Problems with no ethanol gas
/ Problems with no ethanol gas #1
Skyco
Elite Member
SC/NC
I've been using no ethanol gas from a local Exxon station for a few years now in all my power equipment.
Recently I've had two issues come up-
First, my backup gasoline generator at my camp wouldn't start. Pulled the carb off and was horrified at the amount of crusty chunks of some black substance in the carb. Cleaned it all up and got it running. BTW this generator is test run about once a month and has Stabil treated gas which is swapped out every 6 months or so.
Yesterday I went to fire up the Onan 4kW gas generator in my toy hauler RV.
Wouldn't start. This generator is also run monthly. Troubleshooting revealed the electric fuel pump wasn't pumping, could hear it buzz but no flow. Huge PITA to remove the generator from the RV to get inside it to get to the fuel pump. Playing with it I got the pump working by filling it with aerosol carb cleaner and letting it sit a few minutes. Nothing came out of the fuel filter Onan has on the input to the fuel pump when back flushing it with carb cleaner.
Inspection of the tank revealed more of this black crud found in problem one above, encrusting the fuel pickup tube. I think this crud had shellaced the fuel pump plunger into place. The fuel pickup is one I made of copper tubing when the original plastic one fell off a few years ago. No junk was visible in the tank, which is a 10 gallon or so plastic boat tank on the tongue of the trailer behind the LP tanks. This generator also is test run about once a month and has Stabil treated gas which is swapped out every 6 months or so.
So- I'm wondering if the ethanol free fuel has enough, or any, of the cleaners that are present in the ethanol "enriched" fuel.....
I think I'm going to start buying my ethanol free fuel at a different station to see if this happens again...but it may be likely it all comes out of the same source at the tank farm near North Augusta SC, regardless of the brand. It is highly unlikely the fuel in both gensets came from the same purchase but it is possible and maybe it was simply bad gas. The Exxon I've been buying it at is right at the Lake Murray dam and they move a huge amount of this ethanol free gas to the boaters.
Curious if anyone else has experienced similar problems. Lets not get into a debate here about ethanol politics, already got that going in other threads:thumbsup:
/ Problems with no ethanol gas #2
Interesting situations.
I'd be suspect of the Stabil addative too.
And I think for generators, I'd try to get a way to connect a fresh gas supply to them when they need to run.
I've long thought, that just a crank-up and start once in a while, really can't do much to keep a carb clean. But that is likely just my feeling on it. But changing fuel suppliers (you are fortunate to have some choices as some states have gone 100% ethanol enhanced fuel supply). We are getting it shoved down our throats.
By running occasionally I think it does keep the carb from "gunking up" due to evaporated fuel. IOW if not run the fuel dries out in the float bowls due to being vented to the atmosphere, leaving behind gunk or "varnish". A run flushes this out with the new, non evaporated gas containing the lighter/volatile components.
Just found the black gunk odd, never found black stuff ever in fuel or fuel residue no matter how old, brown maybe but not black:confused:
/ Problems with no ethanol gas #4
Around here the non ethanol gas is getting very hard to come by. The last few places have sucked their tanks dry and I wonder how many other places are doing the same and at the same time are sucking up what ever sediment is in their tanks.
/ Problems with no ethanol gas #5
There have been a couple of posts lately about ethanol vs. Not. Frankly I was surprised I can't even remember the last time I saw non-ethanol gas around here. It's mandated by state law so there's no choice. Personally I've never noticed a difference with either. :)7
/ Problems with no ethanol gas #6
Whhhaaattt? I think I heard that only happens with ethanol.:laughing:
/ Problems with no ethanol gas #7
The only problem I've ever had with non-ethanol gasoline is finding some...
/ Problems with no ethanol gas #8
I don't use Stabil anymore. Can't be positive but I think it causes starting problems. If I have to leave a machine out for the winter I shut off the pet cock and run it till it stops.
Rob
/ Problems with no ethanol gas #9
Rob
That is what I do too. If there is no fuel left in the carb there is no risk of evaporation and remaining solids to clog jets.
