Using a generator to power a water well pump
   / Using a generator to power a water well pump #21
For most of us on well systems, this is the best mini-course on the power required to get water to the house that I have read. For all of us seeking such info - THANK YOU!!
   / Using a generator to power a water well pump #22
I have a disconnect box from the house wiring to the well pump. This disconnect box has a pigtail hanging out of it that the generator cord plugs in to. When the power goes out I pull the disconnect. This isolates the pump wiring from the house wiring. Then I plug the pigtail in to the generator. If the power comes back on it doesn't matter because the pump and generator are isolated from the house wiring. I had an electrician do this. It wasn't that expensive. Most folks out this way run their well pumps this way and it's easy to find an electrician that knows exactly what you are talking about when you ask him to do this.
I just installed a 240 outlet adjacent to the subpanel that powers my well pump. If needed I just unplug the pump power cord from the outlet and plug it into the outlet on the generator. It's a similar setup but simple enough for essentially anyone who can work a plug to operate.
You're welcome, that is why I posted this.
   / Using a generator to power a water well pump #24
Our generator is a 7500 kw with a 13500 surge. We run our well pump and everything in the house except our central air and my dryer. It will run everything else plus our tenants fridge and some lights for him. Last time my tenant wired us up some rabbit ears on a step ladder outside so we could hear what was happening.
We added another bathroom with a tankless water heater so I will turn it off if we have an outage. We have a gas waterheater so I'm sure that allows us to have sufficient power for the freezer, fridge, and other things in the house, also a gas stove.
The well pump will pull it down a bit when kicking on but it works fine.
Last hurricane though, I had 50 gallons of gas yet got to the point before they could get any filling stations open that I was siphoning gas out of some of the vehicles.
My husband has a panel for it in the wellhouse. We turn off the mainbreaker so as not to backfeed and then I have written instructions of how to start it up and how to turn it off. It works really well.
I wanted a Generac but they just use to much propane and also the expense of maybe once every 2 years or so. Also they have very limited circuits unless we would get I beleive a 20kw, think hubby said.
   / Using a generator to power a water well pump #25
I have 7000 watt/8750 starting power generator with a transfer switch. Electrician turned the well on while testing it, he flushed the toilet a few times until the tank bladder was down enough that the pump kicked in. He wanted me to hear what happens. Generator made a quick louder blip sound. But once the pump stopped it quickly stabilized. Around here we mostly have propane heat and water heaters and most neighbors have generators 5500-8000 watts (continuous). As long as we have gas to run a generator, it'll do what we need to stay comfortable.
Regarding siphoning of gas from vehicles - is that still possible from a car? Last year during a huge storm and outages people were trying to figure out how to do that - I'd read supposedly in the mid 90's they put anti-gas theft devices in gas tanks so people can't siphon. I've not tried it but read elsewhere someone's comment that they were trying to figure out a way to bypass that device during our big storm last year because trucks had a hard time refueling gas stations..
   / Using a generator to power a water well pump #26
As far as I know they are still putting anti-siphon devices in cars. I saw a note where someone mentioned certain manufactures had stopped but I don't know if that is true. After Katrina I saw more than one mention of people having to buy new fuel tanks for their vehicles as the only way to get the gas out was screwdriver and hammer. I have always wondered if it would be easy/possible to intercept the fuel pump line somewhere and use it to pump the gas out of the tank, I think most vehicles have electric fuel pumps now.
   / Using a generator to power a water well pump #27
This is the plug/outlet that the electrician put in for me. Hydro goes out we just have to unplug from hydro and plug in from the generator. No chance of a back feed as only one plug can be plugged in, pretty simple. Our 5,500 watt generator will run the ½ horse submersible pump in our 2,000 gallon storage tank. Nice to have water if the power is out for 5 days. :thumbsup:
   / Using a generator to power a water well pump #28
My situation is my panel has TWO 20 amp circut breakers for the well pump but there is only regular Romex 120 wiring going along the walls to supply the regular wall switch used as shut off for the well pump, it not the usualy heavier 220 Romex? Also unlike my Mother's submersiable pump well set-up in New York I have no control box? Just a pressure switch with low pressure shut off then three heavy wires going into conduit to the pump?
   / Using a generator to power a water well pump #29
Shortlid,
It sounds like you described 2 20 amp single pole breakers - correct? If so this is 220V going to the pressure switch. You also have a 2 wire pump which means the starting capacitor etc are in the pump motor.
Romex is 12-2 or 14-2 standard internal house wiring and for a 20 AMP circuit this SHOULD be 12-2 wire as 14-2 is rated to 15 amps. Then when the white and black wire are connected to the two breakers this = 220V. I dont know why you dont have a double pole 20 amp breaker in there?
In either event I would suggest you make sure the pump is on the 220V circuit by it self and the wiring is heavy enough feeding the pressure switch.
From how you are describing this I would suggest you have an electrician install the generator transfer switch to your house/well to make sure you have the wiring correct, and the loads/circuits needed balanced properly.
   / Using a generator to power a water well pump #30
Shortlid,
It is a a double throw with a metal bar attaching the two 20 amp breakers. It is not the ones I have seen that has one switch for a breaker that takes up two spaces in the panel.
I checked just now it IS 12-2 wiring I guess it is SLIGHTLY larger than the regular romex going through the rest of the house. I also have a 220 plug for pottery Kiln thatthe PO used to have. But it is armored sheathing over the wiring. That and the electric water heater are the only 220v run in the house. The oven and range is gas.
So guess i will have to look through my paperwork to see what type of Gould pump is down there.
207270 (A52708)
207270 (A52708)
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
Hustler super Z zero turn (A56859)
Hustler super Z...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2013 Jeep Wrangler 4x4 SUV (A59231)
2013 Jeep Wrangler...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
