement terminal
/ battery replacement terminal #1
rvhop
Central, Al.
1975 Ford 4000, 1953 Ford Jubilee
Hello everyone, I need to replace the positive battery terminal on a ford turbo diesel. There are 3 wires, 2 of them are good size wires. 2 of the wires came in the old terminal from the back and the 1 from one battery to the other came in from the side. If any body has replaced theirs, I would appreciate knowing what was used. Thanks
/ battery replacement terminal #2
Go to Cat dealer and get regular clamp type terminal ;they are like automotive only larger and will work with the larger cables. On a 1989 Ford used copper terminals from welding supply house. Filled full of hot solder using a torch and inserted cables. The cables were bolted to the top of a marine style battery that I was using. It looks to be a bigger problem then it is. Just cut the big chunk of lead off and go.
/ battery replacement terminal #3
Velvac makes a terminal that bolts together , that will accept the wires from 3 sides . You can probably go on their web and see what I am talking about . I have sold their products at my store for years , you can find them locally at a tractor/trailer parts store. I hope this helps .
/ battery replacement terminal #4
I would not recommend the bolt on battery cable ends, except in an emergency.
I can't tell you how many times over the years I have had to repair vehicles where they corroded so much inside, that the battery could no longer start the vehicle.
I have seen people replace batteries, starters, and alternators, only to find out later they only had a bad connection inside a bolt on replacement end, which on appearance, looked perfectly fine until it was disassembled.
I suggest you always replace the cable.
/ battery replacement terminal #6
In my experience the best long term solution is to buy the Ford factory cable from the dealer, anything else is a short term repair.
Brian
/ battery replacement terminal #7
anything else, done and maintained correctly, could be a good long term repair... key is maintenance.
a good bit of grease ont he terminal after connection, and cleaning when you service your vehicle should keep everything happy.
I also have one of those wierd molded on/passthru lead clamps for my dual bats in my 7.3 psd one is showing signs of it's age and will be sawn off and a passthru clamp on installed with dielectric grease and then tended to as needed to keep it conducting like it should. proper maintenance solves ALL KINDS of problems..
soundguy
/ battery replacement terminal #9
doesn't have to be... you can make a perfectly working repair that will have the same net resistance in your garage for pennies on the dollar for what the dealer charges for those serial molded cables.
I restore antiques as a hobby. i can sure tell you I have 'mocked up' some stuff that was better than original, or a reccomended replacement.. especially when it comes to the electrics side of things.
theres no reason you have to gut and replace 10' of 1/0 copper because a molded lead plug 3/4's the way down it died.
heck.. think out of the box.. take the blinders off. you could easilly remove the old molded on plug and 't' splice a similar 1-wire plug in using a short 3" wire stub, join the copper and solder after trimming back the insulation, add an anti corrosive agent, then dielectric, the heat shrink it. your lab grade vom capable of meauring 3 digit past the decimal ohms won't see a flipping difference.. and neither will the starter or battery.
this is why we have huge landfills. everyone always thinks you have to unbolt a 90% good part and throw the entire thing away and put a new one on to replace it. no one cares to 'repair' stuff anymore... kinda sad....
soundguy
/ battery replacement terminal #10
I don't work on vehicles as a hobby, I do it for a living.
You don't have to tell me to "think out of the box.. take the blinders off". No one in this area has created more innovative repair procedures than me.
I have not seen how you do it, but I have seen probably a hundred of them over the last 35 years that had grease, shrink wrap, tape and God knows what else on them, and they still failed. That's enough for me.
The weather in Ohio is somewhat tougher than in Florida. Right now it's well below zero with the chill factor. That takes away a major portion of your batter power, add to that a weak connection, and your car is not going to start. Not to mention what a regular heavy coating of road salt does to electrical connections.
Screwing around replacing the end, and doing regular disassembly and cleaning, for what, to save about $10? Yea, I know some cables are not that cheap, most of them are. Even if it's 3 times that, I certainly have better things to do, than spend my time re cleaning a battery terminal, and hoping I don't forget to do it someday.
Since my reputation, and my family depend on it, I replace the cable. That way I never have to think about it again.
/ battery replacement terminal #11
I'm mostly with you Ray. On a product where they don't have aux leads molded into the cable, I typically don't have any problem crimping on a new end and having it run for years without a problem. But the Fords and Dodges, I replace the cables. Yes it is expensive, but like you say, when it is my reputation on the line why take a short cut.
Brian
/ battery replacement terminal #12
I didn't even bother reading your message past the 1st sentence. saw all I needed.
you are compairing apples to wax fruit.
i'm talking home reapir stuff. if you spin wrenches for a living you are all about no returns.. no warranty work, no liability and selling parts to install for best case fixes. Nuff said.
soundguy
/ battery replacement terminal #13
I agree with both of you guys here. There is no way I would make some "Farmer" repair on a daily driver. Especially something my wife or child would drive. I want my daily drive to be 99.99% reliable. The cost of a OEM or aftermarket direct fit cable is not that bad. I have seen electrical components get fried from bad connections and that can get real expensive.
Now on the other hand a old tractor or work truck can get a "Farmer" repair. I know I will be the one operating it, usually close to home, and not very often. These type of repairs can be done all ways. I had my drive paved last year and the guy doing it had a 2 pair of Vise Grips holding on a GM style (junk side terminals that I hate) to a regular post battery. I have also made up battery cables for marine applications using soldered on end covered with color coded water tight heat shrink.
Each has its place.
Chris
/ battery replacement terminal #14
funny you mention that. I used to know a guy that had some old beater farm vehicle that he drove around his farm... he'd drive to his tractor, and then take the battery out of the truck and slap it in the tractor, then trade back in the evening. ( guess he didn't want to have to buy another battery? ).. anyway.. onthe truck, his bat cable ends were 2 pair of those like 5" vice grips, with the bad cable in a piece of copper pipe that had been flattened, then drilled thru with a hole. there was a short 3/8 bolt welded to the side of each grip and the cable went onthere with a nut. he'd just clip them on and then unclp them to remove it. kind funny... a lil too redneck for me.. but.. :)
funny thing about vice grips... I see them used for many things. manual window roller handles. have seen one clipped to a jeep steering shaft in lieu of a wheel before!
soundguy
/ battery replacement terminal #15
I seen a guy share a battery with his boat and truck one time. Put the boat in, park the truck, take out the battery, put in the boat and go fishing, back to the ramp, carry the battery back to the truck, install the battery, load the boat and head for home. Too funny.:D:D:D
Chris
/ battery replacement terminal #16
now I've seen that alot.. especially for huys that leave a boat slipped and only visit now and then.. prevents theft.. and you know the bat is hot when you start..
soundguy
Timberjack 608B FellaBuncher (A62679)
Timberjack 608B...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
KBH PT 12 Row Liquid Fertilizer Applicator (A64119)
KBH PT 12 Row...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2012 Chevrolet Sonic Hatchback (A61574)
2012 Chevrolet...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