/ Problems with no ethanol gas #10
I've found dry carburators/fuel pumps to be more trouble than those left with Sta-bilized fuel; never had a problem with Sta-Bil and have used it for years. I e-mailed the company(?) when we first had to deal with ethanol "enriched" fuel. Received an answer from the vice-president advising the use of regular red Sta-Bil unless in a marine enviroment. I've got a bunch of small engined equipment; 3 chain saws, back-pack blower, self-propelled lawn mower, JD lawn tractor, DR lawn/leaf vacuum, Craftsman push lawn vacuum, DR Field&Brush mower, 6500 watt generator(Honda powered),a Craftsman 8HP snow-blower, and a 4-stroke Yamaha snowmobile. Use red Sta-Bil in them all; some stored for 6/7 months and have not a fuel problem(starting and running) with any of them. Oh ya, also use it in my Kawasaki Mule :eek:
/ Problems with no ethanol gas #11
I have the red, maybe I'm not mixing it correctly or something, thanks for the info I'll check the instructions.
/ Problems with no ethanol gas #12
I mix 2oz to 5 gallons of fuel when in use; double it to 4oz. per 5 gallons for extended storage(6 mths. or more)
I've heard theories both ways on running the carb dry or not. Some say running them dry can dry out seals, and I tend to agree, IF the fuel is treated it should be ok to leave them wet.
The Onan has a fuel pump and no shutoff so I can't easily run it dry if I wanted to. The Generac has a shut off and sometimes I shut if off and sometimes I don't. Prior to discovering the black crud it was left on, gas was actually seeping out of the carb and had wet the air filter element. When I couldn't get it to start was when I disassembled the carb and found all the black crud. I've never seen anythng like it in 40 years of being a motorhead..
Generally the crud I've found in ethanol/gas fueled small engines is white dusty stuff from the water picked up attacking the often zinc carb parts.
/ Problems with no ethanol gas #14
Have you been using the marine Stabil product? I understand it is black in color.
/ Problems with no ethanol gas #15
I just went to my small engine guy to get a rebuilding kit for my 8 hp snow blower engine. When I took it apart all the seals were cracked and crumbling apart. He said it's the new gas. I've never seen anything like it I rebuilt this thing s few years ago and my rebuilds usually last quite awhile.
Rob
/ Problems with no ethanol gas #17
I just found an Exxon station in my area that only offers ethanol free gas. It's priced the same as the ethanol blended gas so I got a 5 gallon can full for my small engines. Thought I was doing the right thing until I read your thread. Now I'm wondering how they can offer it for the same price? Am I missing something?:confused:
Curious. Around here all the non-ethanol gas is a little higher- 10 cents or so.
I continue to use it, I do add a dose of either Techron or Regane Complete to be sure it is cleaning well.
/ Problems with no ethanol gas #19
I cant speak to the no ethanol gas as I find no one offering it at my home. However after having the carb rebuilt twice on my pressure washer and the shop telling me that 1 month is enough time to screw up a carb using ethanol fuel, I believe it. I put in Stabil but it still messes them up. Now I try to run them dry if possible and if not I double load the tank with blue stabil. I just hope that holds my lawnmower for the winter. Maybe I will pull that tank and use the gas in my autos and run the carbs dry when I get back home just to be safe. It is usually not a problem to run the pressure washer out of fuel as it lasts about 30 minutes per tank anyway.
/ Problems with no ethanol gas #20
You folks keep talking about the Blue Stabil and I can not say it works or does not but I maintain about 75 engines between my stuff, my marine business, and the mowing contractors equipment I maintain. When we use the Marine Ethanol Sta-Bil bought at WalMart we have had zero issues for the last 3 years. I have used all the others and never did me any good. Especially the red stuff. Its just been a waste of money.
Deprecated Browser Error
Give it a try. I get a container that treats 320 gallons for $20 at WalMart or TSC. Thats about $.06 per gallon. Cheap insurance.
Chris
2003 Odyssey Lextra 2502 Pontoon w/ 2009 Bagg Boat Trailer (A62613)
2003 Odyssey...
2012 International WorkStar 7500 Truck (A64194)
2012 International...
John Deere C450 Mower Conditioner (A66285)
John Deere C450...
1999 MACK MIXER (A65643)
1999 MACK MIXER...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2025 Swict 84in. Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
