aircommuter
Platinum Member
- Joined
- Nov 26, 2012
- Messages
- 707
- Location
- coulterville,ca
- Tractor
- case 570lxt, JCB 1550B, Gradall 534c, Hyster C612B,Ford 445A
That’s a good choice if A/C is available near the tank and the source has a backup generator.
That's what I was thinking, suppose you need it during an extended power outage. I use an old motorcycle battery that won't hold enough charge to start the bike, but will run a tank top pump. I can pump about 200 gallons before the battery needs another charge. For those "end of the world" days when all else fails, I have a hand pump from Harbor Freight that screws onto the 55 gallon drums I use. Just a thought.That’s a good choice if A/C is available near the tank and the source has a backup generator.
I also, want to use this connector to control my spreader and sprayer.I am planning to add a typical 7 wire trailer plug to my tractor and us it and a male 7 wire trailer plug to power my fuel pump.
I use the SAE Connector for everything, I think some of them are good up to 20 ampsI also, want to use this connector to control my spreader and sprayer.
I have a 100 Gal tank that I use for my tractor. I just use a spare battery and charge it when it gets low.I need to improve the power source for my farm’s diesel fueling station. I need something more reliable.
The 12V DC transfer pump is mounted on an 500 gal. tank outdoors. I currently have just a tractor and ATV requiring diesel, (though this could change), so it doesn’t get used more than once every few months unless it’s growing/tilling season. When I set it up about 10 years ago, I thought the easiest way was to get power from the fueled unit through its cig lighter/DC power port, but this has its problems. Sometimes – especially when I want to fuel them both at the same time - the draw heats up the plug and on occasion pops the inline fuse or even the fuse on the vehicle’s DC port. Then everything comes to a halt while I go fuse hunting. Recently, I suspect it may have even torched the wiring to the ATV's DC port, since I had the dealer tech up the fuse's spec to handle the pump draw. And it seems to vary depending on ambient temperature. I’ve cut down the wire leading to the pump to the minimum needed to reach the vehicle, but it remains an ongoing problem.
The fuel station is within about 20 feet from an inside-accessed AC power outlet, and I’m wondering if some beefy DC power supply would work better; I could run it out to the station only when needed. But after a quick look at these, it seems many are more suited to audio and electronics test bench situations than my ag application.
I am currently renewing all components of the fuel station – pump and motor, hose and nozzle, etc. – and need to get rid of these nagging DC power issues. Trolling for suggestions, wondering what others might be using in a similar setup. Your thoughts on the subject would be welcome. Thank you.
~Lefty7
A 120 volt pump would be the direction that I'd head in. And if your 12 volt pump is any good at all you can sell it to a contractor or excavation company.I need to improve the power source for my farm’s diesel fueling station. I need something more reliable.
~Lefty7
As long as you have ac power available. But then you wouldn't need a 12 volt pumpI got an old battery charger with 2-10a selection, cut the leads off and wired it to my 12v pump. Set it to 10a 12v and always on. Plugged it in and it works great.
My fueling station is parked in the shop, it's a 55gal drum. Tractors and mowers go to it. But I suspect if I didn't have 110v I could just run it off the tractor that's carrying it. Trailer harness would be sufficient for a quick disconnect.As long as you have ac power available. But then you wouldn't need a 12 volt pump
