Repaint YM2000
/ Repaint YM2000 #1
shawnjvl
South Mississippi
YM2000, Kubota G1800
Started repainting my YM2000, I will post photos as I go. The fenders and the hood had alot of surface rust spots, ground and sandblasted all the spots, filled and primed. Using TSC implement paint MF red, white, and black for the frame and chassis, First pic is before, second in process
/ Repaint YM2000 #2
Looks like your making good progress. Lookin good. :thumbsup:
/ Repaint YM2000 #3
To be honest the tractor looked good as it was...paint looked better then most I see. anyway good luck with it.
/ Repaint YM2000 #4
I just used touchup in a spray can I've had since I Bought my tractor that I purchased when I was buying parts. Finally got around to useing it and looks good enough for me. It's a 35yr Old tractor made for work! I've never been a Desk Jockey and if you had a Busy or Rough Day your useally dirty and maybe a Little Scratched up at the end of it. I'm over 10 yrs. older than my Tractor and now I'm thinking I could use a little touch up in a few places myself. :p:laughing:
Carey
/ Repaint YM2000
Main reason I'm doing repaint is the rust, Living on the Gulf Coast with the salt air, I didn't want to end up with major rust. Regards
/ Repaint YM2000 #6
Sorry about that Shawn just agreeing with Smoody It Didn't Look That Bad At All. Seen alot Worse and for sale wanting Big bucks for it. What I mostly hit was Just bare metal and my Grills and same here my wheels are next they have Rice Patty Rust spots on them. I'm just waiting to get Brave enough to get out my El Cheapo HF Paint gun and hope I don't make a Total Mess :ashamed:
Carey
/ Repaint YM2000 #7
Carey
Only 10 years older.... for me I need a rebuild...some days it is a little more than scratched up. My mind thinks i am 30 but my body always tells the truth!!
/ Repaint YM2000
A few more pics, Pulled fuel tank, pulled all wiring and acc., pulled dash, battery, seat. Repaired some more spots on hood, cleaned all the glue where old stickers were. Started cleaning up rust on frame and motor and priming bare metal. Have a great day
/ Repaint YM2000 #9
Carey
Cary those are interesting bearing caps on the front. Are yours held on bly 3 bolts? Mine appear to be the tap on kind like youd find on the front of any old 2wd pickup truck. I see that you oil cap was painted green mine is still yellow? Just interesting to see others machines up close. Tell me what you have on your front bearing caps or take a straight on pic of the for me!
/ Repaint YM2000 #10
Unless you plan on stripping, cleaning, priming, painting each and every piece on the chassis, engine, and frame, I would forget about changing to black and just touch up the green, otherwise you could end up with a big mess.
/ Repaint YM2000 #11
I agree with Normde...the green will always want to show through especially around the grease. I tried this an implement and it looked great for about 6 mo then it was a mess ...I then had to do it right.
/ Repaint YM2000
I worked in auto body repair for almost 20 years, I think I will have good luck.
/ Repaint YM2000 #13
Cary those are interesting bearing caps on the front. Are yours held on bly 3 bolts? Mine appear to be the tap on kind. Tell me what you have on your front bearing caps or take a straight on pic of the for me!
Finally got out today Clemsonfor. Interesting never noticed the difference until seeing shawnjvl's pic. Here you go.You can see I was in them when I bought it.Figured a mid 70's Model I needed to see if they needed Repacked. Nope there sealed FWIW ;)
Carey
/ Repaint YM2000
Carey
I believe Carey has the heavy duty frt axle option, Wish mine had it. I think Carey you have tapered roller bearings instead of the ball bearings like my 2000 has, which I already had to replace.
California can you confirm.
/ Repaint YM2000 #15
Thanks Carey, interesting what you notice. I need to check mine i have not looked at them yet, i have put 80 hrs on mine this year that i have had it. I also have a brake that is squealing a lot now , need to pull the cover and see whats going on and if i have any lining left or do i need to reverse them.
/ Repaint YM2000 #16
I don't know the answer to that one.
My (US) YM240, equivalent to YM2000, has the optional HD, adjustable width front axle same as shown in the back of its parts manual under 'options'. (And I assume this is simply the axle off a larger model). I think the tractor was ordered loader-ready, and the loader may have been put on before it was ever sold.
Mine has the four cover bolts as shown in Carey's photo. I read somewhere, and have always assumed, that this is a sealed bearing. Seems to me it would have to be, the way these tractors are run half submerged in the rice paddies.
/ Repaint YM2000 #17
cary mine looks like it has dust caps on it tat you tap on. neat1500 talks about repacking and replacing the bearings
/ Repaint YM2000 #18
yep been there,done that. my original bearings collapsed so i had to replace. i used sealed ones not open style like it had(dust covers removed) and 2 new race washers cost me $28 AUD. been good sofar but ended up with a flat front today while slashing:(
/ Repaint YM2000 #19
Neat,
Did you order these from a Yanmar dealer or did you just go to the bearing house? You still dont have those part #s do you?
Also im guessing since the type berings Cary has are for the heavy duty axle there is no chance of getting those particular sealed bearings to replace my greese packed bearings?
/ Repaint YM2000 #20
Clem ...take your old bearing to a good bearing house and they will match it up for you... you may not need numbers. I replaced a large bearing in a 1400 tiller and got a sealed bearing for about $30 ...it was there better bearing.
2000 (INOPERABLE) KENWORTH T800 (A67714)
2000 (INOPERABLE)...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Wheels and Tires (A66734)
Set of 4 Unused...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2015 DRAGON PRODUCTS CRUDE TRAILER (A67714)
2015 DRAGON...
